FOX VAN 36 RC2 2006 !!!!!!!!
FOX VAN 36 RC2 2006 !!!!!!!! #523755 10/03/2008 19:31
vvovva Offline OP
HI
I HAVE FOX VAN 36 RC2 2006 FOR SALE!!!!
Description:
Weight 2.47 kg
Travel 6.3 inches/ 160 mm
Adjustments
• Coil spring preload
• Rebound
• Low speed compression
• High speed
compression
• Position sensitive
damper
Lower Legs
Disc Only
20mm Axle
Spring Coil
Features
• Proprietary adjustable position sensitive damper
• Stepped 20mm thru-axle: Allows lower leg to settle into a lower
friction point
• Standard 1 1/8" steerer
• Integrated disc brake guide
Tired of pedaling that heavy freeride fork to the top of your favorite ride? Longing for some bar spinning freedom at the resort? Look no further than the 36 VAN. Boasting oversized 36mm upper tubes, FOX's proprietary position sensitive damper, 160mm of travel, and a super plush coil spring - the 36 VAN is ready for serious abuse. But don't let its stature fool you, at 5.5 pounds the 36 VAN will help you fly both up and down the hill.
PRICE IS 4500 NKR ( PRICE IS TO NEGOTIATE)
FOR MORE INFOS OR PICS CONTAKT ME:
MSN barrettki@wp.pl OR CALL 99876511
Re: FOX VAN 36 RC2 2006 !!!!!!!! [Re: vvovva] #546916 02/05/2008 19:03
vvovva Offline OP
SOLD
Re: FOX VAN 36 RC2 2006 !!!!!!!! [Re: vvovva] #546920 02/05/2008 19:13
Ripen Offline
Cool avatar! L.O.A. Rocks!!
Roy
Re: FOX VAN 36 RC2 2006 !!!!!!!! [Re: Ripen] #551986 13/05/2008 16:58
vvovva Offline OP
SOLD!
