Scott Spark 10 09 mod str L
Scott Spark 10 09 mod str L #798280 26/08/2009 19:53
Ola S Offline OP
Strøken Scott Spark 10 selges nesten ubrukt. Sykkelen har snart gått 50 mil. Selges med Sigma computer og Scott flaskestativ i sykkelens farge. Vekten er kun 10,2kg! Fra hendelen på styret kan man velge mellom lock-out, midtstilling eller full vandring på bakdemperen under kjøring. Håndboken følger med. Har nettopp byttet alt av wire og strømper. Veil pris 57 999,- Må sees!
Ring for visning og prøvekjøring.
Link Scott: http://scott-sports.com/gb_en/product/2413/11712/spark_10
Pris: 35 000,-
Ola Stuveseth
ola.stuveseth@start.no
90770393
Spec:
Weight:
10.20 kg / 22.47 lbs
Frame
- Scott Spark / IMP technology / HMF net
- carbon swingarm / carbon dropouts with replaceable hanger
- sealed aircraft bearings
- 110mm rear travel
- optimised SLS kinematic
Fork
Fox 32 F120RL / Air spring
Alloy steerer / reb. adj / lockout
Quad tapered lowers / 120 mm travel
Shock (Rear)
Scott Nude TC
3 modus / LO-TC-AT
Ball joints / reb. Adj.
trac loc 2 remote control
Headset
Ritchey Pro 1 1/8“
semi integrated 44/50mm
Derailleur (Rear)
Shimano XTR RD-M972 SGS
carbon cage
Shadow Type
27 Speed
Derailleur (Front)
Shimano XTR FD-M971 / 34.9mm clamp
Shifters
Shimano XTR SL-M970
Rapidfire Plus 2
multi and 2 way release
adj. clamp
Brake Levers
Shimano XTR BL-M975 Disc
Brakes
Shimano XTR BR-M975 Disc
180/F and 160/R mm
CL RT97 Rotor
Crankset
Shimano XTR FC-M970
Hollowtech 2
44Ax32Ax22A T
BB-Set
Shimano Cartridge
shell 73mm
Handlebar
Ritchey Carbon WCS
18mm Rise / 640mm
Scott lockon grips
H'stem
Ritchey MTB WCS
4-Axis 44
oversize 31.8mm
1-1/8“ / 6° angle
Pedals
Shimano PD-M540
Clipless pedal
Seatpost
Ritchey WCS Carbon / 34.9 mm
Seat
Selle Italia SLR XP Kevlar / Vanox rails
Hub (Front)
Shimano XTR
HB-M975
Disc CL
Hub (Rear)
Shimano XTR
FH-M975
Disc CL
Chain
Shimano CN-HG93
Cassette
Shimano XTR
CS-M970
11-32 T
Spokes
DT Swiss
Super Comp
black
Rims
DT Swiss
4.2 Disc / 32H
Tires
Schwalbe Rocket Ron
26 x 2.25 / 127EPI
Kevlar Bead Evolution
triple compound
Ola Stuveseth
Lauvtjernveien
3300 Hokksund
90770393
Re: Scott Spark 10 09 mod str L [Re: Ola S] #802220 01/09/2009 10:56
Ola S Offline OP
Prisen på sykkelen er nå 33 000,-
Re: Scott Spark 10 09 mod str L [Re: Ola S] #802850 01/09/2009 20:38
W
wilfredo Offline
W
Hvilken kroppshøyde passer sykkelen til? Vet du forresten om det er mulig å få remote lockout på fremgaffel også?
Re: Scott Spark 10 09 mod str L [Re: wilfredo] #803022 02/09/2009 06:41
Ola S Offline OP
Sykkelen passer for de mellom 176-187. Det er mulig og ettermontere remote, men jeg ville ventet til neste år og heller montert scott sin twin-loc som kommer da. Da får du en kontroll som virker på begge demperene.
Re: Scott Spark 10 09 mod str L [Re: Ola S] #819532 24/09/2009 19:28
Ola S Offline OP
Pris: 32 000,-
Ola Stuveseth
Lauvtjernveien
3300 Hokksund
90770393
