From Slopes to Singletrack, the 36mm Van can do it all. The RC2 patent-Pending Position Sensitive Damper has a FIT Cartridge, 36mm Stanchions and a 20mm Stepped Thru-Axle. Add to this Separately-Adjustable High and Low-Speed Compression Damping Circuits, Adjustable Rebound, and a healthy 160mm of Coil-Sprung Travel and you have a Fork which can handle anything you can throw at it. From Huge Air (with Hard Landings) to Trail Trashing & Stutter Bumps, the 36mm Van sucks it all up and makes the World Smooth. The steer tube in uncut.
For All Mountain, Downhill & Freeriding Travel: 6.3" (160mm) FIT Damping Coil Spring External Coil Spring Preload Adjustment External Rebound Adjustment External Low-Speed Compression Adjustment External High-Speed Compression Adjustment Internal Hydraulic Bottom-Out Adjustment Standard 1 1/8” Steerer Weight: 5.53 lbs (2.51 kg)
Colour: Black
contact me: MSN barrettki@wp.pl or just call 99876511 best offer takes it good luck
hi! yesterday i wrote a leter 2 official fox dealer in norway. so i hope today they send me a price list. do u know any online shops where i can check price? than i will tell u how much i want and we can make deal! do u have msn? mine is barrettki@wp.pl i stay in contact and thx for show interesting
3 weeks ago i bought a similar fork for nkr. 2800,- - used
"Der er nogen, der aldrig laerer at forstaa, at der er noget meget stort og meget stolt i et gigantisk nederlag" - Ole Ritter http://sykkel.hasle-loren.no/
ok tommorow i make some pics in daylight and send it to u. what i can say, fork is brand new and still in plastic bag. uncut. u can pick it up from Tromso.
