CK's knefall !
CK's knefall ! #689498 04/03/2009 13:21
Registrert: Dec 2006
Carsten Offline OP
http://www.light-bikes.de/website/new/wp-content/uploads/2009/03/inset.jpg
De har vel tidligere uttalt at integrert ikke er veien å gå !
http://sykkel.hasle-loren.no/
Re: CK's knefall ! [Re: Carsten] #689500 04/03/2009 13:26
M@rtin Offline
MaBose Infotainment
MaBose Infotainment
Nei, harru sett!
Også offisielt: http://chrisking.com/
Sitat: ZeKing
What is InSet™? Is it an internal headset?
InSet™ is a Chris King® headset, plain and simply stated. User-serviceable stainless steel bearings, aluminum cups, bearing cap and stem cap. It’s a member of the NoThreadSet™ family with the same ten-year warranty. While it may look different than a standard King NoThreadSet™, it adheres to Chris' firm standing that both bearings should be fixed in place. It’s a Chris King® headset but with a different attachment style. It can best be described as a low-stack height headset. We’ve said for years that we would not produce a loose,drop-in bearing style headset. Still saying it.
Martin
Re: CK's knefall ! [Re: Carsten] #689502 04/03/2009 13:27
Registrert: Jul 2005
Thorst Offline
Mer på Chris King sine hjemmesider
Edit: Argh... slått på målstreken av en tysk trønder ICON_SMILE
Redigert av Thorst; 04/03/2009 13:29.
- Espen -
"Man angrer aldri på en dårlig tur, bare de gode man går glipp av"
Re: CK's knefall ! [Re: Thorst] #689504 04/03/2009 13:36
SnorreL Offline
Gammelt nytt dette karer. Vært omtalt på MTBR i lang tid.
Re: CK's knefall ! [Re: Carsten] #689506 04/03/2009 13:41
Hjulcompaniet Offline
Their March 2002pdf (now html) on headsets says that they are against machine bearings having direct contact with the frame, specifically in the manner applied with integrated headsets.
EDIT:
Essentially they are saying that these bearings move around, and that that is not good.
What CK have released here is different.
Re: CK's knefall ! [Re: Carsten] #689509 04/03/2009 13:43
Registrert: Aug 2001
Ole Offline
Sitat: Carsten
Dette er jo ikke integrerte lager, det er interne.
Men hvorfor i all verden har de ikke laget et internt reducer-lager for 1.5" til 1 1/8? Det er jo et hav av sykler med 1.5" styrerør, men ganske så få gafler med 1.5" kronerør...
Ole.
Re: CK's knefall ! [Re: Ole] #689511 04/03/2009 13:44
RazeFaze Offline
De vil vel at koppene skal lyse Chris King logo?
Happy Trails!
Jørgen
Re: CK's knefall ! [Re: RazeFaze] #689512 04/03/2009 13:44
Ole Offline
Jammen, det gjør jo ikke de nye integrerte lagerne heller?
Argh!
Hjem å klemme på R1 nå, så blir jeg glad igjen.
Ole.
Re: CK's knefall ! [Re: Ole] #689515 04/03/2009 13:48
RazeFaze Offline
Men har du sett nye gjennomgåendeaksling med 142mm bredde?
Turner sier de kommer med det på RFX... King er visst med.
Spennende, eller bare plagsomt? Jeg er blandet i dette.
Skal være 135mm i praksis med gjennomgående 12mm aksling, og noen endekopper som gjør montering enklere ala sånne "hakk" på gafler som navet stopper i når man monterer aksling.
Nå kan du gå hjem å være glad, og fundere mer :-)
Happy Trails!
Jørgen
Re: CK's knefall ! [Re: RazeFaze] #689517 04/03/2009 13:54
Registrert: Jan 2002
gauter Offline
Sitat: RazeFaze
Ikke heeeeelt ulikt Syntace X-12 ?
Nuvel, en liten avsporing...
Redigert av gauter; 04/03/2009 13:55. Rediger grunn: Beklager avsporinga!
Gaute
Re: CK's knefall ! [Re: gauter] #689520 04/03/2009 13:57
Fingers on buzzers. round 2..
Certainly not easy to see through a lot of this stuff.
Still a lot to be played out on headsets. I read that CK doc many times when it came out, wondering what kind of position they were putting themselves in. Not easy to get a grip on. And all the different headset types don't help make anything clearer either.
Wish I had an R1...
Re: CK's knefall ! [Re: Hjulcompaniet] #689524 04/03/2009 14:02
SnorreL Offline
Dave Turner om 142mm:
"142 will kill 135. The GREAT thing is that all the 'good' hub makers have the ability to make upgrade kits and convert your current stuff to the new spec for a nominal cost. We, the industry has had the same kind of set up on Lyrics and 36s and Totems for years, put wheel in fork and it sits there ready for the axle. Why not the rear? Even the bolted rear hubs with a QR drop out will not offer the total grip of a couple 12mm holes thru plate."
Er Dave Turner positiv er jeg også positiv. Han er tross alt sjefen.
Edit: Svar til razefaze sin post ikke Hjulcompaniet
Redigert av SnorreL; 04/03/2009 14:39. Rediger grunn: DT er sjefen
Re: CK's knefall ! [Re: Hjulcompaniet] #689530 04/03/2009 14:17
Ole Offline
Sitat: Hjulcompaniet
Wish I had an R1...
U can squeeze my Rs any time!
Ole.
Re: CK's knefall ! [Re: SnorreL] #689531 04/03/2009 14:18
I'm using a screen reader, and the music is too loud here to get what that one was about. Have to get back to you...
No, I'm not really using one, and there is no music today. Was that a pin dropping?
Definately room for improvement back there...
Re: CK's knefall ! [Re: gauter] #689561 04/03/2009 15:56
RazeFaze Offline
Sitat: gauter
Sitat: RazeFaze
Har skjønt at det er hvor det er hentet fra ja, men DT vil lage egen dropout og girhenger da.
Redigert av RazeFaze; 04/03/2009 15:56.
Happy Trails!
Jørgen
