Selger en ny/ubrukt 2015 Scott Scale 920 str M som følge av manglende impulskontroll ved passering av butikk med høstsalg... Den har ikke blitt syklet en eneste meter. Selges da jeg egentlig ikke har behov for denne.
Selges 14000,- (veil 27000,-) Evt høyeste bud.
Hentes/leveres/besiktiges i nærheten av Drammen.
Mvh Øyvind 91675727
The SCOTT Scale 920 boasts a super light HMF Carbon Fiber frame. The series comes fully equipped with a FOX CTD fork, along with our RideLoc technology to allow for three travel settings to always optimize your ride.
Frame Scale Carbon IMP technology / HMF / Tapered HT PM 160 Disc / BB92 IDS SL DM dropouts for 142 × 12mm SDS Shock Damping System -------------------------------------------------------------------------------- Travel 100mm -------------------------------------------------------------------------------- Fork FOX 32 Float Evolution CTD Air CTD damper with 3 modes 15mm QR axle / tapered steerer reb. Adj. / 100mm travel -------------------------------------------------------------------------------- Remote System SCOTT RideLoc Remote Technology 3 modes / integ. clamp -------------------------------------------------------------------------------- Headset Syncros / VP-J205AM1 / 1.5" - 1 1/8" semi integ. OD 50/61mm / ID 44/55mm -------------------------------------------------------------------------------- Rear Derailleur Shimano XT RD-M786 SGS / DM Shadow Type / 20 Speed -------------------------------------------------------------------------------- Front Derailleur Shimano SLX FD-M676-B / 34.9mm -------------------------------------------------------------------------------- Shifters Shimano SLX SL-M670-I Rapidfire plus / 2 way release Ispec clamp -------------------------------------------------------------------------------- Brake Levers Shimano BL-M615 Disc -------------------------------------------------------------------------------- Brakes Shimano BR-M615 Disc 180/F and 160/Rmm SM-RT64 CL Rotor -------------------------------------------------------------------------------- Crankset Shimano XT FC-M785 Hollowtech 2 38Ax24A T -------------------------------------------------------------------------------- BB-Set Shimano SM-BB71-41A / shell 41x89.5mm -------------------------------------------------------------------------------- Handlebar Syncros FL1.5 Tbar Alloy 7050 D.B. / T shape Flat / 9° / 700mm Syncros Pro lock-on grips -------------------------------------------------------------------------------- H'stem Syncros XR1.5 -10° 7050 Alloy / 31.8mm / 1 1/8" -------------------------------------------------------------------------------- Seatpost Syncros FL1.5 34.9mm -------------------------------------------------------------------------------- Seat Syncros XR2.0 / CROM rails -------------------------------------------------------------------------------- Hub (Front) Syncros XR2.5 CL / 15mm made by DT Swiss -------------------------------------------------------------------------------- Hub (Rear) Syncros XR2.5 CL / 142 × 12mm / RWS axle made by DT Swiss -------------------------------------------------------------------------------- Chain Shimano CN-HG54 -------------------------------------------------------------------------------- Cassette Shimano CS-HG81-10 11-36 T -------------------------------------------------------------------------------- Spokes DT Swiss Competition 2.0 -1.8-2.0 Black -------------------------------------------------------------------------------- Rims Syncros XR2.5 28H -------------------------------------------------------------------------------- Tires Schwalbe Rocket Ron EVO / 2.1 127EPI Kevlar Bead PaceStar compound -------------------------------------------------------------------------------- Weights in KG 10.50kg
