Svarte messingnipler
Svarte messingnipler #758518 22/06/2009 21:22
irvin Offline OP
Hepp.
Hvor i Norges land får jeg kjøpt svarte messingnipler?
1.8x12 eller 1.8x14
Skal parres med supercomp.
Re: Svarte messingnipler [Re: irvin] #758560 22/06/2009 22:30
Registrert: Sep 2001
Espen Offline
Det er ikke behov for messingnippel i 1.8, fordi en alunippel i 1.8 er like sterk som en messing i 2.0, og den holder som kjent meget godt.
Espen
(eier av 3 hjulsett med Supercomp og 1.8 alunippel)
post@espenwettre.no
Re: Svarte messingnipler [Re: Espen] #758574 23/06/2009 01:03
Hjulcompaniet Offline
Engineering does not work quite as simply as that, sadly.
One material may be equally as strong as another in a different configuration, but that does not make the other redundant.
Lots of salt on the roads in the winter can corrode alu. badly.
If you plan to keep wheels for a long time, brass nipples will hold upto adjustments better.
Aluminium nipples are also more expensive.
Re: Svarte messingnipler [Re: Hjulcompaniet] #758576 23/06/2009 04:25
Espen Offline
In theory, yes, and Brass is a better material.
In real life, I have never experienced corrotion, or problems with adjustment.
e
post@espenwettre.no
Re: Svarte messingnipler [Re: Espen] #758663 23/06/2009 07:47
I realized your answer was subjective, but I didn't realize it was that subjective.
I have seen corroded nipples. I have even known of wheels in storage to collapse because of it.
I have also seen more alloy nipples damaged by subsequent adjustment than brass.
There is no such thing as a better material. They just have different properties.
Compromise is made in the selection of either.
Re: Svarte messingnipler [Re: Hjulcompaniet] #758668 23/06/2009 07:59
Men finnes det virkelig svarte messingnippler?
Re: Svarte messingnipler [Re: larsb] #758680 23/06/2009 08:18
Re: Svarte messingnipler [Re: Hjulcompaniet] #758748 23/06/2009 09:51
Espen Offline
You'r right.
Brass is a better material, and brassnipples are better than alloy nipples, but my experience with alloy is wery good, so I think they are good enough. They are lighter also.
I do'nt ride too much on salted roads. Good lubrication between spoke and nipple have made adjustments easy, even after many years.
e
post@espenwettre.no
Re: Svarte messingnipler [Re: Espen] #758964 23/06/2009 15:39
JB. Offline
Hold deg til messing. Min mening(TM) er at alunippler er noe forbanna dritt som kun er nødvendig på ritthjul hvor hvert gram teller.
I was just riding along...
Re: Svarte messingnipler [Re: JB.] #759049 23/06/2009 18:55
irvin Offline OP
Alltid flott med diskusjon, men jeg får vel ikke akkurat svar på det jeg lurer på?
Re: Svarte messingnipler [Re: irvin] #759059 23/06/2009 19:12
syklisten Offline
http://www.jensonusa.com/store/product/SN308A00-Dt+Brass+Nipples.aspx
Bør havne under 200kr grensa.
Ikke i Norge, men siden deler ( importør ) ikke har dem, så er det vel ingen andre i Norge som har heller.
Re: Svarte messingnipler [Re: syklisten] #759212 24/06/2009 00:14
irvin Offline OP
Jeg er klar over alternativer i utlandet. Målet var å skaffe de fort som svint, og nei, det ender ikke opp under 200 kroner, selv med billigste frakt. ICON_SMILE
Re: Svarte messingnipler [Re: irvin] #759227 24/06/2009 06:09
Registrert: Jun 2005
FNS Offline
Hør med Racing Depot, de importerer også litt fra DT.
Frode N
Re: Svarte messingnipler [Re: irvin] #759241 24/06/2009 06:56
Registrert: May 2005
Vanilla Ninja Offline
Sitat: irvin
Det har ingenting å si hvor mye frakta koster.
Hvis varen koster under 200 kroner skal du ikke betale mva.
Hvis varen koster over 200 kroner må du betale mva på varens verdi og frakta.
Re: Svarte messingnipler [Re: Vanilla Ninja] #760714 26/06/2009 15:03
irvin Offline OP
OK.
Nipler bestilt. Tidligere har jeg momset på frakt, selv på varer under 200 kroner.
Jeg holder deg ansvarlig, Vanilla Ninja. ICON_SMILE
