Scott Spark 10 (2009 mod) str L
Scott Spark 10 (2009 mod) str L #831535 14/10/2009 18:20
Scale 10 Offline OP
Selger min pent brukte Scott Spark.
Dette er en utrolig morsom og rask sykkel, som passer like fint til bukkerittet, som rundbane og hyggelige turer i skog og mark.
Meget bra utstyr med topp komponenter.
Spec:
Weight:
10.20 kg / 22.47 lbs
Frame
- Scott Spark / IMP technology / HMF net
- carbon swingarm / carbon dropouts with replaceable hanger
- sealed aircraft bearings
- 110mm rear travel
- optimised SLS kinematic
Fork
Fox 32 F120RL / Air spring
Alloy steerer / reb. adj / lockout
Quad tapered lowers / 120 mm travel
Shock (Rear)
Scott Nude TC
3 modus / LO-TC-AT
Ball joints / reb. Adj.
trac loc 2 remote control
Headset
Ritchey Pro 1 1/8“
semi integrated 44/50mm
Derailleur (Rear)
Shimano XTR RD-M972 SGS
carbon cage
Shadow Type
27 Speed
Derailleur (Front)
Shimano XTR FD-M971 / 34.9mm clamp
Shifters
Shimano XTR SL-M970
Rapidfire Plus 2
multi and 2 way release
adj. clamp
Brake Levers
Shimano XTR BL-M975 Disc
Brakes
Shimano XTR BR-M975 Disc
180/F and 160/R mm
CL RT97 Rotor
Crankset
Shimano XTR FC-M970
Hollowtech 2
44Ax32Ax22A T
BB-Set
Shimano Cartridge
shell 73mm
Handlebar
Ritchey Carbon WCS
18mm Rise / 640mm
Scott lockon grips
H'stem
Ritchey MTB WCS
4-Axis 44
oversize 31.8mm
1-1/8“ / 6° angle
Seatpost
Ritchey WCS Carbon / 34.9 mm
Seat
Selle Italia SLR XP Kevlar / Vanox rails
Hub (Front)
Shimano XTR
HB-M975
Disc CL
Hub (Rear)
Shimano XTR
FH-M975
Disc CL
Chain
Shimano CN-HG93
Cassette
Shimano XTR
CS-M970
11-32 T
Spokes
DT Swiss
Super Comp
black
Rims
DT Swiss
4.2 Disc / 32H
Tires
Schwalbe Rocket Ron
26 x 2.25 / 127EPI
Kevlar Bead Evolution
triple compound
Pris 30 000
Re: Scott Spark 10 (2009 mod) str L [Re: Scale 10] #832099 15/10/2009 14:32
front biker Offline
hei
er på utkikk etter fulldempet for bruk på sti, og muligens ritt a la bukkerittet, ultrabirken, 6-dagers etc.
jeg er 191 cm og veier 92 kg. er ramma litt liten, eller kan stemmet forlenges?
og seff: prisantydning??
mvh Øyvind, Oslo, 975 25 425
Re: Scott Spark 10 (2009 mod) str L [Re: front biker] #832512 16/10/2009 08:57
supadupa Offline
Sitat: front biker
hei
Hei, ser at Lars Bleckur selger sin Scott Spark RC til 32000,- SEK. Omregnet til dagens kurs til NOK er jo prisen ganske bra.
Link:
http://www.larsbleckur.se/empty_14.html
Re: Scott Spark 10 (2009 mod) str L [Re: supadupa] #833598 18/10/2009 17:51
Scale 10 Offline OP
Ny pris er 28000
Re: Scott Spark 10 (2009 mod) str L [Re: Scale 10] #836971 24/10/2009 13:42
Scale 10 Offline OP
bump
Re: Scott Spark 10 (2009 mod) str L [Re: Scale 10] #841556 02/11/2009 07:53
Scale 10 Offline OP
bump
Re: Scott Spark 10 (2009 mod) str L [Re: Scale 10] #841804 02/11/2009 14:17
oph Offline
Hei Øyvind,
Jeg har en Spark LTD i XL og ville råde deg til å finne en i denne størrelsen. Dette er bare en fantastisk sykkel, men ikke kjøp den for liten. Jeg syklet tidligere på en Trek Fuel 100 i str L. Den hadde overlørlengde på 62,5 cm og jeg opplevde den som litt kort og gikk stadig vekk over styret. Spark i XL har overrørlengde på 64,5 cm og med den har jeg aldri vært i nærheten av å gå over styret. Lykke til med sykkelkjøp.
Hilsen
Ole Petter
Re: Scott Spark 10 (2009 mod) str L [Re: oph] #843486 05/11/2009 09:07
Scale 10 Offline OP
Ny pris 26500
Re: Scott Spark 10 (2009 mod) str L [Re: Scale 10] #843931 05/11/2009 21:54
sor Offline
Hei. gir deg 22000 for sykkelen.
interessert?
Re: Scott Spark 10 (2009 mod) str L [Re: sor] #843965 05/11/2009 22:56
gustav75 Offline
Er hjulsettet mulig å omgjøre til slangeløst?
Re: Scott Spark 10 (2009 mod) str L [Re: gustav75] #844045 06/11/2009 08:10
Scale 10 Offline OP
sor takk for budet, men nei takk.
Gustav 75, ja det er bare å legge i stansteip og ventil. Fungerer helt utmerket
Re: Scott Spark 10 (2009 mod) str L [Re: Scale 10] #852709 22/11/2009 09:48
Scale 10 Offline OP
Solgt!
Re: Scott Spark 10 (2009 mod) str L [Re: Scale 10] #852751 22/11/2009 12:09
supadupa Offline
Grattis:)
