Pent brukt Specialized Enduro Comp 2009 i størrelse medium selges. Sykkelen ble kjøpt i sommer,brukt ca 3 måneder. Godt vedlikeholdt. Kvittering fra butikk følger selvsagt med.
Passer ryttere mellom 168 og 183 cm.
Bakbremsen er oppgradert til Elixir CR.
Selges høystbydende over 13000, veiledende pris 27999 kr!
Sendes eller hentes i Oslo.
sjekk
http://www.specialized.no/fulld-enduro-comp-fsr-m-satin-black.116953.no.htmlRamme Enduro M5 alloy, fully manipulated frame w/ ORE TT and DT, forged HT, sealed cartridge bearing pivots, ISCG mount adj. geometry, replaceable derailleur hanger, 150mm travel
Gaffel Fox 32 Float RL, 1-1/8 steerer, 15mm thru-axle, 150mm travel w/ compression and rebound adj.
Bakdemper Specialized AFR Shock w/ Spike valve, air spring, adj. rebound and low speed compression, 7.875x2.25
Bremser Custom Avid Elixir CR SL, alloy backed organic pads, 203mm rotor
Girskifter SRAM X-7, aluminum trigger, 9-speed
Krankgir Shimano M660 SLX, DMD, top swing, dual pull
Krank Custom Shimano FC-M542, S: 170mm, others: 175mm
Nav Specialized Hi-Lo disc, 25mm thru-axle, 32h
Felger Custom DT Swiss E440S, 26mm, sleeved w/eyelets, 32h
Dekk S-Works Eskar, 26x2.3, 120 TPI, aramid tubeless ready bead, dual compound
Kjede SRAM PC-971, 9-speed w/Power Link
Kassett Shimano HG61, 9-speed, 11-34t
Styre Specialized Enduro mid rise bar, 6066 alloy, 31.8mm, 6 degree up, 9 degree backsweep, 660mm wide
Stem Specialized adjustable rise, 31.8mm clamp, 3D forged w/ CNC finish
Sadelpinne 2014 butted alloy, single bolt setback, 30.9x350/400mm
Sadel Specialized Format, hollow Cr-Mo rails, SL foam, S/M/L: 130mm XL:143mm
