GT Force Carbon Pro, 2013, strl L
GT Force Carbon Pro, 2013, strl L #1687915 24/09/2013 07:01
El-Rickardo Offline OP
Raskeste sykkelen i klasse M 30-34 i TSR 2013 ICON_SMILE
Fin-fin sykkel i kjempeform og rett fra stor service hos Beach Mountain. Lynrask oppover, bortover og nedover. Høyt krankhus, så ingen uventede islag i store steiner. Perfekt all mountain sykkel, veldig effektiv oppheng og tar deg lett opp til der nedovermoroa begynner.
Jeg er 183 cm over havet og L passer meg fint, geometri vedlagt.
Spec (100% orginal):
Ramme: F.O.C. AM™ Carbon Frame, 150mm Travel Independent Drivetrain™ Suspension System w/ Forged Linkage, Pivots, and BB Shell, Replaceable 142 x 12mm Shimano E-Thru Dropouts and 1 1/8" to 1 1/2" Tapered Head Tube
Gaffel: Fox Racing Shox 32 Float 26 CTD FIT w/Adjust Kashima, 150mm Travel, FIT Damper, w/ Adjustable Rebound & Compression, Lockout, & Tapered Alloy Steerer
Bakdemper: Fox Racing Shox Float CTD BV Adjust Kashima, 7.5"x2" Air Shock, w/ Rebound Adjust & Lockout
Kjede: KMC X10
Krank: RaceFace Next Carbon, 36/24T, 2x10
Kranklager: RaceFace X-Type
Krankgir: Shimano Deore XT, FD-M785
Bakgir: Shimano XTR Shadow Plus, RD-M958-GS
Triggere: Shimano XTR, SL-M980, Rapid Fire
Kasset: Shimano Deore XT, CS-M771, 10-Speed, 11-36T
Hjulsett: Easton EA70 XCT
Dekk: Maxxis Ardent, 26"x2.4", Folding Bead
Bremser: Formula R1, w/ Alloy Carrier 180mm Rotor
Styre: RaceFace Six-C Carbon Riser, 725mm Width, Low Rise, 31.8mm Clamp
Stem: RaceFace Turbine, 1-1/8" Threadless, 31.8mm Clamp
Styrelager: FSA Orbit C-40-ACB, 1.5" to 1-1/8" Tapered, Integrated
Sete: WTB Silverado Race SL w/ Cromoly Rail
Setepinne: RockShox Reverb, 125 mm. Height Adjust w/ Hydraulic Remote
Prisantydning 24 000,- (Nypris 49 995,-), uttatt april 2013 og ikke syklet på siden august.
Kan ses og prøves i Oslo, kjøper betaler evt. frakt.
//Rickard
nifemsyv-nullnull-seksniåtte
Re: GT Force Carbon Pro, 2013, strl L [Re: El-Rickardo] #1689275 26/09/2013 07:16
Bump, denne vil ut i skogen og leke igjen :-)
Re: GT Force Carbon Pro, 2013, strl L [Re: El-Rickardo] #1692574 02/10/2013 10:24
Opp!
Re: GT Force Carbon Pro, 2013, strl L [Re: El-Rickardo] #1693286 03/10/2013 13:07
22 000,- røverpris for supersprek sykkel ICON_SMILE
