Side 1 av 3 1 2 3
Syklist fikk kjempekondis 4x4 løping
Syklist fikk kjempekondis 4x4 løping #1383496 27/04/2012 13:19
hrukin Offline OP
Har dere sett artikkelen i DN. Kan vel ikke være så mange elitesyklister på 85 kg i Norge. Jeg veier jo 95kg+ så det er ikke meg.
http://www.dn.no/dnaktiv/article2382118.ece
Re: Syklist fikk kjempekondis 4x4 løping [Re: hrukin] #1383510 27/04/2012 13:41
Torp Offline
Ser forsåvidt poenget, en toppsyklist på 85 kg har selvfølgelig kjørestyrken i orden, men skal ha ganske så bra O2 for å henge med når det drar seg til i bakkene.
Dog synes jeg det er oppsiktsvekkende at en syklist i grunntreningsperioden har 3x10 dager uten en eneste sykkeløkt. Hadde vært spennende å vite hvem dette er, og hvordan resultatene utvikler seg gjennom sesongen.
Re: Syklist fikk kjempekondis 4x4 løping [Re: hrukin] #1383511 27/04/2012 13:43
FeitSyklist Offline
Sitat: Improved VO2max and time trial performance with more high aerobic intensity interval training and reduced training volume; a case study on an elite national cyclist
The present study investigated to what extent more high aerobic intensity interval training (HAIT) and reduced training volume would influence maximal oxygen uptake (VO2max) and time trial performance in an elite national cyclist in the pre season period.The cyclist was tested for VO2max, cycling economy (Cc), and time trial performance on an ergometer cycle during one year. Training was continuously logged using heart rate monitor during the entire period. Pre season 2011 total monthly training volume was reduced compared to the 2010 pre season, and two HAIT blocks (14 sessions in 9 days and 15 sessions in 10 days) were performed as running. Between the HAIT blocks, three HAIT sessions per week were performed as cycling.From November 2010 to February 2011, the cyclist reduced total average monthly training volume by 18% and cycling training volume by 60%. The amount of training at 90-95% HRpeak increased by 41%. VO2max increased by 10.3% on ergometer cycle. Time trial performance improved by 14.9%. Cc did not change.In conclusion, pre season reduced total training volume but increased amount of HAIT improved VO2max and time trial performance without any changes in Cc. These improvements on cycling appeared despite that the HAIT blocs were performed as running. Reduced training time, and training transfer from running into improved cycling form, may be beneficial for cyclists living in cold climate areas
Re: Syklist fikk kjempekondis 4x4 løping [Re: hrukin] #1383512 27/04/2012 13:43
kitbay Offline
Kanskje det er banesyklist?
Re: Syklist fikk kjempekondis 4x4 løping [Re: hrukin] #1383514 27/04/2012 13:45
Ketle Offline
Tviler ikke på det. Mye lettere å trene intervall på beina og ta seg skikkelig ut enn på sykkel.
Re: Syklist fikk kjempekondis 4x4 løping [Re: hrukin] #1383525 27/04/2012 13:55
hrukin Offline OP
Har ikke problemer med å få opp pulsen i bakkedrag på sykkelen, trenger mao ikke løpe for det. Men jeg er jo bare en livsnyter som sykler.
Re: Syklist fikk kjempekondis 4x4 løping [Re: hrukin] #1383550 27/04/2012 14:22
Rockefoten Offline
Jeg mener det sto at han syklet som normalt, men bare kortere i denne perioden?
Har begynt å løpe litt selv og føler det "tar hardere på kondisen" på kortere tid. 30 min løping er mye hardere enn jeg klarer på 30 min sykling..
Re: Syklist fikk kjempekondis 4x4 løping [Re: hrukin] #1383582 27/04/2012 15:28
bjerkseth Offline
Jeg vet hvem dette er, og han sykler bra på både tempo og fellesstart. Ikke noen banesyklist ICON_SMILE
Instagram: @oivindbjerkseth
Re: Syklist fikk kjempekondis 4x4 løping [Re: bjerkseth] #1383586 27/04/2012 15:34
Torp Offline
Sitat: bjerkseth
Vet du hvordan effekten har vært på terskelwatten?
Og kan du bekrefte at det var snakk om 15 4x4 økter på 10 dager i hver bolk, alle på beina?
Re: Syklist fikk kjempekondis 4x4 løping [Re: hrukin] #1383618 27/04/2012 16:33
Pinello Offline
Et lite dask på lanken til dette forums store mantra: "..tren på det du skal bli god på"?
Re: Syklist fikk kjempekondis 4x4 løping [Re: hrukin] #1383622 27/04/2012 16:38
W
wirre Offline
W
Jeg kan selv verifisere at kondisen min fikk seg en skikkelig oppsving etter et jeg begynte å løpe.. Nå kan man gjerne komme å si at man får opp pulsen når man sykkle bakke intervall, MEN det er noe helt annet.. De som kommer med slike uttalelser har neppe løpt bakke intervall i fart over 6 min/km. Gå ut å prøv, så skal dere se...
Feit og i dårlig form..
Re: Syklist fikk kjempekondis 4x4 løping [Re: hrukin] #1383623 27/04/2012 16:41
olechr Offline
Jeg har trua på det selv. Hadde ikke jeg hatt knær og rygg som funker svært dårlig hadde jeg brukt løping og ikke minst spretten skigang.
Ambassadør for Scott.
Re: Syklist fikk kjempekondis 4x4 løping [Re: hrukin] #1383625 27/04/2012 16:42
Registrert: Dec 2008
Anders93 Offline
For å vite om treningskuren har vært vellykket, må man vel vise til noen resultater i sykkelritt? 02 opptak avgjør ikke alene om man vinner sykkelritt.
Re: Syklist fikk kjempekondis 4x4 løping [Re: Anders93] #1383629 27/04/2012 16:48
W
wirre Offline
W
Sitat: Anders93
Nei, det er ikke alt, men når man var som meg, som pusta å pesa som ei anpusten bikje bare jeg så en motbakke, så er det greit å få opp O2 opptaket.. Styrken i beina kommer mye lettere hvis man har brukbart o2 opptak. Jeg har som kjent kjørt løping i hele vinter, og beina var selvsagt slappe de første sykkel øktene, men det skulle ikke mere til en 5-6 økter før de var i gang!
Re: Syklist fikk kjempekondis 4x4 løping [Re: hrukin] #1383631 27/04/2012 16:52
Jacobsen Offline
Dette overrasker meg ikke i det hele tatt. På sykkel skal det mye til for å slite meg ut kondisjonsmessig i like stor grad som ved løping.
Re: Syklist fikk kjempekondis 4x4 løping [Re: wirre] #1383633 27/04/2012 16:55
Anders93 Offline
Enig i at det sikkert er smart å fokusere på O2 intervaller når sykkelformen ikke er på topp i utgangspunktet. Men her var det snakk om en syklist som allerede VAR i Norges toppen da han begynte på "kuren". Da hadde det vært morsomt å høre hvilke resultater han har oppnådd med det nye O2 opptaket.
Re: Syklist fikk kjempekondis 4x4 løping [Re: hrukin] #1383639 27/04/2012 17:03
Pinello Offline
"Time trial performance improved by 14.9%"
Re: Syklist fikk kjempekondis 4x4 løping [Re: Pinello] #1383721 27/04/2012 18:53
Registrert: Nov 2008
Leif_H Offline
Er vel ikke nødvendig å løpe en gang hvis bakken er bratt nok. Å gå hardt med skistaver opp en slalombakke får opp blodpumpa. Tror ikke at det er så belastende på ledd etc.
Re: Syklist fikk kjempekondis 4x4 løping [Re: hrukin] #1383758 27/04/2012 19:18
joerntp Offline
Er vel forøvrig ikke noe sensasjonelt med dette ?
Mengden derimot høres ganske drøyt ut mongo
Fra november til februar la vi inn tre perioder på ti dager der han skulle gjennom femten 4 x 4 intervaller
Hadde jeg for moro skyld prøvd meg på noe slikt kunne jeg trekt inn årene og fått meg en ny hobby etter den første uka ICON_GRIN
Redigert av joerntp; 27/04/2012 19:21.
Re: Syklist fikk kjempekondis 4x4 løping [Re: hrukin] #1383778 27/04/2012 19:34
fredriks Offline
Jag har läst artikeln och tyckte den var interessant. En sak jag tyckte var konstig var att V02max i löpning och sykling var nestan lika i första testen men VO2max i sykling var det som ökade klart mer än V02max i löpning trots att han tränade mycket löpning.
Re: Syklist fikk kjempekondis 4x4 løping [Re: hrukin] #1383813 27/04/2012 20:06
Hekta-MTB Offline
Løp en times tid uten å ha løpt på lenge så skjønner du at den muskulære belastningen er vesentlig. Og fordi kroppen heller ikke er vant til å løpe vil du fort få ganske høy puls.
Re: Syklist fikk kjempekondis 4x4 løping [Re: Torp] #1383832 27/04/2012 20:23
fredriks Offline
Sitat: Torp
Sitat: bjerkseth
En ökning i tröskel från 333.3 till 380.0
Det verkar ha varit 15 4x4 ökter på 10 dagar alla på beina.
Re: Syklist fikk kjempekondis 4x4 løping [Re: hrukin] #1383984 27/04/2012 23:24
Registrert: Mar 2009
Z
ziggi Offline
Z
Hvis de watt tallene stemmer, så kan han ikke ha vært i norgestoppen før prosjektet. 330 watt og 85 kg..
Re: Syklist fikk kjempekondis 4x4 løping [Re: ziggi] #1384002 28/04/2012 05:19
fredriks Offline
Sitat: ziggi
Estimerat FTP utifrån tempo på 24 och 28 minuter är också lägre än tröskeln baserad på laktat. Testerna är dock gjorda i februari och november så inte i sesongen.
Re: Syklist fikk kjempekondis 4x4 løping [Re: hrukin] #1384073 28/04/2012 08:35
Pinello Offline
Treningsopplegget er jo egentlig en variant over "Samdal-trening". Eller slik dette forums blogger, Tommy, trener. Det spesielle er jo at han som syklist velger å kjøre intervallene som løp.
Han øker VO2 max med ca 10%, dvs. størrelsen på det aerobe arbeidet han er i stand til å utføre i semi-kort periode (4-5 min.) Samtidig forbedrer han tempotiden med 15%. Det er litt merkelig synes jeg. Jeg ville ha tippet en ca. 5% forbedring av tempotid ut fra en 10% økning i Vo2 max. Han er nødt for samtidig å forbedret utnyttingsgrad og/eller arbeidsøkonomi. Eller han er mye mere aero enn tidligere.. Eller den første tempotiden var på en dårlig dag..
Re: Syklist fikk kjempekondis 4x4 løping [Re: hrukin] #1384108 28/04/2012 09:49
Hekta-MTB Offline
Det er også viktig å merke seg at vedkommende var i fysisk stand til å gjennomføre et så hardt opplegg. Han hadde mao mye annen trening før han gjennomførte dette intervallopplegget og det stemmer jo bra med hvordan man generelt tenker om trening og som Helgerud og co ikke nevner eller er uenig i.
Re: Syklist fikk kjempekondis 4x4 løping [Re: hrukin] #1384155 28/04/2012 11:02
fredriks Offline
Jag tittade lite mer på datan. Mellan februari och november innan bolkarna startade så tränade han normalt. Av ca 15 timmar i veckan så hade han 1.6 timmar med en puls över 80% varav 40% över 90%. Är inte det lite väl lite högintensiv träning med den träningsvolumen?
Under forskningsperioden tränade han lika mycket över 80% varav 60% över 90%. Han tränade 10 timmar mindre lugnt i månaden under den perioden och mycket mer löpning.
Re: Syklist fikk kjempekondis 4x4 løping [Re: hrukin] #1384535 28/04/2012 20:51
Krank1 Offline
Toppsyklist i Norge med 64 ml/kg/min i o2 opptak? (før forsøket) Kan det stemme da?
Og til dere som tenker å kjøre ville 4x4 perioder, les denne: (også fra NTNU)
http://mobil.dn.no/c.jsp?rssid=&cid=25618411&item=http%3A%2F%2Fwww.dn.no%2Ffeed%2Fmobiletech%2Farticle%3Faid%3D2338612
Redigert av Krank1; 28/04/2012 20:52.
Re: Syklist fikk kjempekondis 4x4 løping [Re: ziggi] #1514895 03/11/2012 08:24
Registrert: Jan 2009
Playboy75 Offline
Jeg synes og dette høres "lite ut". Jeg klarer sjøl 360-370watt i en time, og farten jeg får er ikke mer en ca 41 på en vanlig racer. Kjørte 3timer på 300w og resultatet da ble 34.1km/t.
Dog sier Reidar Borgersen at snittwatten hans var 381w på NM gullet i Tempo, så her må det være mange andre faktorer ute å går. Jeg veier sjøl ca 83 + klær og får 42.6km/t når jeg trår 388w i en relativt flat løype.
Re: Syklist fikk kjempekondis 4x4 løping [Re: Playboy75] #1514896 03/11/2012 08:26
Playboy75 Offline
388w = 42.6km/t . Igen var dette på vanlig racer uten aero hjul.
Side 1 av 3 1 2 3
