Specialized Stumpjumper FSR Expert Carbon EVO Str M
Specialized Stumpjumper FSR Expert Carbon EVO Str M #2419101 04/07/2017 09:04
Registrert: Dec 2007
Vole. Offline OP
Stumpjumper FSR Expert Carbon EVO 2014 Str M Kr 25000,-
Oppgradert med Chris King Bottom bracket, Fox Transfer Factory 150,Rental Fatbar Carbon 780mm og Race Face narrow wide 28T krankdrev og 77 designz crash plate. Magic Mary og Ardent dekk satt opp slangeløst.
Kan selges uten Fatbar og Transfer mot reduksjon i pris.
Av en eller annen grunn får jeg ikke lagt ut bilder,så hær er en lenke til Specialized sine sider.
https://www.specialized.com/no/en/bike-a...arbon-evo/49732
Ska få ut bilder når jeg har tilgang til en pc.
Technical Specifications
FRAME
FACT 9m carbon front triangle, EVO geometry, FACT IS construction, M5 alloy rear triangle, tapered headtube, carbon PF30 BB, ISCG ’05, internal Command Post IR routing, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 150mm travel
SWAT
Bottle cage, EMT Tool, and Top Cap Chain Tool w/ SWAT Technology
REAR SHOCK
Custom FOX Float CTD Factory w/ AUTOSAG and Boost Valve, Kashima coating, Climb, Trail, Descend settings and reb adj., 195x51mm
FORK
RockShox RC, Solo Air spring, tapered alloy steerer, comp, lockout, and reb adj., 15mm thru-axle, 150mm travel
HEADSET
1-1/8 and 1-1/2" threadless, Campy style upper with 1-1/2" lower, cartridge bearings
STEM
Specialized Trail, 6061 alloy, 4-bolt, 6-degree rise, 31.8mm clamp
HANDLEBARS
Specialized All-Mountain, low-rise, 7050 alloy, 750mm wide, 8-degree backsweep, 6-degree upsweep, 31.8mm
GRIPS
Specialized Sip Grip, light lock-on, half-waffle aramid-infused, S/M: regular, Others: XL thickness
FRONT BRAKE
Custom Avid Elixir 7 Trail, 4-piston caliper, steel backed metallic pad, S/M: 180mm, Others: 200mm rotor
REAR BRAKE
Custom Avid Elixir 7 Trail, 4-piston caliper, steel backed metallic pad, S/M: 160mm, Others: 180mm rotor
BRAKE LEVERS
Custom Avid Elixir 7 Trail, hydraulic disc, tool-less reach adj.
FRONT DERAILLEUR
REAR DERAILLEUR
SRAM X01, 11-speed, mid cage
SHIFT LEVERS
SRAM X01, 11-speed, trigger
CASSETTE
SRAM X01, 11-speed, 10-42
CHAIN
SRAM, 11-speed, hollow plates/pins, PowerLink
CRANKSET
Custom SRAM carbon S-2200, custom XX1 style ring, PF30 spindle, removable spider, S: 170mm, Others: 175mm
CHAINRINGS
BOTTOM BRACKET
SRAM PF30, OS press-in bearings, sealed cartridge
PEDALS
RIMS
Roval Traverse, alloy disc, 24mm internal width, 27h/32h
FRONT HUB
Roval Traverse, 15mm thru-axle end caps, 27h
REAR HUB
Roval Traverse 142+, XX1 driver body, 12mm thru-axle, 32h
SPOKES
DT Swiss Super Comp, 2.0/1.65/1.8 stainless
FRONT TIRE
Specialized Butcher Control, 2Bliss Ready, 26x2.3", foldable aramid bead, 60TPI
REAR TIRE
Specialized Purgatory Control, 2Bliss Ready, 26x2.3", foldable aramid bead, dual-compound, 60 TPI
INNER TUBES
SADDLE
Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
SEATPOST
Specialized Command Post IR, 3-position, internally routed adjustable height w/ air spring, remote operated, single bolt head, 30.9mm, S:100mm, Others: 125mm travel
SEAT BINDER
7050 hard anodized alloy, single bolt, 34.9mm
Kom til Lom!
Re: Specialized Stumpjumper FSR Expert Carbon EVO Str M [Re: Vole.] #2420067 08/07/2017 21:49
Vole. Offline OP
Kom til Lom!
Re: Specialized Stumpjumper FSR Expert Carbon EVO Str M [Re: Vole.] #2420880 12/07/2017 23:23
Vole. Offline OP
Det er lov å komme med bud :-)
Kom til Lom!
Re: Specialized Stumpjumper FSR Expert Carbon EVO Str M [Re: Vole.] #2428548 12/08/2017 12:15
Vole. Offline OP
Ny pris: 22000,-
Kom til Lom!
Re: Specialized Stumpjumper FSR Expert Carbon EVO Str M [Re: Vole.] #2435403 04/09/2017 15:00
Vole. Offline OP
Ny pris: 20000,-
Kom til Lom!
Re: Specialized Stumpjumper FSR Expert Carbon EVO Str M [Re: Vole.] #2496220 07/07/2018 12:42
Vole. Offline OP
Solgt.
Kom til Lom!
