Side 80 av 132 1 2 78 79 80 81 82 131 132
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: Øyvind V] #1912939 17/01/2015 21:05
rasmusic Offline
Sitat: sveinaa
Vil man få betalt for å kjøre intervaller pa rulla i bukken?
JA!
Sitat: Øyvind V
Liker Eddy Merxx-tempo best jeg; da slipper man å havne så innmari langt bak gutta med full temporigg. Er jo dårlig for motivasjonen ICON_SMILE
Så 45 sekunder på mila er ikke langt bak når vi har nesten lik w/kg? ICON_TONGUE
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: EmilZipp] #1912944 17/01/2015 21:14
Hoaas Offline
Sitat: EmilZipp
snev av avsporing i denne tråden, men hvor stor forskjell er det på:
1) konkurranse landeveissykkel (ex supersix) m høyprofil hjul og vanlig hjelm
2) samme sykkel som 1 men med tempo-styre-klips
3) temposykkel m platehjul (ex slice), hakkespetthjelm og full pakke
.... I en tempoløype, gjerne målt i spart tid
"They were lucky to have near ideal conditions for the outdoor tests, which kept the measurement errors down to around two percent of total power. The corresponding errors in the wind tunnel are under one percent. From doing this, they found the outdoor testing validated the wind tunnel testing, but did not replicate it.
They also found that outdoors there was a 60-70 watt saving at 40km/h between the normal road bike setup, which required 280-290W at this speed, and the full time trial setup ( 220W). That worked out at between 22-24 percent in aerodynamic savings.
To put it another way, it was nine seconds per kilometre, 2'14 per 10 miles (16.1km), 5'33 per 40km, and 24'58 over 180.2km, the distance of the bike leg in an Ironman triathlon. Or another way, if you can ride a road bike at 40km/h and switch to a time trial bike and helmet, you can do over 44km/h."
Anbefaler å lese denne: http://www.bikeradar.com/road/gear/article/how-aero-is-aero-19273/
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: rasmusic] #1912950 17/01/2015 21:45
Øyvind V Offline
Sitat: rasmusic
Sitat: Øyvind V
Jo. Men du kommer jo fra en annen planet, så jeg sammenligner ikke med dine prestasjoner ICON_SMILE Er bedre å bli nr 8-9 på Eddy-tempo enn 30 på vanlig tempo.
Edit: "Bedre" i forhold til motivasjon, og mulighet til å sammenligne med andre, mener jeg. Ikke bedre prestasjonsmessig.
Redigert av Øyvind V; 17/01/2015 22:02.
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: rasmusic] #1912973 17/01/2015 23:15
sveinaa Offline
Finnes det et sete som er smalt, som ikke flexer for mye på midten (lite nedbøy,?) og som man i tillegg kan sitte på hele setet( lengderetning )?
Redigert av sveinaa; 17/01/2015 23:16.
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: sveinaa] #1913045 18/01/2015 11:43
Hoaas Offline
Specialized Sitero? Egner seg egentlig bare til tempo, vet ikke om det var det du var ute etter.
Redigert av Hoaas; 18/01/2015 11:44.
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: Hoaas] #1913439 19/01/2015 16:03
sveinaa Offline
Sitat: Hoaas
Nei ikke helt det. Litt usikker på hva jeg må ha. Har syklet mye med DDK sadel og det funker bra på terreng, i alle så lenge man kan sitte oppreist, og ikke må legge seg ned for da stopper blodtilførselen nesten momentant.
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: grr] #1913695 20/01/2015 10:38
Registrert: Feb 2013
Steinth Offline
Hei,
et spørsmål til sone 1 ekspertene. ICON_SMILE
Hva er den egentlige forskjellen i treningseffekt på sone 1 og sone 0? (Definerer sone 0, til under 60% HF)
Kan jeg like greit bytte en sone 1 økt, til sone 0 økt og oppnå det samme?
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: grr] #1913716 20/01/2015 11:17
Hoaas Offline
Sone 0 er vel primært restitusjonstrening, få blodsirkulasjon i muskulaturen osv. Treningseffekten er svært lav i sone 0, men bare mengdene er store nok går jo det meste. Vet av godt trente folk som har økt o2-opptaket ved å gå hver dag, men her snakker vi 12 timer for dagen.
Så skal du trene i 1-8 timer ville jeg nok holdt meg i sone 1.
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: grr] #1914109 21/01/2015 08:14
Kriss Offline
Plukka laktatmåleren opp fra støvet i går for å teste før jeg selger den.. Første hardøkt siden juli og 4x8 etter "så hardt jeg greier og holde samme watt på alle draga prinsippet".
Laktat etter endt drag: 5,6 - 8 - 6,5 og 8,5.
Dere som skal ha full kontroll regner jeg med måler laktat også i tillegg til watt og puls for at det skal bli riktig.. ICON_WINK
Så hva bruker dere å ha i laktat etter slike drag?
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: Kriss] #1914111 21/01/2015 08:17
Øyvind V Offline
Laktat tar jeg på følelsen ICON_WINK
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: Øyvind V] #1914113 21/01/2015 08:23
Kriss Offline
Sitat: Øyvind V
Hallo! Kan jo ikke slå sammen to lissom.
Følelsen er viktig, men laktat må måles, watt må måles (med skikkelig wattmåler, ikke sånn jukse tacx watt), og puls må måles, hvis ikke har man jo ikke kontroll og da blir det jo ikke optimalt..
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: Kriss] #1914118 21/01/2015 08:40
Øyvind V Offline
Jeg har lært nå, vettu. Kjører på følelsen, så hardt dagsformen tillater. Så får det bli som det blir ICON_SMILE
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: Øyvind V] #1914137 21/01/2015 09:23
tore14 Offline
Det må da finnes en treningsklokke som har både laktatmåling og følelse!
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: grr] #1914139 21/01/2015 09:26
Hoaas Offline
Den burde ta med aerobic decoupling også, i tillegg til smiley eller surmunn (følelse). Klokke med permanent veneflon burde ikke være noe problem.
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: Kriss] #1914153 21/01/2015 09:44
hrukin Online
Sitat: Kriss
Siden det ofte blir henvist til OT soner, her er noe laktatgreier
Redigert av hrukin; 21/01/2015 09:46.
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: hrukin] #1914158 21/01/2015 09:51
Kriss Offline
Sitat: hrukin
Sitat: Kriss
Har sett den, føltes ikke helt som sone 5 akkurat så derfor jeg lurte på om noen har erfaringer med målinger etter forholdsvis harde drag..
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: Kriss] #1914172 21/01/2015 10:14
Kruser Offline
Jeg hadde 6,7 i laktat på slutten av 3. draget i en 4x8 økt med svakt stigende intensitet på draga (2 minutt pause).Pulsen var da også inne i sone 5.
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: grr] #1914181 21/01/2015 10:32
EHAa Offline
Personlig liker jeg å trene litt enklere enn dette, men jeg ønsker også gjerne å lære litt;) Derfor legger jeg ut dette, for å høre hva andre tenker.
Når man er over terskel, vil vel melkesyre akkumuleres over tid. Jeg regner med at disse harde 8-minutterene må være over terskel. Det vil si at jo lengre man kjører på en gitt intensitet, jo høyere blir laktatverdiene. (Inntil man tvinges til å senke intensiteten, går tom for drivstoff, får krampe eller liknende).
Målet med økta til Kriss var å kjøre et visst antall drag, på så jevnt høy intensitet som mulig. Økta er for kort til at man "går tom" eller liknende. Det vil si at han antakeligvis vil stoppes av at han når "smerteterskelen sin", altså "blir stiv". Det skal han etter planen gjøre på det siste draget.
Jeg forstår ikke hvordan man kan unngå å havne i laktatsone 5 med denne planen for økta, gitt at man er over terskel. Hvis han hadde 4,5 i laktat på siste drag ville han sikkert ikke følt at det var veldig ubehagelig, og logikken bak treningen ville da sagt: "Kjør hardere".
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: EHAa] #1914190 21/01/2015 10:47
Hoaas Offline
Sitat: EHAa
Men får man riktig belastning om man kjører med så høye verdier? Selv om pulsen kanskje sier i4?
Jeg hadde lav i4 puls på slutten av et 20min i4 drag i går, men jeg hadde en rævva dag, kjente syra bygge seg opp allerede i sone 2, så sleit rett og slett med å komme meg gjennom sone 3. Pulsen min sa at dette ikke var så hardt, følelsen sa at dette var steinhardt, laktat ville nok bekreftet følelsen. Hva blir mest korrekt å se på ifht belastning?
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: Hoaas] #1914198 21/01/2015 10:55
EHAa Offline
Jeg aner ikke hva som er "best" å bruke som "fasitparameter". Antakeligvis er det ikke så farlig, bare man har et nogenlunde bevisst forhold til fordeler og ulemper med de ulike måtene å styre intensitet på. Jeg tenker bare at på relativt korte drag over terskel, må man jo kjøre seg stiv med en slik logikk. Og for å unngå sarkastiske kommentarer: Nei, jeg sier ikke at jeg tror det er farlig å trene med syre i januar. (Jeg gjør det selv også, uten at det skal tolkes som et kvalitetstegn).
Når stopptegnet er "jeg klarer ikke hardere", og man er over terskel, da må det vel være syra som stopper deg fra å tråkke hardere til slutt? Og da må man jo nødvendigvis få høye målinger?
Redigert av EHAa; 21/01/2015 10:57.
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: Kriss] #1914212 21/01/2015 11:15
sveinaa Offline
Sitat: Kriss
Sitat: Øyvind V
Jeg har merket at jeg bryr meg mer og mer om hva en wattmåler kunne gjort for meg. Har derfor brukt mye tid på å tråle nettet. Om Stages ikke er på ønskelisten. Hva finnes der ute som ikke koster skjorta og går rett på et BSA lager?
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: Hoaas] #1914214 21/01/2015 11:17
sveinaa Offline
Sitat: Hoaas
Sitat: EHAa
Når du skal trene hver dag må du ned på intensiteten når det er rolig. Tipper dette ordner seg dersom du setter sykkelen bort en dag og tar en hviledag ICON_SMILE
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: Kriss] #1914216 21/01/2015 11:19
sveinaa Offline
Sitat: Kriss
Hadde du lenger pause mellom dra 2 og 3?
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: sveinaa] #1914220 21/01/2015 11:25
Hoaas Offline
Hadde rolig langtur på ski på søndag og hviledag mandag, men mulig forrige uke sitter i, med i4 5x6 mandag, skirenn onsdag og i3 langdrag lørdag. Blir nok et par rolige dager nå, ja, lade litt opp til Tour of sufferlandria som starter på lørdag ICON_SMILE
Men spørsmålet var ikke relatert til meg, det var genuin interesse for hva som kanskje gir det beste bildet på belastningen du kjører.
Redigert av Hoaas; 21/01/2015 11:25.
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: Kruser] #1914232 21/01/2015 11:46
Kriss Offline
Sitat: Kruser
Pulsen var ikke i sone 5 nei.
Så tabellen stemte dårlig når det gjelder forholdet puls/laktat..
Puls:
Drag 1: snitt 150 maks 157
Drag 2: snitt 156 maks 165
Drag 3: snitt 160 maks 170
Drag 4: snitt 164 maks 174
Følt intensitet: greide akkurat og holde samme watt på alle draga, men ikke uten kamp.
Målt terskel i lab tidligere har gitt meg terskel på alt fra 166 til 173. 166 føles mest riktig nå for tiden, men har jo også kjørt 3-4 timers ritt med høyere snittpuls enn 170.
Uansett veldig høye laktatverdier syns jeg.
Skulle jeg kjørt drag med laktatmåler og holdt meg under 4 hadde jeg jo surra rundt på "tomgang" virker det som..
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: sveinaa] #1914234 21/01/2015 11:49
Kriss Offline
Sitat: sveinaa
Sitat: Kriss
Nei, 3 min pauser..
Men stemmer med følelsen. Drag to føltes verre enn drag tre.
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: Kriss] #1914235 21/01/2015 11:50
Hoaas Offline
Sitat: Kriss
Sitat: Kruser
Puls:
Var det ikke en som skrev her inne tidligere om laktattest med virus i kroppen? Opplevd intensitet var lav, med produserte store mengder syre likevel. Pulsen hans spratt fort opp til sone 3, men så gikk den jevnt oppover. Målte også 4 i laktat lenge før han opplevde det som særlig intensivt.
Defekt laktatmåler? ICON_WINK
Redigert av Hoaas; 21/01/2015 11:51.
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: Hoaas] #1914237 21/01/2015 11:52
sveinaa Offline
Dette blir ikke vitenskapelig, men jeg tror det er lurt å kjøre på erfaringstall og følelse (Man endrer ikke form rett over natta uten at noe er galt.). Kroppen er ikke en maskin og den vil ikke alltid oppføre seg på lik måte på lik intensitet. Tror det er så enkelt som at om man har pint seg gjennom en hardøkt med tunge ben så må man ha pause for å hente seg inn igjen.
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: Hoaas] #1914240 21/01/2015 11:53
Kriss Offline
Sitat: Hoaas
Sitat: Kriss
Sitat: Kruser
Puls:
Tror ikke det.. Hadde 1 før start så det stemmer jo bra.. Følelsen syre opp til øra stemte også bra. ICON_SMILE
Og ikke virus..
Men skal man kjøre "syrefritt" etter laktatmåleren så blir ikke mye til tråkk ser det ut til.. ICON_WINK
Re: Øke utholdenheten, er virkelig sone 1 veien å gå? [Re: sveinaa] #1914244 21/01/2015 11:58
Hoaas Offline
Sitat: sveinaa
Rare er at beina kjennes bedre ut i dag enn de gjorde før økta i går ICON_WINK Hadde nok muligens en ræva dag, sov litt dårlig siden kjerringa snorka så jævlig, hehe!
Ellers enig i det du skriver ICON_SMILE
