Lake mxz302 winter cycling shoes
Lake mxz302 winter cycling shoes #857973 01/12/2009 15:03
Registrert: Dec 2009
I
iceman Offline OP
I
Hei!
I am looking for the Lake mxz302 wintercycling shoes.
Can anybody tell me where in Oslo i can buy these?
Greetings from Fagernes ,Valdres.
Re: Lake mxz302 winter cycling shoes [Re: iceman] #865375 17/12/2009 16:32
hajo Offline
me too, looking for where these shoes can be bought from
Re: Lake mxz302 winter cycling shoes [Re: hajo] #865377 17/12/2009 16:35
hajo Offline
Re: Lake mxz302 winter cycling shoes [Re: hajo] #865378 17/12/2009 16:36
hajo Offline
Re: Lake mxz302 winter cycling shoes [Re: hajo] #865389 17/12/2009 17:06
hajo Offline
Re: Lake mxz302 winter cycling shoes [Re: hajo] #866810 21/12/2009 19:09
MrWhite Offline
When in doubt: flat out.
Founder of Sleiverud Racing
Re: Lake mxz302 winter cycling shoes [Re: MrWhite] #866826 21/12/2009 19:57
jerik Offline
Sender de til adresser i Norge?
Re: Lake mxz302 winter cycling shoes [Re: jerik] #867613 23/12/2009 19:57
MrWhite Offline
Hvem da? "wintercyclingshoes?". Aner ikke, men håper det.
Re: Lake mxz302 winter cycling shoes [Re: iceman] #867916 25/12/2009 19:40
KleinFervor Offline
Sitat: iceman
Sørensen sykler on Helsfyr/Oslo have this shoes. Normaly I use size 45, but had to switch to 47 for the Lake ones. By the way, I hope you consider suporting them (or another local store), instead of parting with your hard earned chash to some foreign web-page.
Re: Lake mxz302 winter cycling shoes [Re: KleinFervor] #868542 29/12/2009 00:06
hajo Offline
Re: Lake mxz302 winter cycling shoes [Re: hajo] #869006 30/12/2009 16:08
jerik Offline
Vel, gearandtraining.com, sender for bortimot samme pris, ferdig fortollet fra USA.
Re: Lake mxz302 winter cycling shoes [Re: jerik] #869599 03/01/2010 07:40
hajo Offline
kjøpte et par på topbikes. de kom i posten i går.
Re: Lake mxz302 winter cycling shoes [Re: hajo] #869613 03/01/2010 09:12
lph Offline
Er skoene bra? Og i hvilke temperaturer? Har hørt Lake-sko rost opp i skyene andre steder, men det koster jo spenn, da.
Re: Lake mxz302 winter cycling shoes [Re: lph] #869727 03/01/2010 15:14
hajo Offline
jeg har ikke prøvd dem enda. men skal en liten tur litt senere idag. og selvfølgelig mer utover uka. da skal det bli kaldvær.
jeg skal holde dere oppdatert
Re: Lake mxz302 winter cycling shoes [Re: hajo] #869758 03/01/2010 16:43
hajo Offline
var ute en tur i ca. 40 minutter, -12 grader og vind var forholdene. greie nok forhold. det er ikke mye. men jeg har problemer med hendene, jeg fryser kjempelett på fingrene. jeg har nye hansker fra svenske halvarssons. de er nok gode, det er den tofingrede typen, egentlig for snøscooterbruk. men de er grei å sykle med.
men det var skoene jeg skulle skrive om. de er behagelige å ha på jeg kjøpte str.45. der er god plass til mer sokker og kanskje ekstra såle. men det tror jeg ikke jeg trenger ekstra såle, de som er der virker gode. for skoene sin del kunne jeg vært en god del lengre ute, ingen tvil om det. jeg begynte å kjenne at det ble kjøligere på føttene, men frøs ikke, langt derifra. så så langt ser det lovende ut. det blir selvfølgelig flere ganger jeg gir inntrykk av skoene, ettersom jeg bruker dem og samler erfaring
Re: Lake mxz302 winter cycling shoes [Re: hajo] #870773 06/01/2010 08:35
jerik Offline
Jeg sykla i halvannen time i 20 minus forleden, og de holdt mål. Jeg kan ikke skjønne annet enn at Lake MXZ 302 er i en klasse for seg som vintersykkelsko! yes
Re: Lake mxz302 winter cycling shoes [Re: jerik] #870784 06/01/2010 08:51
lph Offline
Kult! Da blir det nok disse skoene når Shimano-skoa en gang sier takk for seg.
Hansker: har god erfaring med Pearl Izumi Inferno (heter nå Barrier) hummerhansker. Fryser da bare hvis jeg blir for varm (!) og fuktig på hendene av svette. Tynntynne ull linerhansker inni hjelper mot det, god og varm igår i 15 minus i en time.
Re: Lake mxz302 winter cycling shoes [Re: lph] #870942 06/01/2010 13:33
Registrert: Jan 2006
fondy Offline
Fantastiske sko, har hatt mine i 3 sesonger, kjøpte de på cyclecomponents.com
Anbefales
mvh Pål
Re: Lake mxz302 winter cycling shoes [Re: lph] #872530 10/01/2010 16:42
hajo Offline
Sitat: lph
http://www.slf.no/Medlemssider/Pa_Sykkel/Pa_Sykkel_2007/36490/TEST.pdf
jeg fant pearl izumi hansker som heter Pearl Izumi Lobster Glove, de får god omtale. men dyre er de. er det disse, her i en nyere? utgave?
Re: Lake mxz302 winter cycling shoes [Re: hajo] #872537 10/01/2010 16:54
hajo Offline
Re: Lake mxz302 winter cycling shoes [Re: hajo] #872558 10/01/2010 17:49
lph Offline
Jepp, det er de samme hanskene. Jeg har tredelt, nå er de todelt. Sikkert ørlite varmere. Kjøp gjerne tynne linere i samme slengen, gjør det også mye lettere å tørke dem.
Re: Lake mxz302 winter cycling shoes [Re: hajo] #872594 10/01/2010 20:06
Registrert: Jan 2002
gauter Offline
Pearl Izumis Lobster Glove har vært tilnærma uforandra i en del år nå. Jeg har brukt mine i hele vinter når det har vært ordentlig kaldt. Personlig fryser jeg kanskje ikke så veldig lell på hendene, men Lobster kan etter min smak bli for varme når det er plussgrader.
Flere totimersturer i rundt 10-15 minus, samt nedoverbakkesykling til jobb i 20 minus, og jeg har fremdeles til gode å fryse i år. Den kan bli litt klam og fuktig ved aktiv sykling, men er såpass godt vindisolert at det ikke oppleves som noe problem for min del.
Noe som er litt negativt, er at de tørker seint når de først er blitt våte inni, pga. trang åpning ved håndleddet.
Test fra gamle dager her:
http://terrengsykkel.no/index.php?id=587
Gaute
Re: Lake mxz302 winter cycling shoes [Re: gauter] #872785 11/01/2010 11:31
lph Offline
Jeg orker ikke bruke disse i varmere enn minus 4... Da er det over på "vanlig" vinter/høsthanske (661 Storm glove, tror jeg). Skotørker er forresten kjekt å ha hvis de blir våte inni.
