Selger min Enduro, brukt i 2 mnd. DT Swiss 6.10 bakhjul med Intense gummi, ODI holker. Sykkelen ligger også på finn, med finnkode: 14106045.Ellers kan sykkelen sees i Oslo etter avtale. Specialized sin agent i Norge valgte å ikke ta inn denne modellen, da de heller selger modellen under samt toppmodellen PRO Carbon! Så til sammenligning koster denne Expert`n 30 tusen Danske Kroner! Her kan du kjøpe en helt RÅ sykkel som tar deg like godt opp som ned. Få konkurrenter dekker dette på lik linje med Specialized og Enduro!!. Størrelsen er Large!
FRAME Enduro M5 alloy, fully manipulated frame w/ ORE TT and DT, forged HT, sealed cartridge bearing pivots, ISCG mount adj. geometry, replaceable derailleur hanger, 150mm travel
REAR SHOCK Specialized AFR Shock w/ Spike valve, air spring, adjustable rebound and low speed compression, 7.875x2.25"
FORK Specialized Future Shock e150SL, dual crown w/ integrated stem, 150mm travel, rebound, compresion and travel adjust, 25mm thru axle, alloy steerer
HEADSET 1 1/8" threadless, alloy cups w/ 10mm insertion, sealed cartridge bearing
STEM Specialized Future Shock, 31.8mm clamp integrated w/ fork
HANDLEBARS Specialized Enduro mid rise bar, 2014 alloy, 31.8mm, 6 degree up, 9 degree backsweep, 660mm wide
TAPE/GRIPS Specialized thin lock on grip, dual density
FRONT BRAKE Custom Avid Ultimate 7, hydraulic disc, 203mm rotor
REAR BRAKE Custom Avid Ultimate 7, hydraulic disc, 185mm rotor
BRAKE LEVERS Custom Avid Ultimate 7, hydraulic disc
FRONT DERAILLEUR Shimano M581 LX, DMD, top swing, dual pull
REAR DERAILLEUR SRAM X-0, 9-speed, mid cage
SHIFT LEVERS SRAM X-9, aluminum 9-speed trigger
CASSETTE FREEWHEEL Shimano HG-50, 9-speed, 11-34t
CHAIN SRAM PC-971 w/ Power Link
CRANKSET Shimano M762 XT custom for Specialized
CHAINRINGS 22S/32A/44A, 4 bolt 104/64mm
BOTTOM BRACKET Shimano M762 XT custom for Specialized
PEDALS N/A
RIMS DT Swiss custom for Specialized X420, 24mm w/ eyelets, 32h
FRONT HUB Specialized disc, 25mm thru axle, 32h
REAR HUB DT Swiss custom for Specialized 370 w/ DT RWS QR, 32h
SPOKES DT Swiss Competition 1.8/1.6mm
FRONT TIRE S-Works Eskar, 26x2.3", 120 TPI, aramid tubeless ready bead, dual compound
REAR TIRE S-Works Eskar, 26x2.3", 120 TPI, aramid tubeless ready bead, dual compound
TUBES Specialized Ultralite, .6mm, presta
SADDLE Specialized Enduro, hollow Cr-Mo rails, SL foam
SEAT POST 2014 butted alloy, single bolt setback, 30.9 x 350/400mm
SEAT BINDER Alloy collar w/ QR, 34.9mm clamp ID
http://www.finn.no/finn/bap/object?finnkode=14106045
