Selger min 2009 modell som kun er brukt 3 ganger. byttes pga overgang til ren downhill. En meget god stisykkel. Nypris 16000,- Selger for 12.000,-
Jeg kan nås på 98219498
Les mer på
www.mongoose.comBilde på
http://www.mongoose.com/usa/eng/mtn/Products/Mountain-Pavement/Details/2758-M9TEOE-Teocali-EliteFrame: Mongoose FreeDrive W/ 145mm travel, zero stack headset and replaceable hanger
Fork: Marzocchi 44 TST2 140 mm travel, air spring, TST 5 position compression adjust, rebound and 15 mm thru axle
Rear Shock: Fox Float RP2 XV, air spring, two position
ProPedal, extra volume air can, 200x57 mm w/ 19x8 mm hardware
Crankset: Shimano FC-M542 22/32/44T Hollowtech II
Bottom Bracket: Shimano external bearing
Pedals: Crank Bros. Smarty
Front Derailleur: Shimano Deore
Rear Derailleur: New Shimano SLX, Shadow mount
Shifters: Shimano Deore 27 speed
Freewheel: SRAM PG-950 Cassette11-34T
Chain: Shimano HG73
Rims: Mavic XM317 32 hole
Front Hub: Formula 15mm thru axle
Rear Hub: Shimano Deore disc cassette
Spokes: 14g Stainless
Brake Levers: Hayes Stroker Trail w/ tool free reach adjust
Handlebar: FSA XC-300A-OS AL6061 riser 31.8x 20x 680 mm
Stem: FSA OS-190LX 6 deg. 31.8x90mm
Grips: Mongoose Lock on
Saddle: SDG Bel Air RL cromoly rail
Seat Post: 2014 alloy post with double bolt clamp, 31.6x350 mm
