"Oldschool" Durace i Paris-Roubaix 2009
"Oldschool" Durace i Paris-Roubaix 2009 #708547 13/04/2009 11:16
Registrert: Sep 2004
aambo Offline OP
Ser ut som oksen fra Grimstad bruker gamle Durace skifter med utvending wire-føring
http://cyclingnews.com/photos/2009/apr09...90412ispa-0154b
Begynner da å lure på om den nye Durace gruppas innvending kabelføring ikke fungerer så bra.
Re: "Oldschool" Durace i Paris-Roubaix 2009 [Re: aambo] #708568 13/04/2009 12:13
erling Offline
Det er flere på Cervelo som synes den gamle gruppa girer bedre og helst vil kjøre med den.
Re: "Oldschool" Durace i Paris-Roubaix 2009 [Re: erling] #708719 13/04/2009 18:13
Dybersh Offline
Har hørt rykter om at Thor ville ha den gamle under helvete i nord fordi den har store hendler å holde i.
Re: "Oldschool" Durace i Paris-Roubaix 2009 [Re: Dybersh] #708790 13/04/2009 19:26
cannondalist Offline
Thor med flere har kjørt med gamle 7800 i de fleste klassikerene i år. Hva som er grunnen deriomt???
Re: "Oldschool" Durace i Paris-Roubaix 2009 [Re: cannondalist] #708926 14/04/2009 07:05
Registrert: Mar 2002
kjull Offline
Fra http://www.cyclingnews.com/tech.php?id=/tech/2009/news/04-04
Cervélo Test Team have a diverse range of sponsors and suppliers – including Škoda, Zipvit, 3T, Rotor, Speedplay, Castelli, fi’zi:k, 2XU, Quarq, Catlike, Elite, Nokon, Morgan Blue, Reporter and Sportblam – though one conspicuous omission is a groupset supplier. In spite of the greater financial burden, the team prefer to purchase their own for greater freedom of choice.
In fact, though the team have been running Shimano Dura-Ace groupsets this whole season, they have notably swapped generations, having first started with 7800, then switching to 7900 only to return back to 7800.
“We are using the 7800 group simply because the shifting is better on the Rotor rings,” said Campana. “We have a lot of bikes with the 7800, and we built up some bikes with the 7900, but the riders’ choice is actually to turn back to the 7800 because it shifts better.”
Rotor is the official chainset supplier but recent months have witnessed changes there as well with substitutions from both SRAM and FSA seen on some bikes at various races such as the Tour of California.
Re: "Oldschool" Durace i Paris-Roubaix 2009 [Re: kjull] #708986 14/04/2009 08:49
Svart på hvitt...
Re: "Oldschool" Durace i Paris-Roubaix 2009 [Re: kjull] #709201 14/04/2009 14:05
Registrert: Dec 2006
beast666 Offline
Sitat: kjull
Hvis det er slik at de bruker Rotor Q-rings skjønner jeg at de må ha 7800 framskifteren. Framskifteren, ved bruk av Q-rings, må stå kjempelangt over største skiva, de er jo ovale. DA 7900 har jo ikke trimfunksjon på framskifter som den gamle 7800 har, noe som man må ha på Q-rings. Når det er sagt er 7900 den desidert beste framskifteren til dags dato uansett merke.
Re: "Oldschool" Durace i Paris-Roubaix 2009 [Re: beast666] #709204 14/04/2009 14:10
erling Offline
Kan jeg bruke den sammem med SRAM RED?
Re: "Oldschool" Durace i Paris-Roubaix 2009 [Re: erling] #709213 14/04/2009 14:22
beast666 Offline
Sitat: erling
Vet ikke men den kan ikke brukes med 7800 grep.
Re: "Oldschool" Durace i Paris-Roubaix 2009 [Re: beast666] #709214 14/04/2009 14:23
beast666 Offline
Tok faktisk feil 7900 skifter kan brukes med Q-rings, Haussler kjørte P-R med denne kombo. Legg merke til hvor høyt skifteren står.
http://www.cyclingnews.com/tech.php?id=/..._Haussler_crank
Redigert av beast666; 14/04/2009 14:24.
Re: "Oldschool" Durace i Paris-Roubaix 2009 [Re: beast666] #709246 14/04/2009 15:31
erling Offline
Kan jeg bruke SRAM RED hendler i kombo med DA7900 fremskifter? Eller blir det trøbbel med vaiertrekket.
Re: "Oldschool" Durace i Paris-Roubaix 2009 [Re: erling] #709262 14/04/2009 15:59
MEN...Mange av gutta i highroad brukte også 7800, og de er ikke sponsa av rotor...
Re: "Oldschool" Durace i Paris-Roubaix 2009 [Re: erling] #709289 14/04/2009 16:58
beast666 Offline
Sitat: erling
http://forum.cyclingnews.com/showthread.php?t=68
Re: "Oldschool" Durace i Paris-Roubaix 2009 [Re: cannondalist] #709293 14/04/2009 17:01
beast666 Offline
Sitat: cannondalist
De er ihvertfall så smarte at de bruker shimano
Re: "Oldschool" Durace i Paris-Roubaix 2009 [Re: beast666] #709333 14/04/2009 17:54
TAHL Offline
Så da er vel de to beste dumme da.
Siden de kjørte med Campa.
Bare for å provosere, etter at det hadde skilt seg ut 6 mann var det 2 stykker som falt (Hoste og Van Summeren kjøre inn i Flecha). Det var også de to eneste som ikke brukte Campa. Tilfeldig?
Re: "Oldschool" Durace i Paris-Roubaix 2009 [Re: TAHL] #709349 14/04/2009 18:13
beast666 Offline
Sitat: TAHL
Helt riktig, tilfeldig og litt heldig at noen belgiske tilskuere hadde helt diesel på avtalt sted.
Re: "Oldschool" Durace i Paris-Roubaix 2009 [Re: beast666] #709353 14/04/2009 18:15
beast666 Offline
Sitat: beast666
Sitat: TAHL
Beklager det var ikke diesel
http://www.vg.no/pub/vgart.hbs?artid=552551
Re: "Oldschool" Durace i Paris-Roubaix 2009 [Re: beast666] #709504 14/04/2009 20:35
Registrert: Oct 2006
Yeti-man Offline
Sitat: beast666
Nå ja. Jeg Synes Campa Record Titanium er bra, Shimano 600 Ultegra (6400) er meget bra osv. Frontskiftere er ikke "hokus-pokus" teknologi. Men å få det til å funke på Rotor/Biopace er ikke lett.
Re: "Oldschool" Durace i Paris-Roubaix 2009 [Re: Yeti-man] #709897 15/04/2009 13:41
beast666 Offline
Sitat: Yeti-man
Sitat: beast666
Helt riktig ikke noe hokus pokus, men bare så synd at kun Shimano har skjønt at topgruppa bør være TOP OF THE LINE og ikke noe lett og ubrukelig
Her er sykkelen til Franzoi med Chorus framskifter IKKE Record
Og her er et lite utvalg av Sram Force framskiftere remerket med med Red merker og som vi ser Cancellara bruker Force
Re: "Oldschool" Durace i Paris-Roubaix 2009 [Re: aambo] #711519 17/04/2009 20:02
Pete Offline
Popcornansvarlig
Popcornansvarlig
Dette blir mye synsing, men jeg tror vi kan trekke opp tre hovedgrunner til at det brukes 7800-komponenter i proffritt:
1) Mange av disse gutta har 5 års erfaring (og kanskje vel så det) med 7800-serie komponenter og for ritt som Paris-Roubaix kan det vel tenkes at man safer ved å bruke "kjente og kjære" komponenter
2) Kompatibilitetsproblemer med andre komponenter: FSA, Rotor, SRM, osv. gjør at man får bedre ytelse med 7800-girdeler, girspaker og kranker. 7900-gruppa er i høyeste grad utviklet som et integrert system - på både godt og vondt - sammen funker det imponerende bra, men å blande inn tredjepartskomponenter kan gi uforutsigbare resultater
3) Tilgjengelighet: Lag som Cervelo (og tidligere CSC/Saxo Bank) kjøper Shimano-komponentene på vanlig måte og må stille seg i køen sammen med andre som vil handle. Sponsa lag som Rabobank, Columbia, Skil-Shimano og FdJ får nye varer først.
Recovery-mode
Re: "Oldschool" Durace i Paris-Roubaix 2009 [Re: Pete] #711628 17/04/2009 22:17
Yeti-man Offline
Sitat: Pete
Kompabilitet har da alltid vært et fortrinn blandt komponenter (generelt).
Re: "Oldschool" Durace i Paris-Roubaix 2009 [Re: beast666] #711677 18/04/2009 06:57
parkprest Offline
Kort OT - hvilket pedalsystem er dette ?
pedalistisk !
Re: "Oldschool" Durace i Paris-Roubaix 2009 [Re: parkprest] #711686 18/04/2009 07:23
TAHL Offline
Pedalen var vel første gagn brukt av Fabian Cancellara for et par å siden. Det er en lollipopp pedal uten fyllet.
http://www.cyclingnews.com/tech.php?id=/photos/2009/tech/features/paris_roubaix209/PR_Saxo_pedal
Re: "Oldschool" Durace i Paris-Roubaix 2009 [Re: beast666] #713646 21/04/2009 05:57
asbjorjo Offline
Sitat: beast666
Måtte du lete lenge for å finne den? Jeg tok en kjapp titt på bildene cyclingnews har av sykler fra P-R, og de fleste (alle jeg gadd se på) der (inkludert Boonen og Pozzato) kjørte med Record forskiftere. Boonen kjørte riktignok på den gamle gruppa, men det ser ikke ut til å være voldsom forskjell.
Nå regner jeg selvsagt med at du vet bedre enn både Boonen, Pozzato og mekanikerne deres når det gjelder TOP OF THE LINE forskiftere. ICON_WINK
Re: "Oldschool" Durace i Paris-Roubaix 2009 [Re: asbjorjo] #713748 21/04/2009 08:21
Yeti-man Offline
Og så vare det (husker ikke hva han hete) SRAM Red som ikke finnes med lange krankarmer, hvor de endte opp med Rival armer i stedet. Tror ikke "top of the line" spiller så veldig avgjørende rolle dersom du snakker med sykkelisten selv eller hans mekaniker. Man tager det man haver og som fungerer. Noe annet er om du spør sponsoren...
