Specialized Epic Marathon, 2008 mod, selges 19000.
Specialized Epic Marathon, 2008 mod, selges 19000. #761041 27/06/2009 18:18
Barre Offline OP
Pent brukt Epic marathon selges, X-T, X-O, X-9, Magurra martha bremser, Brain demper bak.
Superrask crosscountry sykkel.
Tlf 91595761
Re: Specialized Epic Marathon, 2008 mod, selges 19000. [Re: Barre] #761259 28/06/2009 14:59
lalun Offline
Hvor står sykkelen?
Re: Specialized Epic Marathon, 2008 mod, selges 19000. [Re: lalun] #761346 28/06/2009 18:32
Barre Offline OP
Jessheim
Re: Specialized Epic Marathon, 2008 mod, selges 19000. [Re: Barre] #761565 29/06/2009 08:13
tyrileif Offline
Size?
Re: Specialized Epic Marathon, 2008 mod, selges 19000. [Re: tyrileif] #761619 29/06/2009 09:10
Barre Offline OP
Size Large, aluminium ramme.
Re: Specialized Epic Marathon, 2008 mod, selges 19000. [Re: Barre] #762476 30/06/2009 17:51
Barre Offline OP
FRAME Epic FSR M5 alloy, fully manipulated frame w/ new larger diameter/stiffer ORE DT/TT, FACT carbon shock link, sealed cartridge bearings, 100mm travel, replaceable derailleur hanger
REAR SHOCK Specialized AFR Shock w/ Flow Control valve, adjustable from HT firm to Trail Tune, air spring, adjustable rebound
FORK Fox F100 RLC, 100mm travel, rebound/compression adjust, lock out w/ threashold adjust, alloy steerer
HEADSET 1 1/8" threadless, alloy cups w/ 10mm insertion, sealed cartridge bearing
STEM Specialized adjustable rise, 31.8mm clamp, 3D forged w/CNC finish
HANDLEBARS Specialized OS XC low rise carbon bar, 640mm wide, 6 degree up, 8 degree backsweep
TAPE/GRIPS Specialized thin lock on grip, dual density
FRONT BRAKE Magura Marta, hydraulic disc, 160 and 185mm SL rotor
REAR BRAKE Magura Marta, hydraulic disc, 160mm SL rotor
BRAKE LEVERS Magura Marta, hydraulic disc
FRONT DERAILLEUR Shimano M770 XT, 34.9 clamp, bottom swing, dual pull
REAR DERAILLEUR SRAM X-0, 9-speed, mid cage
SHIFT LEVERS SRAM X-0, carbon/aluminum 9-speed trigger
CASSETTE FREEWHEEL Shimano M760 XT, 9-speed, 11-34t
CHAIN SRAM PC-971 w/ Power Link
CRANKSET New Shimano M-770 XT
CHAINRINGS 22S/32A/44A, 4 bolt 104/64mm
BOTTOM BRACKET New Shimano M770 XT
PEDALS Crank Brothers Smarty custom for Specialized
RIMS DT Swiss XR 4.2D, 24mm w/ eyelets, 28/32h
FRONT HUB Specialized Hi Lo disc, 28h CNC flange and disc mount, sealed cartridge bearing, 9mm DT RWS alloy QR
REAR HUB DT Swiss custom for Specialized, Star rachet alloy freehub w/ DT RWS 10mm alloy QR, 32h
SPOKES DT Swiss Super Comp 2.0/1.7/1.8 stainless, alloy nipples
FRONT TIRE S-Works Fast Trak LK, 26x2.0", tubeless ready, aramid bead, dual compound
REAR TIRE S-Works Fast Trak LK, 26x2.0", tubeless ready, aramid bead, dual compound
TUBES Specialized Ultralite, .6mm, presta
SADDLE Specialized Phenom, Titanium rails
SEAT POST Thomson, setback w/ 12 degree clamp, 367/410mm
SEAT BINDER Alloy collar w/ QR, 34.9mm clamp ID
NOTES Protective clear coat, derailleur hanger, reflectors, owners manual
Re: Specialized Epic Marathon, 2008 mod, selges 19000. [Re: Barre] #764001 03/07/2009 08:15
Registrert: Jan 2008
c2firm Offline
Hva er vekten på den slik den står nå?
The one who dies with most toys, wins!
Re: Specialized Epic Marathon, 2008 mod, selges 19000. [Re: c2firm] #764082 03/07/2009 10:20
Barre Offline OP
Skal prøve å fåveid idag, om jeg ikke rekker det blir det i morgen.
barre
Re: Specialized Epic Marathon, 2008 mod, selges 19000. [Re: Barre] #764168 03/07/2009 12:29
Barre Offline OP
Vekt slik den står, med crank brothers eggbeaters, 11,5 kg.
Barre
Re: Specialized Epic Marathon, 2008 mod, selges 19000. [Re: Barre] #765337 06/07/2009 10:44
Barre Offline OP
Nå senker jeg prisen til 18000kr.
Barre
Re: Specialized Epic Marathon, 2008 mod, selges 19000. [Re: Barre] #766952 08/07/2009 18:46
Barre Offline OP
Solgt!
