GT 2012 modell Fury Carbon Team downhill-toppmodellen til GT, str. Large
Sykkelen er ny, ubrukt, selges for 45.000,-
Denne er utsolgt i USA pga stor pågang
Får den etter påske.
Tlf 400 93 233
Specs fra GT sin hjemmeside under, se gjerne nettsiden deres:
GT Fury Carbon Team Type of Frame F.O.C. Xm™ Carbon Frame, 210mm Travel Independent Drivetrain™ Suspension System w/ F.O.C. Pivots, and 150 x 12mm Dropouts, and 1 1/2" Head Tube,
Fork Marzocchi 888 Rc3 Evo, 203Mm Travel, 20X110Mm Thru Axle, W/ Adjustable High Speed & Low Speed Compression, Rebound, & Volume Adjust
Crank Truvativ Descendent 1.1, 36T
Bottom Bracket Sram GXP
Shifters SRAM X7, Trigger (Rear Only)
Cog Set Shimano Tiagra, CS-4600, 11-25T, 10-Speed
Chain KMC X10, 10-Speed
Front Derailleur e.thirteen LS1+ with 40T Bashguard
Rear Derailleur SRAM X9, Short Cage
Rims Alex Supra BH 32H
Front Hub ALL TERRA Lightweight Alloy Sealed Bearing Disc 32H
Rear Hub ALL TERRA Lightweight Alloy Sealed Bearing Disc 32H
Spokes DT Swiss Champion
Tires Maxxis Minion DHF, 2.5", Dual Ply, 3C
Pedals ALL TERRA Slimline Flat Pedal, Sealed Bearings, w/ Replaceable Pins
Front Brake Formula RXO, 203mm/180mm (F/R)
Rear Brake Formula RXO, 203mm/180mm (F/R)
Brake Levers Formula RXO
Handlebar Funn Full On, Triple Butted, 6061-T6, 785mm
Stem Funn RSX MkII Direct Mount, 45-50mm
Headset Cane Creek Angleset ZS49xZS49, +/-1 deg, 1.5 to 1 1/8"
Saddle SDG Formula FX I-Beam
Seat Post SDG Micro I-Beam, 30.0mm x 350mm
Rear Shock Fox Shox DHX RC2 w/210mm Travel, Adjustable Rebound & Compression
Extras N/A
