2009 Mongoose Teocali Elite stisykkel som kun er noen måneder gammel til salgs, den er svært pent brukt og fremstår som ny. Selges pga overgang til ren downhill. Str M.
En svært god stisykkel med bakdemper som nærmest nullstilles ved vanlig sykling.
Nypris 17000,- Selges for 12.000,-
Kan sees/testes i Oslo.
Ta kontakt via reinert.hersleth (a) gmail.com
Spekk:
Frame: Mongoose FreeDrive W/ 145mm travel, zero stack headset and replaceable hanger
Fork: Marzocchi 44 TST2 140 mm travel, air spring, TST 5 position compression adjust, rebound and 15 mm thru axle
Rear Shock: Fox Float RP2 XV, air spring, two position
ProPedal, extra volume air can, 200x57 mm w/ 19x8 mm hardware
Crankset: Shimano FC-M542 22/32/44T Hollowtech II
Bottom Bracket: Shimano external bearing
Pedals: Crank Bros. Smarty
Front Derailleur: Shimano Deore
Rear Derailleur: New Shimano SLX, Shadow mount
Shifters: Shimano Deore 27 speed
Freewheel: SRAM PG-950 Cassette11-34T
Chain: Shimano HG73
Rims: Mavic XM317 32 hole
Front Hub: Formula 15mm thru axle
Rear Hub: Shimano Deore disc cassette
Spokes: 14g Stainless
Brake Levers: Hayes Stroker Trail w/ tool free reach adjust
Handlebar: FSA XC-300A-OS AL6061 riser 31.8x 20x 680 mm
Stem: FSA OS-190LX 6 deg. 31.8x90mm
Grips: Mongoose Lock on
Saddle: SDG Bel Air RL cromoly rail
Seat Post: 2014 alloy post with double bolt clamp, 31.6x350 mm
Les mer på
http://www.mongoose.com/usa/eng/mtn/Prod...E-Teocali-Elite
