Side 1 av 7 1 2 3 4 5 6 7
CRC-Hva betyr dette?
CRC-Hva betyr dette? #538230 14/04/2008 20:57
Santacruz Offline OP
Måneder eller timer?
Re: CRC-Hva betyr dette? [Re: Santacruz] #538251 14/04/2008 21:38
tmork Offline
Lilloman
Lilloman
Spennende. Har en lignende selv der gls-trace viste at det var manglende papirer som gjorde at den ble liggende på tollen fra 11. til 14. Pakken min ser derimot ut til å fortsatt befinne seg i Norge *bank i bordet*, mens din visst nok er på vei tilbake til CRC.
Lillo-Connoisseur
Terje ™ coffee
Lostjenesten - Lillomarka
Re: CRC-Hva betyr dette? [Re: Santacruz] #538252 14/04/2008 21:38
Registrert: Oct 2006
MortenML Offline
Og hva med dette? Måneder eller år?
14/04/2008 19:46 NO1010 , Norway 14.61 Problem in customs clearance due to incomplete documents
11/04/2008 23:55 DK0063 Kolding, Denmark 1.0 Outbound from GLS location
11/04/2008 23:21 DK0063 Kolding, Denmark 2.0 Inbound to GLS location
11/04/2008 23:21 DK0063 Kolding, Denmark 1.0 Outbound from GLS location
11/04/2008 01:07 GB0100 , United Kingdom 1.0 Outbound from GLS location
10/04/2008 22:01 GB0100 , United Kingdom 0.0 Data transferred to GLS System
10/04/2008 22:01 GB0100 , United Kingdom 1.0 Outbound from GLS location
09/04/2008 15:10 GB0035 , United Kingdom 1.0 Outbound from GLS location
/mitch
Re: CRC-Hva betyr dette? [Re: MortenML] #538254 14/04/2008 21:42
tmork Offline
Lilloman
Lilloman
Ikke godt å si, min ser slik ut:
14/04/2008 10:30 NO1010 , Norway 15.0 Released by customs
14/04/2008 03:15 NO1010 , Norway 2.0 Inbound to GLS location
11/04/2008 14:49 NO1010 , Norway 14.61 Problem in customs clearance due to incomplete documents
11/04/2008 00:43 DK0063 Kolding, Denmark 1.0 Outbound from GLS location
11/04/2008 00:04 DK0063 Kolding, Denmark 2.0 Inbound to GLS location
11/04/2008 00:04 DK0063 Kolding, Denmark 1.0 Outbound from GLS location
10/04/2008 01:06 GB0100 , United Kingdom 1.0 Outbound from GLS location
09/04/2008 21:36 GB0100 , United Kingdom 0.0 Data transferred to GLS System
09/04/2008 21:36 GB0100 , United Kingdom 1.0 Outbound from GLS location
08/04/2008 16:45 GB0035 , United Kingdom 1.0 Outbound from GLS location
Befinner seg angivelig i Norge fortsatt.
Lillo-Connoisseur
Terje ™ coffee
Re: CRC-Hva betyr dette? [Re: MortenML] #538255 14/04/2008 21:43
perano Offline
Hvis dere vil følge pakkens ferd videre nå, må dere ringe GLS i Danmark og få oppgitt 6 eller 7 siffer som Posten bruker foran GLS-nummeret. Ser ut som om de er like rundt hjørnet og at et postbud prøver å levere på døra mens dere ikke er hjemme for deretter å levere pakken på nærmeste postkontor...
Redigert av perano; 14/04/2008 21:43.
Per Andreas
Støtt NOTS
Re: CRC-Hva betyr dette? [Re: perano] #538257 14/04/2008 21:48
tmork Offline
Lilloman
Lilloman
Det er linjen med tollproblemer som gir hodebry, og da spesielt for første taler der trace viser at den muligens har dukket opp i Danmark igjen.
Lillo-Connoisseur
Terje ™ coffee
Re: CRC-Hva betyr dette? [Re: tmork] #538266 15/04/2008 00:26
chalshus Offline
Noen er uheldige.
Jeg fikk sendt en pakke den 1. April fra Hong Kong. Fikk telefon fra posten 1830. den 7. april om jeg ville ha den tilkjørt eller hente selv. Fikk også sporingsnummeret og info om hvor mye moms jeg måtte betale. God service og bra hastighet....
Re: CRC-Hva betyr dette? [Re: chalshus] #538278 15/04/2008 06:01
stephy Offline
"11/04/2008 14:49 NO1010 , Norway 14.61 Problem in customs clearance due to incomplete documents"
Fikk denne linjen jeg også nylig, og da var problemet at CRC ikke hadde skrevet på etternavnet mitt på adresselinjen, kun fornavn. Fikk det fikset ved å ringe Posten.
Re: CRC-Hva betyr dette? [Re: stephy] #538284 15/04/2008 06:11
RazeFaze Offline
Ringe til posten? Går det an? Kan de hjelpe deg?
Snedig...et tips til flere i denne tråden det, tror jeg.
Lurer man på noe, så kan Posten ofte hjelpe hvis pakken har vært innom dem.
Happy Trails!
Jørgen
Re: CRC-Hva betyr dette? [Re: RazeFaze] #538293 15/04/2008 06:23
stephy Offline
Du må først få forsendelsnummeret fra GLS Danmark. GLS Norge er et underbruk av Posten.
Re: CRC-Hva betyr dette? [Re: stephy] #538331 15/04/2008 07:33
MortenML Offline
Noe har i hvert fall skjedd siden i går...
15/04/2008 06:17 NO1010 , Norway 2.0 Inbound to GLS location
15/04/2008 01:08 NO1010 , Norway 15.0 Released by customs
/mitch
Re: CRC-Hva betyr dette? [Re: MortenML] #538392 15/04/2008 09:35
Lapavoni Offline
Det er ikke bare jeg som sliter skjønner jeg.
Jeg ringte Posten. Det virket som om pakken var borte i hævven. De skal ringe meg når de finner den.
09/04/2008 10:28 NO1010 , Norway 8.0 Stored
09/04/2008 05:53 NO1010 , Norway 2.0 Inbound to GLS location
08/04/2008 00:36 DK0063 Kolding, Denmark 1.0 Outbound from GLS location
07/04/2008 23:02 DK0063 Kolding, Denmark 2.0 Inbound to GLS location
07/04/2008 23:02 DK0063 Kolding, Denmark 1.0 Outbound from GLS location
05/04/2008 01:10 GB0100 , United Kingdom 1.0 Outbound from GLS location
04/04/2008 21:41 GB0100 , United Kingdom 0.0 Data transferred to GLS System
04/04/2008 21:41 GB0100 , United Kingdom 1.0 Outbound from GLS location
03/04/2008 15:33 GB0035 , United Kingdom 1.0 Outbound from GLS location
Re: CRC-Hva betyr dette? [Re: Lapavoni] #538409 15/04/2008 10:07
Stein Offline
Dette kommer så og si alltid av at tollavdelingen ikke finner deg i systemet sitt, og setter pakken på lager til de har sendt deg, og fått svar på, skriftlig søknad om tillatelse til å få fortolle ting for deg.
Hvis du har gitt dem dette fra før, ringer du posten, ber om å få snakke med tollavdelingen, og hjelper dem til å finne deg og personnummeret ditt i systemet sitt, så sender de pakka videre i systemet.
Denne mølla må jeg gjennom hver gang jeg bestiller noe som er for dyrt (>1000) til at det fortolles på postkontoret. Det holder at det er ett eneste tegn i navnet som er forskjellig fra det de har registrert for at de ikke finner deg - selv om det bare er en ekstra space eller et komma.
Re: CRC-Hva betyr dette? [Re: Stein] #538457 15/04/2008 11:47
tmork Offline
Lilloman
Lilloman
Sjekk nå på egen pakke med samme statuser som vist over, var at pakka tok en tur innom lageret for grandiosa, og var nå på vei til Lillonære strøk.
Lillo-Connoisseur
Terje ™ coffee
Re: CRC-Hva betyr dette? [Re: tmork] #538461 15/04/2008 11:51
MortenML Offline
Ingen grunn til panikk ser det ut til. Har fått postens sporingsnummer og hentet ut følgende. Hva skulle vi gjort uten internett? Det er et under at vi i det hele tatt fungerte i gamle dager. ICON_SMILE
15.04.08 13.27 REGISTRERT OMLASTINGSTERMINAL 0024 OSLO
15.04.08 09.50 UTSENDT 0024 OSLO
15.04.08 09.50 Ankommet lager 0024 OSLO
15.04.08 06.17 INNLEVERT POSTTERMINAL 0024 OSLO
15.04.08 01.08 FORTOLLET 0024 OSLO
14.04.08 19.46 TIL LAGER 0024 OSLO
/mitch
Re: CRC-Hva betyr dette? [Re: Stein] #538463 15/04/2008 11:56
Lapavoni Offline
Sitat: Stein
Dette stemte. Helt utrolig. Damen jeg snakket med ordnet opp og beklaget så mye over denne mennesklige svikten. Jeg tror jaggu jeg spanderer UPS neste gang.
Takk for tipset.
Re: CRC-Hva betyr dette? [Re: Lapavoni] #538465 15/04/2008 11:58
Stein Offline
Det er strengt tatt ikke så rart. Hvis nettbutikken staver navnet ditt litt annerledes enn det posten har i sitt register, så finner ikke systemet frem. Det står jo ikke akkurat personnummer på adresselappen.
Re: CRC-Hva betyr dette? [Re: Stein] #538475 15/04/2008 12:22
Lapavoni Offline
Nå skriver da CRC ut direkte fra sin database hvor jeg selv har skrevet navnet mitt. Navnet mitt var helt korrekt stavet på pakken og damen jeg snakket med kunne ikke forstå hvorfor denne pakken ikke hadde gått igjennom.
Re: CRC-Hva betyr dette? [Re: Lapavoni] #538476 15/04/2008 12:28
supercaliber Offline
Übergrønnskolling
Übergrønnskolling
Hvor lang tid bruker CRC vanligvis på å plukke og sende ei pakke?
Before I was blind, but now I can't see...
Re: CRC-Hva betyr dette? [Re: supercaliber] #538481 15/04/2008 12:39
KTL Offline
Sitat: supercaliber
Noen timer,
Sending med UPS tar ofte mindre enn 24 timer hvis den bestilles rundt lunsjtid, slik at den går ut fra CRC på ettermiddagen/kvelden. Da har du den dagen etter.
mvh
Knut Tore
Tirsdagsklubben™
Re: CRC-Hva betyr dette? [Re: supercaliber] #538482 15/04/2008 12:40
Lapavoni Offline
Hvis de har tingene på lager så blir det sendt samme dag eller dagen etter bestilling, senest.
Re: CRC-Hva betyr dette? [Re: Lapavoni] #538499 15/04/2008 13:14
Übergrønnskolling
Übergrønnskolling
Hmm bestilt fredag kl 1944 og det står Processing fremdeles..
Re: CRC-Hva betyr dette? [Re: supercaliber] #538501 15/04/2008 13:19
Lapavoni Offline
Da vil jeg tro at det er noe som ikke er på lager, men som kommer inn i løpet av kort tid. Slik var det med meg i hvertfall. Send dem en mail og spør om hva som skjer.
Re: CRC-Hva betyr dette? [Re: Lapavoni] #538504 15/04/2008 13:21
RazeFaze Offline
Om ting er "in stock" eller ikke ser man jo ved bestilling. Er i hvertfall greit å være klar over at ting tar lenger tid om ting ikke er "in stock". De deler såvidt jeg vet ikke opp bestillinger.
Happy Trails!
Jørgen
Re: CRC-Hva betyr dette? [Re: RazeFaze] #538510 15/04/2008 13:27
Übergrønnskolling
Übergrønnskolling
Jeg valgte bare ting som var på lager, men etter at jeg fikk ordrebekreftelsen står det at to av varene ikke er på lager. Bummer..
Re: CRC-Hva betyr dette? [Re: supercaliber] #538511 15/04/2008 13:28
Stein Offline
Lurt å passe på at det fremdeles er "in stock" etter at du har lagt varene i kurven. Hvis det er noe du skal ha 2 stk. av, og de kun har 1 stk på lager, er det f.eks. lett å gå i den fella.
Re: CRC-Hva betyr dette? [Re: Stein] #538523 15/04/2008 13:52
Übergrønnskolling
Übergrønnskolling
En eller annen felle har jeg tydeligvis gått i.
Har jo unnlatt å bestille varer jeg kunne trengt utifra at de ikke var på lager og bestilt ekspress levering fordi jeg var litt utålmodig..
Men når Rabbagast kan vente 20 år på å punktere ICON_LAUGH (grattis) så skal jeg vel klare å smøre meg med et par lag med tålmodighet.
Re: CRC-Hva betyr dette? [Re: supercaliber] #538796 16/04/2008 07:37
En telefon til GLS, og feil funnet. Pakken er for stor for transportbåndet. De sender ikke før de får mer spenn fra CRC. Dette blir spennende.
Re: CRC-Hva betyr dette? [Re: Santacruz] #538797 16/04/2008 07:44
EgilS Offline
Kan de ikke da bære pakken gjennom lokalet?
Re: CRC-Hva betyr dette? [Re: EgilS] #538806 16/04/2008 08:03
KTL Offline
Sitat: EgilS
Det må eventuellt klareres med HMS-ansvarlig, klubben og bedriftshelsetjenesten, og dermed er det nok kjappere å få mere penger fra CRC -de vil jo kundens beste!
mvh
Knut Tore
Tirsdagsklubben™
