Specialized Demo 8 PRO 05 Selges: 9500,-
Specialized Demo 8 PRO 05 Selges: 9500,- #971333 21/06/2010 17:03
Registrert: Apr 2006
photodude Offline OP
Selger sykkelen til lillebror. Dette er en Specialized Demo 8 PRO størrelse medium. Selges for 9500,- Ta kontakt på 47 60 58 78 eller send PM. Sykkelen står i Hokksund/Vestfossen.
EXPERIENCE: EXTREME FREERIDE
The Demo 8 is a trimmed-down version of the Demo 9. With a lighter chassis, slightly less rear wheel travel and lower BB, this bike is more maneuverable, yet still retains most of the extreme freeride capabilities of it's bigger sibling.
Racers and lighter riders who crave a more nible, tighter, and quicker handling machine will appreciate this bike that is equally at home on the DH circuit as the local chutes, ladders, and drops.
Chassis weight was minimized by using a longer downtube and less liberal forging at the BB area. A shorter shock was utilized, with a ti spring for extra weight savings. 135mm spacing on the rear end with a 6mm offset allows for standard dropouts, standard wheelsets & hubs.
FRAME: All-New DEMO 8 FSR frame. Super low center of gravity and standover with sub-seatstay actuated shock. Full cartridge bearing pivots, 8.1" of travel with full chainguide and front derailleur compatibility. 135mm wide asymmetrical 6mm offset rear triangle, ISCG mount, rear derailleur protector. 26 and 24" wheel compatible with two geometry settings.
REAR SHOCK: Manitou Swinger 4-way, SPV position-sensitive damping, external adjustable pedal platform, progressivness, and rebound with titanium coil S:400 M:450 L:500. 8.75x2.75
FORK: Fox 40 RC3. 40mm stanchions, position-sensitive damping, external initial, mid and end position damping adjust, external rebound, 20mm thru-axle dropouts
HEADSET: Cr-Mo, 1 1/8 threadless, all alloy and steel construction, loose ball bearing with seals
STEM: Syncros BearHug HD, 4-bolt 31.8mm clamp
HANDLEBARS: Easton Monkeylite
TAPE / GRIPS: Specialized MTB grip, black, double density Kraton
FRONT BRAKE: Magura Louise BAT full hydraulic disc, 8" rotor
REAR BRAKE: Magura Louise BAT full hydraulic disc, 8" rotor
REAR DERAILLEUR: SRAM X.9
SHIFT LEVERS: SRAM X.9
CASSETTE: Shimano HG-50, 9-speed, 11x32t
CHAIN: Shimano HG-73
CRANKSET: Truvativ Holzfeller 7050 ISIS spline, 7050 alloy, 170mm
CHAINRINGS: 38t ring. BlackSpire DS-1 guide with C4 Lexan bash guard
BOTTOM BRACKET: Truvativ ISIS GigaPipe DH, 73mm shell width, 128mm spindle length
PEDALS: Lo-Pro Magnesium platform, Removable pins, oversize Cr-Mo axle
RIMS: Mavic EX721, 26" front and rear, 36 hole, welded
FRONT HUB: Specialized Stout disc, 36 hole, cartridge bearings, 20mm alloy thru-axle
REAR HUB: Specialized Stout 36h, bolt-on axle
SPOKES: DT Swiss, 2.0mm (14g) stainless, black, brass nipples
FRONT TIRE: Maxxis Minion DH 2.5"
REAR Tire: Maxxis Minion DH 2.5"
SADDLE: Specialized freeride, SL foam 8mm Cr-Mo rails, X-Brace
SEAT POST: Syncros Derived 2-bolt, 30.9 x 330mm
Redigert av photodude; 21/06/2010 17:31.
Re: Specialized Demo 8 PRO 05 Selges: 9500,- [Re: photodude] #972149 22/06/2010 20:20
Torzt Offline
Er denne mye brukt? tilstand?
Re: Specialized Demo 8 PRO 05 Selges: 9500,- [Re: Torzt] #972663 23/06/2010 14:43
Sykkelen er ikke lengere til salgs.
