En Force LE som GT har brukt som demosykkel sommeren 2013 er nå til salgs. Sykkelen står i Oslo, og er godt vedlikeholdt. Den er utstyrt med Fox Suspension sine ID tags på gaffel/shock, for enkel tuning av oppsett.
Dette er en rå racingklar enduromaskin som inviterer til å dra på, og som aldri vil være den som setter begrensninger for deg. Pinkbike skrev bl.a. i sin test:
GT's Force LE has a distinct personality that plays well to a hard-charging rider who has no problem throwing a bike around to obtain immediate results. Dan Atherton proves that in the hands of the right rider, the Force LE can be a screaming fast bike - but you have to be that special person to take full advantage of its attributes. The Force LE is well appointed for high-performance Enduro and all-mountain use, so outside of tuning the suspension to your liking and ditching the rear tire for something like a Minion, there are few, if any modifications that will significantly alter its performance or its personality. [...] If you are a point-and-shoot rider who makes motorcycle noises while smashing corners, GT's Force LE could be perfect for the job.-
Oppsett:Ramme: Monocoque/Hydroformed XM Metal™ Frame (TT/DT,ST), 150mm Travel Independent Drivetrain™ Suspension System w/ Forged Linkage, Pivots, and Bottom Bracket, Replaceable 142 x 12mm Shimano E-Thru Dropouts, 1 1/8" to 1 1/2" Tapered Head Tube w/ TT and DT gussets
Gaffel: Fox Racing Shox 34 Float 160 RLC FIT, 160mm Travel, fit damper, 20x110mm Thru Axle, w/ Adjustable Rebound & Compression, Lockout, & Tapered 1.5"--> 1-1/8" Alloy Steerer
Bakdemper: Fox Racing Shox Float CTD BV Adjust, 7.5"x2" Air Shock, w/ Rebound Adjust & Lockout
Kjede: KMC X10
Krankarmer/drev: RaceFace Turbine, 36/24T w/ Bashguard
Kranklager: RaceFace X-Type
Framgir: Shimano Deore XT, FD-M785
Bakgir: Shimano Deore XT Shadow Plus, RD-M786-GS
Skiftere: Shimano Deore XT, SL-M780, Rapid Fire
Frikrans: Shimano Deore XT, CS-M771-10, 10-Speed, 11-36T
Felger: Easton Haven Wheelset
Dekk: Maxxis Ardent, 26x2.4" Folding Bead & Exo Protection i front, Maxxis Minion DHF 2.35 Super Tacky bak
Framnav: Easton Haven Wheelset
Baknav: Easton Haven Wheelset
Eiker: Easton Haven Wheelset
Bremser: Formula T1, w/ Alloy Carrier 180mm Rotor
Hendler: Formula T1 w/ TFRA & FCS
Styre: Kore OCD-TR, Triple Butted AL7050, 740mm Width, 15mm Rise, 31.8mm
Stem: Easton Haven
Holker: GT Wings w/ Waffle Lock-on
Styrelager: Cane Creek Angleset EC44xEC49 w/ +/- 1° Offset Cup
Sete: WTB Silverado Race SL
Setepinne: RockShox Reverb, Height Adjust w/ Hydraulic Remote
Kan sees i Oslo.
Send PM for spørsmål og kontaktinfo.
Pris: 20.000
