Side 1 av 26 1 2 3 25 26
Ibis Ripley 29er fulldemper
Ibis Ripley 29er fulldemper #1249942 31/08/2011 08:36
simenf Offline OP
Ibis har nettopp annonsert sin 29er fulldemper HER
Rå fakta er :
29" wheels
120mm rear wheel dw-link travel
Twin angular contact composite bearing eccentric linkages
Full carbon fiber monocoque with sacrifical core molding
Tapered head tube (Cane Creek AngleSet & Chris King InSet compatible)
Kashima coated Fox Float RP23 with Adaptive Logic Boost Valve technology
Clean cable routing with molded carbon cable stops and provisions for cable-actuated adjustable seat posts
BB92/Press GXP style integrated BB is lighter and stiffer and better for molding
142mm Maxle rear axle provides high axle stiffness with QR ease of wheel removal and installation
160mm carbon fiber post mount rear brake mounts
High direct front derailleur, mounted to swingarm
Geometry designed to work with 120-140mm forks
34mm fork stanchion approved
4 Sizes (S, M, L, XL)
Weight TBD
Price TBD but in line with our other frames
Delivery TBD, but not in 2011
Navnet henspiller kanskje på filmen "The talented mr Ripley"? Ser i all fall ut til å ha "alt".
Re: Ibis Ripley 29er fulldemper [Re: simenf] #1249944 31/08/2011 08:38
Registrert: Mar 2009
kask Offline
Ser vanvittig bra ut! Hvis de klarer å bygge den lett så er nok dette en modell som vil selge bra
Re: Ibis Ripley 29er fulldemper [Re: simenf] #1249974 31/08/2011 08:57
simenf Offline OP
Noen som kan forklare hva "Twin angular contact composite bearing eccentric linkages" betyr?
Fordeler?
Re: Ibis Ripley 29er fulldemper [Re: simenf] #1249980 31/08/2011 09:01
runermm Offline
De har vel i prinsippet gjort det samme som på Yeti SB66, men med to linker, ikke bare en. Det er jo genialt ICON_SMILE
Re: Ibis Ripley 29er fulldemper [Re: simenf] #1249993 31/08/2011 09:16
simenf Offline OP
Re: Ibis Ripley 29er fulldemper [Re: simenf] #1249997 31/08/2011 09:24
Registrert: Feb 2009
Diablito Offline
Sannsynligvis - når det evt. blir å få tak i ICON_WINK
Framgir montert på baksvingen ser spennende ut. Men er det i praksis problemer med nøyaktigheten på forgiret avhengig av demperutslag når det er montert på seterør?
Re: Ibis Ripley 29er fulldemper [Re: simenf] #1250039 31/08/2011 10:00
nr7wave Offline
Aquafil
Aquafil
Dette så jo veldig spennende ut! Særlig den nye link-løsnigen. Må jo bli veldig stivt og fint. Nå mangler det bare at BOS kommer med en 29-er gaffel på 140mm. Da kommer jeg til å bli skikkelig fristet til å gå over til 29.
Christian S.
Re: Ibis Ripley 29er fulldemper [Re: simenf] #1250042 31/08/2011 10:03
Kortkorte linker i form av eksentrisk aksling er jo fint. Har troen på holdbarheten der.
Re: Ibis Ripley 29er fulldemper [Re: simenf] #1250055 31/08/2011 10:12
Kjartandaddy Offline
Me wants!
Big wheels keep on turning
Re: Ibis Ripley 29er fulldemper [Re: simenf] #1250435 31/08/2011 15:48
Jonas88 Offline
Latterlig lekker. Ny drømmesykkel?
Blir spennende å se hva vekten havner på også.
Denne med en fox 34 burde funke til det meste...
Re: Ibis Ripley 29er fulldemper [Re: simenf] #1250660 31/08/2011 19:59
Registrert: Sep 2001
Espen Offline
Jepp, dette kan bli en vinner. Spent på vekt.
Noen som tør tippe?
2500g?
post@espenwettre.no
Re: Ibis Ripley 29er fulldemper [Re: simenf] #1250670 31/08/2011 20:09
runermm Offline
SL-R veier 2,25 kg og Ripley bygges med samme metodikk. Samtidig gir de nye linkene en vektbesparelse på 130 gram, så kan nok ende opp rundt 2,5 kg, ja. Heftige saker for en storhjuling med 120/140 mm vandring!
Re: Ibis Ripley 29er fulldemper [Re: simenf] #1250725 31/08/2011 20:59
Espen Offline
Jepp, det er knakende fett!
Skal man være litt nøktern, er vel ikke en halvkilo på ramma egentlig noen krise på en solid stisykkel til sterke voksne menn, men jeg liker utviklingen.
e
post@espenwettre.no
Re: Ibis Ripley 29er fulldemper [Re: simenf] #1250740 31/08/2011 21:08
Jonas88 Offline
Hva tenker dere om styrevinkelen?
69.5° med 140mm... Jeg hadde håpet på noe bitte litt slakkere.
Men det er kanskje bare meg?
Re: Ibis Ripley 29er fulldemper [Re: simenf] #1250748 31/08/2011 21:13
Jamez Offline
hadde ikke gjort noe med en grad slakkere med 140mm nei tror jeg...
synd de ikke bare kunne brukt full 1.5" styrerør så man kunne satt på et angleset for de som vil tweake litt selv..
Re: Ibis Ripley 29er fulldemper [Re: simenf] #1250752 31/08/2011 21:22
Loki Offline
Det står i første post at angleset kan brukes, eller?
Re: Ibis Ripley 29er fulldemper [Re: simenf] #1250753 31/08/2011 21:22
runermm Offline
69,5° på en 29er vel ikke så galt. Og ja, Ibis skriver at Ripleyen kompatibel med AngleSet.
* Tapered head tube (Cane Creek AngleSet & Chris King InSet compatible) -> http://www.ibiscycles.com/bikes/ripley_29er/#
Redigert av runermm; 31/08/2011 21:23.
Re: Ibis Ripley 29er fulldemper [Re: simenf] #1250758 31/08/2011 21:25
Jamez Offline
men, om man skal bruke angleset så må kan man ikke ha tapered gaffel... og det vil man jo gjerne ha!
Re: Ibis Ripley 29er fulldemper [Re: Jonas88] #1250782 31/08/2011 21:53
Registrert: Oct 2001
Trond Vidar Offline
I want to ride my bicycle
Sitat: Jonas88
hvor mye erfaring har du med å kjøre 29ere? 69.5 er relativt slakt på en 29er.
Dave Weagle er tungt inne på en tråd om Ripley på mtbr.com nå, anbefaler å lese den. Der står det mye om styrevinkel.
http://forums.mtbr.com/ibis/dw-link-2xc-ibis-ripley-29er-734897.html
Re: Ibis Ripley 29er fulldemper [Re: Trond Vidar] #1250851 01/09/2011 05:59
Jonas88 Offline
Sitat: Trond Vidar
Sitat: Jonas88
Flott å høre hva Dave Weagle selv mener. Det slakkeste jeg har prøvd er en WFO med 69°, og når jeg tenker meg om var vel den ganske all right, så 69.5° blir kanskje ganske spot on det også?
Jeg har mer erfaring med 26ere, ut ifra hva DW skriver så skal 69.5° tilsvare ca 67° på 26er? Noen tanker om dette?
Re: Ibis Ripley 29er fulldemper [Re: Jonas88] #1250868 01/09/2011 06:33
Espen Offline
Jeg kjører 29er med 71.5 grader og 120mm. Det funker meget bra, spesiellt nedover.
En sykkels egenskaper bestemmes av så utrolig mye mer enn styrevinkel.
DW er god, og det tror jeg denne sykkelen blir også.
e
Redigert av Espen; 01/09/2011 06:34.
post@espenwettre.no
Re: Ibis Ripley 29er fulldemper [Re: simenf] #1250901 01/09/2011 07:16
Jeg utsetter oppussingen av badet til 2015.
Re: Ibis Ripley 29er fulldemper [Re: Jonas88] #1250923 01/09/2011 07:35
Jamez Offline
Sitat: Jonas88
Jeg ser den - om man tenker litt matematisk.
Med større hjul blir jo gaffelen lengre, og på den måten kan man vel kanskje si at 69.5 grader plasserer kontaktpunktet mot bakken lengre framfor stem'en enn på en 26er med samme vinkel.
Men, etter noen grove raske beregninger blir det omtrent 1 grad forskjell der.
Om man regner på 'vippepunkt' blir det kanskje enda litt lengre fram effektivt pga de større hjulene?
Re: Ibis Ripley 29er fulldemper [Re: simenf] #1250961 01/09/2011 07:59
simenf Offline OP
Hva med resten av geometrien?
Den kabelen til frontgiret stikker i øynene. Blir interessant å se ferdig grafikk på ramma. Ser veldig ut som en prototype, spesielt rundt linkboltene.
Redigert av simenf; 01/09/2011 08:20.
Re: Ibis Ripley 29er fulldemper [Re: simenf] #1251068 01/09/2011 09:43
Skal klare meg uten frontgir på denne også. Tar gjerne ramma i stealthgrå.
Re: Ibis Ripley 29er fulldemper [Re: Jonas88] #1253919 04/09/2011 21:34
sigmund Offline
Lekre saker! En sånn skal jeg bygge meg neste år ICON_SMILE
Når det gjelder vekta så sier en representant fra Ibis i denne videoen, at de har som mål å få en rammevekt på 2000g i str. large med demper.
__o
_-\<,
(_)/(_)____ Sigmund
Re: Ibis Ripley 29er fulldemper [Re: simenf] #1254023 05/09/2011 07:35
simenf Offline OP
Takk for linken - det var interessant info.
Jeg har bestilt!
Spørsmålet er vel hva en fyller ventetiden med....av sykkel, that is. Beholde dagens eller leke med en annen mer stiorientert "ventesykkel". Midten av 2012 blir fort slutten av 2012, ref Ibis tidligere utsettelser.
Redigert av simenf; 05/09/2011 07:44. Rediger grunn: Linken
Re: Ibis Ripley 29er fulldemper [Re: simenf] #1255216 06/09/2011 12:09
sigmund Offline
Da har Ibis lagt ut en video som viser litt mer rundt detaljene på bakhjulsopphenget, og bevegelsene til de mye omtalte eksentriske lenkene. (... som jo er det samme som to veldig korte lenker)
Som ingeniørnerd skulle jeg gjerne sett litt detaljer rundt banen til bakakselen, når denne går gjennom vandringen.
__o
_-\<,
(_)/(_)____ Sigmund
Re: Ibis Ripley 29er fulldemper [Re: simenf] #1255367 06/09/2011 14:49
simenf Offline OP
Det står at Ripley er kompatibel med Angleset, men er 1,5" konisk styrerør på gaffel kompatibelt med Angleset?
Hadde vært dumt å måtte være begrenset til 1 1/8" rett styrerør-gaffel på en sånn sykkel. 70 eller 69,5 grader hadde kanskje vært enda bedre på sti.
Re: Ibis Ripley 29er fulldemper [Re: simenf] #1255381 06/09/2011 15:22
arni@stinky Offline
Sitat: simenf
Ser for meg ut som om det skal gå helt fint. Se link til Cane Creek for mer info. Med Angleset må du nok holde deg til 1 1/8" styrerør.
Redigert av arni@stinky; 06/09/2011 15:28. Rediger grunn: For kjapp på avtrekkeren
Kunnskap er informasjon kombinert med erfaring, kontekst,
interpretasjon og refleksjon. Kunnskap er begrunnet tro.
Kunnskap oppstår mellom ørene i menneskets hjerne.
Petter Gottschalk
