2010 GT Force 2.0
Størrelse: Medium
Kjøpt for to måneder siden, og er derfor så god som ny!
Sykkelen står i Tromsø, men kan postes til hele Norge
12000 NOK
SPECIFICATIONS:Rear Hub Shimano Deore 6 bolt disc
Cog set SRAM PG-950 11-34T
Spokes DT Swiss Champion 1.8 stainless steel
Front Hub GT 20 mm through axle with 4 japanese sealed bearing
Rims WTB Speed Disc, 32 hole, black anodized, for presta valve.
Chain Shimano Nine Speed
Shifters SRAM X-9
Rear Derailleur SRAM X-9 Medium Cage
Front Derailleur SRAM X-9
Pedals Shimano DX
Bottom Bracket Truvativ Outboard
Crankset / Chainwheel Truvativ Stylo, with Alloy rings and 2 piece outboard BB
Fork Rock Shox Revelation SL 140mm travel with 20mm through axle, Dual Air sprung with rebound damping adjust with 7050 aluminum steerer
Frame GT designed 6061 Monocoque frame with Independent Drivetrain suspension. 6.0 inches of rear wheel travel. With new forged I-link. Standardized bearings and modular dropout system.
Rear Shock Fox Float RP2 Shock with rebound adjust and lock out
Nipples DT Swiss Alloy
Tires Front: 26"x 2.3 Kenda Nevgal, 120 tpi with Kevlar bead, Rear: same only 2.1
Front Brake Avid Juicy 3 180mm rotor
Rear Brake Avid Juicy 3 160mm rotor
Brake Levers Avid Juicy
Handlebar Ritchey Pro Rizer Alloy 31.8 clamp, low rise
Stem Ritchey 31.8 clamp, 3-D forged
Headset FSA Orbit X 1 1/8" forged cups, sealed bearings
Grips GT Lock Down, co molded locking grip system with alloy collars
Saddle WTB Rocket V Comp wth Cr-mo rails
Seat Post Ritchey Comp Post
Seat Clamp GT Alum QR
