Vurderes solgt pga. tilløkning i familjen...
Ny (5ggr i marka) Specialized EnduroSL Expert 2010 size Large:
http://www.specialized.com/no/no/bc/SBCBkModel.jsp?spid=45728&eid=4344&menuItemId=9391Karbon utgaven ble beste topptursykkeln i senaste Terrengsykkel Nr.26, s72-73.
Nypris 37998kr,
nå kun 25000krKonge AM- og stisykkel!
Finnes i Oslo.
/Jonas - 45 86 68 32
Description:Where XC and DH collide, you'll find the lightweight Enduro SL—the most capable All Mountain bike that lets you climb without crying and rail in the technical terrain. If you want to ride the whole mountain and really own it, the Enduro's six-inch travel frame, adjustable travel fork, position-sensitive rear shock and remote-adjust seatpost give you the skills to get the job done (though you'll need a little talent on your own).
Features: * Avid Elixir R CR SL lightweight hydraulic disc brakes/levers with tool-free reach and adjustable pad contact
* Custom Fox RP2BV rear shock features position-sensitive Boost Valve damping for great square edge bump performance
* Front wheel spins on a 20mm thru-axle variable flange hub for a superb combination of strength and weight, with a DT Swiss 330SL disc-ready freehub in the rear
* Specialized Command Post 3-position adjustable-height seatpost with remote lever for on-the-fly changes to riding stance
* RockShox Lyrik IS 2-Step 115/160mm-travel fork with 20mm Maxle thru-axle features external rebound and compression adjust for pitch-perfect descents
* Custom DT Swiss E4405 26mm wide rims and Competition stainless steel spokes for strength without the weight penalty
Technical Specfication:FRAME Enduro M5 alloy, size Large, fully manipulated frame w/ ORE TT and DT, forged HT, sealed cartridge bearing pivots, ISCG mount, replaceable derailleur hanger, 160mm travel
REAR SHOCK Fox RP2BV with Boost Valve for Enduro. Ext reb and ProPedal adj.
FORK RockShox Lyrik IS 2-step, 115/160mm travel, tapered alloy steer, rebound and compression adj.
HEADSET 1-1/8 and 1.5" Threadless, Campy style upper with 1.5" lower cartridge bearing
STEM 3D forged alloy, adjustable rise, 31.8mm clamp
HANDLEBARS Specialized Enduro mid-rise bar, 7050 alloy, 31.8mm, 9 degree backsweep, 6 degree up, 680mm wide
GRIPS Specialized waffle lock on grip (S/M) Specialized Thick lock on grip (L/XL)
FRONT BRAKE Custom Avid Elixir R CR SL, alloy backed semi-met pads, alloy CR Elixir lever w/ pad contact adj & reach adj, 205mm rotor
REAR BRAKE Custom Avid Elixir R CR SL, alloy backed semi-met pads, alloy CR Elixir lever w/ pad contact adj & reach adj, 185mm rotor
BRAKE LEVERS Custom Avid Elixir CR SL Hydraulic, carbon lever blade, tool-less adj. reach and pad contact
FRONT DERAILLEUR
Shimano M665-E, SLX, top swing, dual pull for double
REAR DERAILLEUR SRAM X-0, 9-speed, mid cage
SHIFT LEVERS SRAM X-9 aluminum trigger
CASSETTE Shimano HG61, 9-speed, 11-34t
CHAIN SRAM PC-971, 9-speed w/Power Link
CRANKSET Custom Shimano FC-M762, 2pc., S22/A36 with Gamut shift guide, S: 170mm, others: 175mm
CHAINRINGS S22/A36
BOTTOM BRACKET Custom Shimano integrated
PEDALS Shimano DX
RIMS Red Custom DT Swiss E440S, 26mm, sleeved w/eyelets, 32h
FRONT HUB Hi-Lo disc, 20mm thru-axle, 32h
REAR HUB Custom DT Swiss 330SL w/ alloy freehub, DT RWS QR, 32h
SPOKES DT Swiss Competition 1.8/1.6mm stainless
FRONT TIRE S-Works Eskar, 26x2.3", 120 TPI, tubeless ready, aramid bead, dual compound
REAR TIRE Specialized Eskar Control, 26x2.3", 60 TPI, tubeless ready, aramid bead
INNER TUBES Ultralight presta valve
SADDLE Specialized Format, hollow Cr-Mo rails, SL foam, S/M: 130mm L/XL:143mm
SEATPOST Specialized Command Post, 3 position, 100mm Adjustable height, Remote Operated, Single bolt head
SEAT BINDER 7050 hard annodized alloy collar w/ QR, 34.9mm clamp ID, black
NOTES Protective clear coat, derailleur hanger, owners manual
WEIGHT 13,5 kg
