NY GT Fury 2010-Veil 70000 - Selges 30.000 - Str M
NY GT Fury 2010-Veil 70000 - Selges 30.000 - Str M #1378910 22/04/2012 15:24
Stoffer Offline OP
Helt ubrukt downhillsykkel. Den råeste fra GT. Selges rimelig.
Teknisk spec :
BOTTOM BRACKET: Shimano New Saint
BRAKES: Shimano Saint Centerlock 203mm (front) 180mm (rear)
CASSETTE: Shimano Dura Ace nine speed 12 - 25
CHAIN: Shimano
CRANKSET: Shimano New Saint with 38 tooth ring
FORK: Rock Shox New Boxxer World Cup, with high speed, lo speed rebound and compression damping, motion control, new 20 mm maxle, 36 mm stanchions, air spring adjust
FRAME: Full Monocoque Carbon Fiber with forged and CNC fitments, with all new I link assembly and pivot design for 8.65 inches of rear wheel travel with Maxle rear axle QR system
FRONT DERAILLEUR: E-Thirteen SRS Light guide with chain taco for 38 tooth ring
GRIPS/TAPE: GT alloy Lock Down
HANDLEBAR: FSA Carbon DH. 31.8mm bar bore, 25 mm rise with 8 degree sweep 3 degree tip
HEADSET: FSA Orbit Z 1.5 R cold forged alloy cups for 1.5 headtube with sealed cartridge ACB bearings, with internal reducers for 1 1/8 steerer, 9mm total stack
LEVERS: Shimano Saint
PEDALS: NA
REAR DERAILLEUR: Shimano New Saint short cage
REAR SHOCK: Rock Shox Vivid 5.1 coil spring with ending and beginning stroke rebound adjust, compression ending and beginning strokeadjust, drop stop bottom out adjust
SADDLE: WTB Rocket V Pro, with Cr-mo Rails
SEATPOST: Thompson zero offset, CNC turned USA made 2014 seatpost, 31.6mm by 350
SHIFTERS: Shimano New Saint short cage
STEM: FUNN RSX Direct mount for Boxxer, full CNC 30 degree rise, for 31.8 bar bore
TIRES: Kenda Nevegal, 2.5" DH with "Stik-E" compound, butyl cap and sidewall reinforcement
WHEELSET: Rims: Mavic EX-729, welded joint with Maxtal alloy material; Front Hub: DT / Swiss FW 440 for 20 mm Axle, with centerlock; Rear Hub: DT / Swiss FW 440 for 12 mm Axle with centerlock
Les mer på [url= http://www.performancebike.com/bikes/PlatinumProductDisplayView?catalogId=10551&storeId=10052&langId=-1&categoryId=400343&productId=1078561&platinumHome=400339]GT Fury 2010[/url]
Ring meg gjerne for spørsmål på 98219498
Re: NY GT Fury 2010-Veil 70000 - Selges 30.000 - Str M [Re: Stoffer] #1385154 29/04/2012 21:05
Stoffer Offline OP
Selger for 27.500,-
