Lager en pakke av gaffel og bakdemper her.
Altså: 2009 888 rc3
"- 200mm Travel
- RC3 VA (Rebound & Hi-Lo Auto Compression Adj, Volume Adj)
- Mechanical Preload
- Aluminum Steer Tube
- 38mm Alloy Stanchions
- 8” Post Mount (Max Disc 9”)
2009 Roco WC (241,3 eye to eye- 3" travel)
"- Ext. adjustable High Speed Compresssion
- Ext. adjustable Rebound
- Ext. adjustable bottom-out resistance via air valve
- Spring Preload"
Begge to, samlet: kr. 8 500,- Ferdig prutet.
Som sagt, ring ( 90 67 56 79) eller send mail
( ole.hall@gmail.com )
