Mongoose Boot'R 2010 str.L blir vurdert selt grunna skade og overgang til stisykkel. Bra stand. Prisant. 14.000. Nye pedalar (Fire Eye Pedals Flat PJ Pedals 2011 Black), girskifter (S-ram X.9 9speed) og steve peat holker. Elles likt utstyr som originalt lista opp nedanfor.
Original utstyrliste: Frame: New Mongoose FreeDrive DH 210mm travel and 150mm Maxle drops Fork: Rock Shox Boxxer Race 200 mm travel, rebound, compression and preload adjust, 20 mm Maxle thru axle Rear Shock: Fox Van R rebound and preload adjust, 241x76 mm w/ 19x8 mm hardware Bottom Bracket: VP square taper Shifters: SRAM X.7 9 speed Chain: KMC X9 w/ Missing Link connector Front Derailleur: N/A Rear Derailleur: SRAM X.9 medium cage Rims: SUN MTX-31 32 hole Hubs: Formula sealed bearing 20mm thru axle Tires: Kenda Excavator DH w/ Stick-E rubber 26X2.5 Pedals: Funn melt forged with 3M mini panel and replaceable pins Handlebar: Funn Full Bore triple butted AL7075 riser, 25.4x50x710 mm Stem: FUNN RSX 25.4x45 mm direct attach for Boxxer, CNC alloy Headset: FSA Orbit Z 1.5 Flush Fit, reduces 1.5 head tube to 1 1/8" fork Brake Levers: Tektro XL-750, hinged (rear only) Spokes: DT Champion 14G stainless Grips: Mongoose Lock on Saddle: Custom Mongoose SDG Bel Air I-Beam Seat Post: SDG I-Beam 2014 alloy, 31.6x250 Seat Clamp: Alloy w/ QR Extras: E.13 LG1alloy back plate ISCG05 chainguide w/ Taco bash guard, Rock Shox Maxle
