"Oldschool" Durace i Paris-Roubaix 2009
#708547
13/04/2009 11:16
Registrert: Sep 2004
aambo
Innlegg: 471 |
Ser ut som oksen fra Grimstad bruker gamle Durace skifter med utvending wire-føring http://cyclingnews.com/photos/2009/apr09...90412ispa-0154bBegynner da å lure på om den nye Durace gruppas innvending kabelføring ikke fungerer så bra.
Re: "Oldschool" Durace i Paris-Roubaix 2009
[Re: aambo]
#708568
13/04/2009 12:13
erling
Innlegg: 8,853 |
Det er flere på Cervelo som synes den gamle gruppa girer bedre og helst vil kjøre med den.
[Re: erling]
#708719
13/04/2009 18:13
Dybersh
Innlegg: 111 |
Har hørt rykter om at Thor ville ha den gamle under helvete i nord fordi den har store hendler å holde i.
[Re: Dybersh]
#708790
13/04/2009 19:26
cannondalist
Innlegg: 1,140 |
Thor med flere har kjørt med gamle 7800 i de fleste klassikerene i år. Hva som er grunnen deriomt???
[Re: cannondalist]
#708926
14/04/2009 07:05
Registrert: Mar 2002
kjull
Innlegg: 2,579 |
Fra http://www.cyclingnews.com/tech.php?id=/tech/2009/news/04-04Cervélo Test Team have a diverse range of sponsors and suppliers – including Škoda, Zipvit, 3T, Rotor, Speedplay, Castelli, fi’zi:k, 2XU, Quarq, Catlike, Elite, Nokon, Morgan Blue, Reporter and Sportblam – though one conspicuous omission is a groupset supplier. In spite of the greater financial burden, the team prefer to purchase their own for greater freedom of choice.
In fact, though the team have been running Shimano Dura-Ace groupsets this whole season, they have notably swapped generations, having first started with 7800, then switching to 7900 only to return back to 7800.
“We are using the 7800 group simply because the shifting is better on the Rotor rings,” said Campana. “We have a lot of bikes with the 7800, and we built up some bikes with the 7900, but the riders’ choice is actually to turn back to the 7800 because it shifts better.”
Rotor is the official chainset supplier but recent months have witnessed changes there as well with substitutions from both SRAM and FSA seen on some bikes at various races such as the Tour of California.
[Re: kjull]
#708986
14/04/2009 08:49
cannondalist
Innlegg: 1,140 |
[Re: kjull]
#709201
14/04/2009 14:05
Registrert: Dec 2006
beast666
Innlegg: 483 |
Hvis det er slik at de bruker Rotor Q-rings skjønner jeg at de må ha 7800 framskifteren. Framskifteren, ved bruk av Q-rings, må stå kjempelangt over største skiva, de er jo ovale. DA 7900 har jo ikke trimfunksjon på framskifter som den gamle 7800 har, noe som man må ha på Q-rings. Når det er sagt er 7900 den desidert beste framskifteren til dags dato uansett merke.
[Re: beast666]
#709204
14/04/2009 14:10
erling
Innlegg: 8,853 |
Når det er sagt er 7900 den desidert beste framskifteren til dags dato uansett merke. Kan jeg bruke den sammem med SRAM RED?
[Re: erling]
#709213
14/04/2009 14:22
beast666
Innlegg: 483 |
Når det er sagt er 7900 den desidert beste framskifteren til dags dato uansett merke. Kan jeg bruke den sammem med SRAM RED? Vet ikke men den kan ikke brukes med 7800 grep.
[Re: beast666]
#709246
14/04/2009 15:31
erling
Innlegg: 8,853 |
Kan jeg bruke SRAM RED hendler i kombo med DA7900 fremskifter? Eller blir det trøbbel med vaiertrekket.
[Re: erling]
#709262
14/04/2009 15:59
cannondalist
Innlegg: 1,140 |
MEN...Mange av gutta i highroad brukte også 7800, og de er ikke sponsa av rotor...
[Re: cannondalist]
#709293
14/04/2009 17:01
beast666
Innlegg: 483 |
MEN...Mange av gutta i highroad brukte også 7800, og de er ikke sponsa av rotor... De er ihvertfall så smarte at de bruker shimano
[Re: beast666]
#709333
14/04/2009 17:54
TAHL
Innlegg: 110 |
Så da er vel de to beste dumme da.
Siden de kjørte med Campa.
Bare for å provosere, etter at det hadde skilt seg ut 6 mann var det 2 stykker som falt (Hoste og Van Summeren kjøre inn i Flecha). Det var også de to eneste som ikke brukte Campa. Tilfeldig?
[Re: TAHL]
#709349
14/04/2009 18:13
beast666
Innlegg: 483 |
Bare for å provosere, etter at det hadde skilt seg ut 6 mann var det 2 stykker som falt (Hoste og Van Summeren kjøre inn i Flecha). Det var også de to eneste som ikke brukte Campa. Tilfeldig? Helt riktig, tilfeldig og litt heldig at noen belgiske tilskuere hadde helt diesel på avtalt sted.
[Re: beast666]
#709353
14/04/2009 18:15
beast666
Innlegg: 483 |
Bare for å provosere, etter at det hadde skilt seg ut 6 mann var det 2 stykker som falt (Hoste og Van Summeren kjøre inn i Flecha). Det var også de to eneste som ikke brukte Campa. Tilfeldig? Helt riktig, tilfeldig og litt heldig at noen belgiske tilskuere hadde helt diesel på avtalt sted. Beklager det var ikke diesel http://www.vg.no/pub/vgart.hbs?artid=552551
[Re: beast666]
#709504
14/04/2009 20:35
Registrert: Oct 2006
Yeti-man
Innlegg: 994 |
Når det er sagt er 7900 den desidert beste framskifteren til dags dato uansett merke. Nå ja. Jeg Synes Campa Record Titanium er bra, Shimano 600 Ultegra (6400) er meget bra osv. Frontskiftere er ikke "hokus-pokus" teknologi. Men å få det til å funke på Rotor/Biopace er ikke lett.
[Re: Yeti-man]
#709897
15/04/2009 13:41
beast666
Innlegg: 483 |
Når det er sagt er 7900 den desidert beste framskifteren til dags dato uansett merke. Nå ja. Jeg Synes Campa Record Titanium er bra, Shimano 600 Ultegra (6400) er meget bra osv. Frontskiftere er ikke "hokus-pokus" teknologi. Men å få det til å funke på Rotor/Biopace er ikke lett. Helt riktig ikke noe hokus pokus, men bare så synd at kun Shimano har skjønt at topgruppa bør være TOP OF THE LINE og ikke noe lett og ubrukelig Her er sykkelen til Franzoi med Chorus framskifter IKKE Record Og her er et lite utvalg av Sram Force framskiftere remerket med med Red merker og som vi ser Cancellara bruker Force
[Re: aambo]
#711519
17/04/2009 20:02
Pete
Popcornansvarlig
Popcornansvarlig
Innlegg: 6,409 |
Dette blir mye synsing, men jeg tror vi kan trekke opp tre hovedgrunner til at det brukes 7800-komponenter i proffritt:
1) Mange av disse gutta har 5 års erfaring (og kanskje vel så det) med 7800-serie komponenter og for ritt som Paris-Roubaix kan det vel tenkes at man safer ved å bruke "kjente og kjære" komponenter
2) Kompatibilitetsproblemer med andre komponenter: FSA, Rotor, SRM, osv. gjør at man får bedre ytelse med 7800-girdeler, girspaker og kranker. 7900-gruppa er i høyeste grad utviklet som et integrert system - på både godt og vondt - sammen funker det imponerende bra, men å blande inn tredjepartskomponenter kan gi uforutsigbare resultater
3) Tilgjengelighet: Lag som Cervelo (og tidligere CSC/Saxo Bank) kjøper Shimano-komponentene på vanlig måte og må stille seg i køen sammen med andre som vil handle. Sponsa lag som Rabobank, Columbia, Skil-Shimano og FdJ får nye varer først.
Recovery-mode
[Re: Pete]
#711628
17/04/2009 22:17
Yeti-man
Innlegg: 994 |
7900-gruppa er i høyeste grad utviklet som et integrert system - på både godt og vondt - sammen funker det imponerende bra, men å blande inn tredjepartskomponenter kan gi uforutsigbare resultater Kompabilitet har da alltid vært et fortrinn blandt komponenter (generelt).
[Re: beast666]
#711677
18/04/2009 06:57
parkprest
Innlegg: 1,560 |
Kort OT - hvilket pedalsystem er dette ?
pedalistisk !
[Re: beast666]
#713646
21/04/2009 05:57
asbjorjo
Innlegg: 901 |
Helt riktig ikke noe hokus pokus, men bare så synd at kun Shimano har skjønt at topgruppa bør være TOP OF THE LINE og ikke noe lett og ubrukelig Her er sykkelen til Franzoi med Chorus framskifter IKKE Record Måtte du lete lenge for å finne den? Jeg tok en kjapp titt på bildene cyclingnews har av sykler fra P-R, og de fleste (alle jeg gadd se på) der (inkludert Boonen og Pozzato) kjørte med Record forskiftere. Boonen kjørte riktignok på den gamle gruppa, men det ser ikke ut til å være voldsom forskjell. Nå regner jeg selvsagt med at du vet bedre enn både Boonen, Pozzato og mekanikerne deres når det gjelder TOP OF THE LINE forskiftere.
[Re: asbjorjo]
#713748
21/04/2009 08:21
Yeti-man
Innlegg: 994 |
Og så vare det (husker ikke hva han hete) SRAM Red som ikke finnes med lange krankarmer, hvor de endte opp med Rival armer i stedet. Tror ikke "top of the line" spiller så veldig avgjørende rolle dersom du snakker med sykkelisten selv eller hans mekaniker. Man tager det man haver og som fungerer. Noe annet er om du spør sponsoren...
