Jamis XAM 1 stisykkel medium. Fox DHX Air 4.0 etc
Jamis XAM 1 stisykkel medium. Fox DHX Air 4.0 etc #763298 02/07/2009 06:40
prusik Offline OP
Modellen under XAM 2 som vant stisykkeltesten i terrengsykkel i fjor. Det er samme ramme.
08 mod. Nesten ikke brukt. Nypris 20 000 selges 9 500 med to sett pedaler (flate og klikk) og kortere styrestem.
Får ikke lastet opp bilde. Sender det på mail til den som er interessert.
Specifications
Frame
7005 aluminum, over-sized cartridge bearing pivots, fully active 150mm travel mp3 linkage design, Fox DHX Air 4.0 shock with 10mm hardware, replaceable derailleur hanger
Fork
Marzocchi 55 TST2, external lock-out, compression and rebound adjustable, air prelaod, 20mm QR thru-axle,
Headset
Aheadset, Zero-Stack, 1 1/8”
Wheels
Mavic XM317 eyeletted disc rims, 32H, with Shimano M475 rear disc hub, Formula DH-DC91 20mm thru-axle front, WTB 14g stainless steel spokes
Tires
WTB Prowler SS 2.3, Folding bead, 55a DNA Compound
Derailleurs
Shimano Deore XT Shadow rear, Deore front 34.9mm
Shiftlevers
Shimano Deore Rapidfire Plus-SL, 27 speed
Chain
Sram PowerChain 971 with Gold Power Link
Cassette
SRAM Powerglide 950, 9-speed, 11-34
Crankset
Shimano Deore , 44/32/22, 170mm (15”), 175mm (17-21”)
BB Set
Shimano integrated
Pedals
FPD clipless
Brakeset
Avid Juicy 3 hydraulic disc brakes with 7” front and 6” rear rotors
Handlebar
Easton EA50 31.8 MonkeyBar, 8° sweep x mid-rise x 685 wide
Stem
Easton Vice All Mountain 31.6, 6° rise x 85mm (15-17”) & 100mm (19-21”) extensions
Grips
WTB MotoTec clamp-on, DNA compound
Seat Post
Easton EA50 micro-adjust, 31.6mm x 350mm
Saddle
WTB Rocket V Comp, ABR corners, steel rails
Color
Dirt
Weight
35.00 lbs
Re: Jamis XAM 1 stisykkel medium. Fox DHX Air 4.0 etc [Re: prusik] #763718 02/07/2009 18:51
Telemark-patriot Offline
Bilde?
Re: Jamis XAM 1 stisykkel medium. Fox DHX Air 4.0 etc [Re: Telemark-patriot] #763953 03/07/2009 06:45
prusik Offline OP
Som nevnt ovenfor: Får ikke lastet opp bilde. Sender det på mail til den som er interessert.
Re: Jamis XAM 1 stisykkel medium. Fox DHX Air 4.0 etc [Re: prusik] #764546 04/07/2009 16:39
art Offline
nevermind. så størrelsen nå.
Redigert av art; 04/07/2009 16:42.
Re: Jamis XAM 1 stisykkel medium. Fox DHX Air 4.0 etc [Re: art] #764909 05/07/2009 13:45
prusik Offline OP
Solgt
