Selger nå min lekne AllTerrainBike til fordel for en noe raskere sykkel. Den er brukt ca 3mnd og fremstår nesten som ny. Ingen deler er skiftet ut. Den er str 17". Skikkelig moro sykkel, men jeg har bare råd til å ha en og trenger en raskere allrounder;) Denne er mer en lekesykkel i jord og skau;)
Specialized har følgende å si om sykkelen:
ATB - All Terrain Bike
SOLID AS A... From the mean streets to demanding dirt trails, the Hardrock® delivers performance and durability in a package that looks good and is built to be solid as a rock.
Inside Tech
Building a hardtail frame that'll last a lifetime and is still light enough to ride isn't easy, but in the 25-plus years that we've been building mountain bikes, we've learned a thing or two. For the Hardrock we use a 100% proprietary, butted A1 alloy tubeset that is light, but still tough because we put the material only where it needs to be. Optimized Radius Engineering top and down tubes add even more brawn and still manage to shave weight.
Size 17
Seat Tube Length - Center to Top 432mm
Top Tube Length (Horizontal) 590mm
Top Tube Length (Actual) 569mm
Chainstay Length 427mm
Bottom Bracket Height - Low Setting 300mm
Seat Tube Angle (Actual) - Low Setting 73°
Head Tube Angle - Low Setting 70°
Wheel Base 1076mm
Standover Height 758mm
Head Tube Height 120mm
Handlebar Width 640mm
Stem Length 75mm
Crank Length 170mm
Seatpost Length 350mm
TT is measured horizontally from center of HT to center of ST
Spesifikasjoner:
FRAME A1 Premium Aluminum, double-butted, ORE DT, externally relieved HT, reinforced disc mount, forged dropouts w/ replaceable 98954020 alloy hanger, disc only
FORK SR Suntour SF7-XCM, 100mm travel, 12": 80mm, 30mm Hi-Ten stanchions and steerer, one piece alloy lower, coils spring mcu w/ preload adj., spring assisted seals, custom paint/graphic, disc only
HEADSET 1 1/8" threadless
STEM Specialized 3D forged alloy, two bolt, 25.4mm, 10 degree rise
HANDLEBARS Alloy 25.4mm, 640mm wide, 38mm rise, 8 degree back, 6 degree up sweep, 3.2mm thick
TAPE/GRIPS Specialized Enduro, dual density Kraton
FRONT BRAKE Avid BB-5, mechanical disc, 6" G2 Clean Sweep rotor
REAR BRAKE Avid BB-5, mechanical disc, 6" G2 Clean Sweep rotor
BRAKE LEVERS Shimano EF-50, integrated
FRONT DERAILLEUR Shimano Altus FD-M310-6, top swing, 34.9mm clamp
REAR DERAILLEUR Shimano Acera RD-M340
SHIFT LEVERS Shimano EF-50
CASSETTE FREEWHEEL Shimano HG-40, 8-speed, 11-32t
CHAIN KMC X8, 1/2" x 3/32" w/ reusable Missing Link
CRANKSET SR Suntour XCM-T312, replaceable rings, Octalink spline
CHAINRINGS 42S/32S/22S
BOTTOM BRACKET Shimano BB-ES25, Octalink spline, cartridge bearing, 68 x 118mm for 50mm chainline
PEDALS Steel cage, composite body, 9/16"
RIMS Specialized/Alex HRD 26, double wall disc
FRONT HUB Specialized Hi Lo disc, 32h, CNC flange and disc mount, polished races, alloy QR
REAR HUB Specialized Hi Lo disc, cassette, 32h, CNC flanges and disc mount, polished races, alloy QR
SPOKES 1.8mm (15g) stainless
FRONT TIRE Specialized Resolution, 26x2.1", 30TPI, wire bead
REAR TIRE Specialized Resolution, 26x2.1", 30TPI, wire bead
TUBES Specialized schraeder valve
SADDLE Specialized Aggro, kevlar sides, front and rear bumpers, 143mm width
SEAT POST Specialized alloy two bolt micro adjust head, 30.9mm
SEAT BINDER Specialized alloy w/ QR
NOTES Chain stay protector, reflectors, clear coat, owners manual
Hadde tenkt meg 4000,- for den. Nypris er 5499,-
