Specialized Stumpjumper Marathon Carbon 2009 Med
Specialized Stumpjumper Marathon Carbon 2009 Med #1177090 20/05/2011 19:39
Registrert: May 2004
steff1g Offline OP
Jeg selger min pent brukte Specialized stumpjumper marathon carbon fra 2009.
Sykkelen er i medium str. Sykkelen har jeg brukt i ca 60-70 mil.
Dempegaffelen er akkurat nyoverhalt hos BAB.
Mer spec under bilde...
Nypris på sykkelen var 36.000,- jeg selger den for 17.000,-
ta kontakt på mail på stef-gul@online.no
Sykkelen kan ses i Drammens området
Her er SPEC:
ramme:FACT 9M carbon, Forged dropouts with disc mount and replaceable derailleur hanger
gaffel:Specialized Future Shock S90, 90mm travel, Brain Fade, Rebound adjust, Single
sided air spring and damper, Carbon 1-1/8 inch to 1.5 inch steerer
Front Derailleur:Shimano M660 SLX, 34.9mm, Clamp bottom swing, Dual pull
Rear Derailleur:SRAM X-0, 9-speed, Mid cage
Shifters:SRAM X-0, Carbon/aluminium trigger, 9-speed
Chainset:Shimano FC-M770 XT, 2 piece: 175mmChainrings:22/32/44 Tooth Chainrings,
4-bolt, 104/64mm
Bottom Bracket:Custom Shimano BB-91, OS, Press-in bearing
Cassette:Shimano M770 XT, 9-speed, 11-34 Tooth Range
Chain:SRAM PC-971, 9-speed with Power Link
FrontBrake:Custom Avid Ultimate SL, Alloy backed organic pads, Alloy calliper,
Magnesium lever body with carbon blade, SS hardware package, 185mm rotor
Rear Brake:Custom Avid Ultimate SL, Alloy backed organic pads, Alloy calliper,
Magnesium lever body with carbon blade, SS hardware package, 160mm rotorBrake
Levers:Custom Avid Ultimate SL Hydraulic
Handlebar: truativ Carbon
Stem:thomson elite
Headset:1-1/8 inch to 1.5 inch Threadless, Campy style, Cartridge bearing
Rims:DT Swiss XR 4.2D, 24mm with eyelets, 28/32 hole
Front Hub:Specialized Hi Lo disc, CNC flange, Sealed cartridge bearing, Oversized
end caps, 9mm DT RWS, Alloy QR, 28 hole
Rear Hub:Custom DT Swiss 280S with Star Rachet, Alloy freehub with DT RWS, 10mm
alloy QR, 32 hole
Spokes:DT Super Comp 2.0/1.7/1.8mm butted stainless, Black, Alloy nipples
Saddle:Specialized Phenom SL, Ti rails, thin foam, 143mm
Seatpost:Thomson Elite
//SG
Re: Specialized Stumpjumper Marathon Carbon 2009 Med [Re: steff1g] #1193571 09/06/2011 19:02
steff1g Offline OP
16.000,-
//SG
