Rock Shox Argyle RC 2011 100mm - selges kr 1900,-
Rock Shox Argyle RC 2011 100mm - selges kr 1900,- #1194652 11/06/2011 07:34
Hurr Offline OP
Jeg røyk på et bomkjøp på nettet. Glemte i farten at jeg skulle ha gaffel til v-bremser og quick-release.
Om noen vil kjøpe den så slipper jeg turen på posten for å returnere den.
Dette skal være spekken:
Rock Shox Argyle RC Forks - Coil 2011 - 100mm - Purple/Grey 20mm Maxle Lite
Technologies:
• Fixed Coil: The coil spring is a simple, time-tested design with a smooth feel characterized by a linear spring curve.
• Maxle Lite: The tool-free Maxle Lite brings exceptional stiffness and durability to your ride in the lightest, easiest-to-use thru axle system on the market.
• Motion Control™: With Motion Control, forks chew up climbs with incredible efficiency while the patented lockout blowoff valve and threshold control immediately absorb any bumps along the way. An elegant design in a simple and lightweight package. Motion Control is compatible with PushLoc and PopLoc remotes.
Specifications:
• Travel: 100mm
• Weight: 2526g (5.56 lbs)
• Damping: Motion Control
• Available Springs: Coil
• Adjustments: External Rebound, Low Speed Compression, Preload
• Steerer Options: Aluminium 1 1/8"
• Crown: Forged 6061 T-6 Aluminium
• Upper Tubes: 32mm, 4130 Tapered Wall Steel, Chrome
• Lowers: Magnesium, Maxle Lite 20mm Axle, IS Disc Mount
• Maximum Rotor Size: 210mm
• Other: *Weight based on 265mm 1 1/8" steerer with Maxle Lite
Updates for Model Year 2011
• Features new Maxle Lite.
• Lighter weight.
• Argyle RC 100mm
Om du ikke liker fargen så får du en boks sortmaling til kr 60,- hos Biltema ICON_SMILE
Re: Rock Shox Argyle RC 2011 100mm - selges kr 1900,- [Re: Hurr] #1195991 13/06/2011 12:31
silverdog Offline
PM sendt!
Re: Rock Shox Argyle RC 2011 100mm - selges kr 1900,- [Re: silverdog] #1196876 14/06/2011 15:37
Hurr Offline OP
Gaffelen er solgt
