Svarte messingnipler
#758518
22/06/2009 21:22
irvin
Innlegg: 253 |
Hepp.
Hvor i Norges land får jeg kjøpt svarte messingnipler?
1.8x12 eller 1.8x14
Skal parres med supercomp.
Re: Svarte messingnipler
[Re: irvin]
#758560
22/06/2009 22:30
Registrert: Sep 2001
Espen
Innlegg: 16,266 |
Det er ikke behov for messingnippel i 1.8, fordi en alunippel i 1.8 er like sterk som en messing i 2.0, og den holder som kjent meget godt.
Espen (eier av 3 hjulsett med Supercomp og 1.8 alunippel)
[Re: Espen]
#758574
23/06/2009 01:03
Hjulcompaniet
Innlegg: 1,551 |
Engineering does not work quite as simply as that, sadly. One material may be equally as strong as another in a different configuration, but that does not make the other redundant.
Lots of salt on the roads in the winter can corrode alu. badly.
If you plan to keep wheels for a long time, brass nipples will hold upto adjustments better.
Aluminium nipples are also more expensive.
[Re: Hjulcompaniet]
#758576
23/06/2009 04:25
Espen
Innlegg: 16,266 |
In theory, yes, and Brass is a better material.
In real life, I have never experienced corrotion, or problems with adjustment.
e
[Re: Espen]
#758663
23/06/2009 07:47
Hjulcompaniet
Innlegg: 1,551 |
I realized your answer was subjective, but I didn't realize it was that subjective.
I have seen corroded nipples. I have even known of wheels in storage to collapse because of it.
I have also seen more alloy nipples damaged by subsequent adjustment than brass.
There is no such thing as a better material. They just have different properties.
Compromise is made in the selection of either.
[Re: Hjulcompaniet]
#758668
23/06/2009 07:59
larsb
Innlegg: 19,900 |
Men finnes det virkelig svarte messingnippler?
[Re: larsb]
#758680
23/06/2009 08:18
Hjulcompaniet
Innlegg: 1,551 |
[Re: Hjulcompaniet]
#758748
23/06/2009 09:51
Espen
Innlegg: 16,266 |
You'r right.
Brass is a better material, and brassnipples are better than alloy nipples, but my experience with alloy is wery good, so I think they are good enough. They are lighter also.
I do'nt ride too much on salted roads. Good lubrication between spoke and nipple have made adjustments easy, even after many years.
e
[Re: Espen]
#758964
23/06/2009 15:39
JB.
Innlegg: 1,573 |
Hold deg til messing. Min mening(TM) er at alunippler er noe forbanna dritt som kun er nødvendig på ritthjul hvor hvert gram teller.
I was just riding along...
[Re: JB.]
#759049
23/06/2009 18:55
irvin
Innlegg: 253 |
Alltid flott med diskusjon, men jeg får vel ikke akkurat svar på det jeg lurer på?
[Re: syklisten]
#759212
24/06/2009 00:14
irvin
Innlegg: 253 |
Jeg er klar over alternativer i utlandet. Målet var å skaffe de fort som svint, og nei, det ender ikke opp under 200 kroner, selv med billigste frakt.
[Re: irvin]
#759227
24/06/2009 06:09
Registrert: Jun 2005
FNS
Innlegg: 288 |
Hør med Racing Depot, de importerer også litt fra DT.
Frode N
[Re: irvin]
#759241
24/06/2009 06:56
Registrert: May 2005
Vanilla Ninja
Innlegg: 6,510 |
det ender ikke opp under 200 kroner, selv med billigste frakt.  Det har ingenting å si hvor mye frakta koster. Hvis varen koster under 200 kroner skal du ikke betale mva. Hvis varen koster over 200 kroner må du betale mva på varens verdi og frakta.
[Re: Vanilla Ninja]
#760714
26/06/2009 15:03
irvin
Innlegg: 253 |
OK. Nipler bestilt. Tidligere har jeg momset på frakt, selv på varer under 200 kroner. Jeg holder deg ansvarlig, Vanilla Ninja.
