Som ny og strøken Rock Shox Monarch RT selges, kun brukt 5 timer. Tatt av en Kona Process 111 2017, MED tune- se bilde.
Selges 1500.-kr inkl. frakt
Specifications for Monarch RT WEIGHT 215g DAMPING External rebound, 2 position compression (Open/Pedal) CONFIGURATIONS 184x44mm REBOUND DAMPING Rapid Recovery SPRING Standard, High Volume, Standard with High Volume Eyelet, High Volume with High Volume Eyelet SPRING ADJUST Air pressure via single schrader valve SHAFT MATERIAL 7075 aluminum SHAFT DIAMETER 9mm BODY MATERIAL Hard anodized, forged aluminum with sag gradients BODY FINISH Fast Black UPGRADE over R: Threshold
Re: Strøken Rock Shox Monarch RT 184x44mm
[Re: rage]
#249343124/06/201819:54
