Specialized Epic Maraton 2008, Selges 24000 kr
Specialized Epic Maraton 2008, Selges 24000 kr #599955 27/08/2008 13:35
Barre Offline OP
Jeg må desverre selge min 10 mnd gamle Epic Maraton.
Pent brukt.
Ring på 915 95 761
Ramme str L.
http://www.specialized.com/bc/SBCBkModel.jsp?spid=33457
FRAME Epic FSR M5 alloy, fully manipulated frame w/ new larger diameter/stiffer ORE DT/TT, FACT carbon shock link, sealed cartridge bearings, 100mm travel, replaceable derailleur hanger
REAR SHOCK Specialized AFR Shock w/ Flow Control valve, adjustable from HT firm to Trail Tune, air spring, adjustable rebound
FORK Fox F100 RLC, 100mm travel, rebound/compression adjust, lock out w/ threashold adjust, alloy steerer
HEADSET 1 1/8" threadless, alloy cups w/ 10mm insertion, sealed cartridge bearing
STEM Specialized adjustable rise, 31.8mm clamp, 3D forged w/CNC finish
HANDLEBARS Specialized OS XC low rise carbon bar, 640mm wide, 6 degree up, 8 degree backsweep
TAPE/GRIPS Specialized thin lock on grip, dual density
FRONT BRAKE Magura Marta, hydraulic disc, 160 and 185mm SL rotor
REAR BRAKE Magura Marta, hydraulic disc, 160mm SL rotor
BRAKE LEVERS Magura Marta, hydraulic disc
FRONT DERAILLEUR Shimano M770 XT, 34.9 clamp, bottom swing, dual pull
REAR DERAILLEUR SRAM X-0, 9-speed, mid cage
SHIFT LEVERS SRAM X-0, carbon/aluminum 9-speed trigger
CASSETTE FREEWHEEL Shimano M760 XT, 9-speed, 11-34t
CHAIN SRAM PC-971 w/ Power Link
CRANKSET New Shimano M-770 XT
CHAINRINGS 22S/32A/44A, 4 bolt 104/64mm
BOTTOM BRACKET New Shimano M770 XT
PEDALS Crank Brothers Smarty custom for Specialized
RIMS DT Swiss XR 4.2D, 24mm w/ eyelets, 28/32h
FRONT HUB Specialized Hi Lo disc, 28h CNC flange and disc mount, sealed cartridge bearing, 9mm DT RWS alloy QR
REAR HUB DT Swiss custom for Specialized, Star rachet alloy freehub w/ DT RWS 10mm alloy QR, 32h
SPOKES DT Swiss Super Comp 2.0/1.7/1.8 stainless, alloy nipples
FRONT TIRE S-Works Fast Trak LK, 26x2.0", tubeless ready, aramid bead, dual compound
REAR TIRE S-Works Fast Trak LK, 26x2.0", tubeless ready, aramid bead, dual compound
TUBES Specialized Ultralite, .6mm, presta
SADDLE Specialized Phenom, Titanium rails
SEAT POST Thomson, setback w/ 12 degree clamp, 367/410mm
SEAT BINDER Alloy collar w/ QR, 34.9mm clamp ID
NOTES Protective clear coat, derailleur hanger, reflectors, owners manual
Redigert av Barre; 27/08/2008 20:06.
Re: Specialized Epic Maraton 2008, Selges. [Re: Barre] #601213 29/08/2008 17:20
Barre Offline OP
Jeg får ikke redigert annonsen, men det ligger bedre bilder på Finn.no
Barre.
Redigert av Barre; 29/08/2008 17:23.
Re: Specialized Epic Maraton 2008, Selges. [Re: Barre] #602551 01/09/2008 20:28
Barre Offline OP
SOLGT.
Re: Specialized Epic Maraton 2008, Selges. [Re: Barre] #602574 01/09/2008 20:57
JonahHex Offline
Leppedefekt kåbbåj
Leppedefekt kåbbåj
Ikke verst, grom sykkel ICON_SMILE
