Mongoose Khyber Super str L nesten ubrukt
Mongoose Khyber Super str L nesten ubrukt #871024 06/01/2010 16:49
Geirno Offline OP
Dette er en super stisykkel, passer perfekt for Nordmarka, men sikkert også for andre flotte plasser.kjøpte den mot slutten av sesongen men ble skada så har ikke fått brukt den. Kun en 2timerstur i Østmarka. Selges da jeg ikke finner plass å ha den, står per idag i stua...
Veilprisen er 24900,- selges nå for 19500,-
kan treffes på mail: geir.norland@gmail.com
Color(s): Black Nickel
* Frame: Mongoose FreeDrive All Mountain/Free Ride, 165mm travel, 135mm vertical drop outs
* Fork: Marzocchi 55 ATA Micro 125-165 travel adjust, micro compression adjust, nickel stanchions, air spring with progressive bottom out, 20 mm QR thru axle
* Rear Shock: Marzocchi ROCO Air R, 5 position compression, bottom out resistance, oversize air can, and rebound adjust, 216x63 mm w/ 19x8 mm hardware
* Crankset: Shimano SLX 22/36T/BASH Hollow Tech II
* Bottom Bracket: Shimano external bearing
* Pedals: Crank Bros. Acid
* Front Derailleur: Shimano SLX for 22/36T combo
* Rear Derailleur: Shimano XT, Shadow mount
* Shifters: Shimano SLX 18 speed
* Freewheel: SRAM PG-950 Cassette11-34T
* Chain: Shimano HG73
* Rims: No Tubes ZTR Flow 32 hole
* Front Hub: Formula sealed bearing 15 mm thru axle
* Rear Hub: Formula sealed bearing cassette
* Spokes: DT Competition double butted with alloy nipples
* Brake Levers: Hayes Stroker Trail w/ tool free reach adjust
* Handlebar: Gravity Light, triple butted and shot peened AL7050, 31.8x 25x710 mm
* Stem: Gravity Light, 31.8x50 mm
* Grips: Mongoose Lock on
* Saddle: SDG Bel Air RL cromoly rail
* Seat Post: Cobra R adjustable height w/ remote 31.6 x 350 mm
Re: Mongoose Khyber Super str L nesten ubrukt [Re: Geirno] #871256 07/01/2010 08:50
ToHee Offline
- så humla suser
- så humla suser
Jeg gikk fra en Ventana X5 til denne og har ikke angret et sekund. Et bilde som bedre viser hvor fin sykkelen er:
Aron SK, NBNL
Re: Mongoose Khyber Super str L nesten ubrukt [Re: ToHee] #874465 15/01/2010 00:53
Geirno Offline OP
står forsatt i stua
Re: Mongoose Khyber Super str L nesten ubrukt [Re: Geirno] #878191 23/01/2010 22:30
Registrert: Jan 2010
npl Offline
Solgt? Pris?
Re: Mongoose Khyber Super str L nesten ubrukt [Re: npl] #879347 26/01/2010 15:18
Geirno Offline OP
den er ikke solgt. prisen står i annonsen:)
Re: Mongoose Khyber Super str L nesten ubrukt [Re: Geirno] #913194 06/04/2010 10:08
Geirno Offline OP
nå er jo sesongen her og jeg har forsatt sykkelen:)
løp og kjøp
