Hi!
I have for sale brand new Fox van36 rc2 2007 fork.
Price is: 4900 nok
From Slopes to Singletrack, the 36mm Van can do it all. The RC2 patent-Pending Position Sensitive Damper has a FIT Cartridge, 36mm Stanchions and a 20mm Stepped Thru-Axle. Add to this Separately-Adjustable High and Low-Speed Compression Damping Circuits, Adjustable Rebound, and a healthy 160mm of Coil-Sprung Travel and you have a Fork which can handle anything you can throw at it. From Huge Air (with Hard Landings) to Trail Trashing & Stutter Bumps, the 36mm Van sucks it all up and makes the World Smooth. The steer tube in uncut.
For All Mountain, Downhill & Freeriding
Travel: 6.3" (160mm)
FIT Damping
Coil Spring
External Coil Spring Preload Adjustment
External Rebound Adjustment
External Low-Speed Compression Adjustment
External High-Speed Compression Adjustment
Internal Hydraulic Bottom-Out Adjustment
Standard 1 1/8” Steerer
Weight: 5.53 lbs (2.51 kg)
Colour: Black
contact me:
MSN barrettki@wp.pl or just call 99876511
