Used only once, will not have any time to use it this year so i am selling it. Can be shipped. If you are interested PM me and ill take some pictures.
179 - 186 cm L
FRAMESET
Frame Aurum carbon 650B 200mm travel
Fork Rock shox Boxxer RC 650B 200mm
Rear Shock Rock shox Kage RC coil spring
WHEELS
Rims Sun Inferno 29 rim 650B black, with eyelet
Tires Maxxis Minion DHR II Rear DHF Front 3C 650Bx2.4
Tubes Kenda MTB 650B presta tubes
Front Hub Formula alloy sealed bearing 20 mm
Rear Hub Formula DHT rear cassette disc hub 142 x 12
Spokes/Nipples Black stainless spokes 2.0
DRIVETRAIN
Shifter Front N/A
Shifter Rear Shimano Zee 10sp KSLM640RA
Shifter Casing Jagwire LEX housing
Front Derailleur N/A
Rear Derailleur Shimano Zee Shadow Plus short cage
Cassette Shimano SLX custom 7sp cassette w/spacer
Crankset Race Face Respond DH 165mm 36T
Bottom Bracket BB PF MTB 107
Pedals Alloy low profile flat MTB pedal w/steel pins
Chain KMC X 10 10 sp
Chain Tensioner E13 LS 1
COMPONENTS
Seat Post SDG I-beam 30.9x350mm
Seat Post Clamp Integrated w/frame
Saddle SDG I-Fly I-Beam saddle, Norco graphic
Headset FSA #57E-1 w.5.3 mm top cover
Headset Spacer 1x10mm, 2x5mm, 3x3mm headset spacers
Top Cap Norco FSA
Stem Spank Director "direct mount" 50mm
Handlebar Spank Spoon 772x20mm rise DH bar
Grips Norco lock on
Front Brake Shimano Zee hydraulic disc brake
Rear Brake Shimano Zee hydraulic disc brake
Brake Levers Shimano Zee
Brake Cable Casing N/A
25 000 NOK
Redigert av Che3z; 18/05/2017 16:05.
