Hi!
I have for sale following:
1)2007 Banshee Scratch Frame size Medium
Come with everything seen in pictures. FSA Pig headset, BB converter, Easton seat post and clamp, all mounting hardware included.
[color:#FF0000]Price drop from 5500 nkr to 5000 nkr !!![/color]
2)2007 brand new Fox van 36 rc2
From Slopes to Singletrack, the 36mm Van can do it all. The RC2 patent-Pending Position Sensitive Damper has a FIT Cartridge, 36mm Stanchions and a 20mm Stepped Thru-Axle. Add to this Separately-Adjustable High and Low-Speed Compression Damping Circuits, Adjustable Rebound, and a healthy 160mm of Coil-Sprung Travel and you have a Fork which can handle anything you can throw at it. From Huge Air (with Hard Landings) to Trail Trashing & Stutter Bumps, the 36mm Van sucks it all up and makes the World Smooth. The steer tube in uncut.
For All Mountain, Downhill & Freeriding
Travel: 6.3" (160mm)
FIT Damping
Coil Spring
External Coil Spring Preload Adjustment
External Rebound Adjustment
External Low-Speed Compression Adjustment
External High-Speed Compression Adjustment
Internal Hydraulic Bottom-Out Adjustment
Standard 1 1/8” Steerer
Weight: 5.53 lbs (2.51 kg)
Colour: Black
Price drop from 6500 nkr to 6000 nkr!!!3)2006 used Fox van 36 rc2 in realy good condition.
Description:
Weight 2.47 kg
Travel 6.3 inches/ 160 mm
Adjustments
• Coil spring preload
• Rebound
• Low speed compression
• High speed
compression
• Position sensitive
damper
Lower Legs
Disc Only
20mm Axle
Spring Coil
Features
• Proprietary adjustable position sensitive damper
• Stepped 20mm thru-axle: Allows lower leg to settle into a lower
friction point
• Standard 1 1/8" steerer
• Integrated disc brake guide
Tired of pedaling that heavy freeride fork to the top of your favorite ride? Longing for some bar innendørssvettingpåenergometersykkel freedom at the resort? Look no further than the 36 VAN. Boasting oversized 36mm upper tubes, FOX's proprietary position sensitive damper, 160mm of travel, and a super plush coil spring - the 36 VAN is ready for serious abuse. But don't let its stature fool you, at 5.5 pounds the 36 VAN will help you fly both up and down the hill.
Price drop from 4500 nkr to 4000 nkr!!!4)2006 Fox DHX 5.0 Air excelent condition.
specification:
http://foxracingshox.com/fox_bicycle/bike_index.htmPrice drop from 3000 nkr to 2500 nkr!!!5)2007 brand new Troy Lee Design helmets.
2007 D2 Composite Rustic Gold 1x(XL/XXL)
Price drop from 2000 nkr to 1800 nkr!!!
2007 D2 Composite Hotwheels 1x(XL/XXL)
2007 D2 Carbon Classic 1x(M/L)
price drop from 3000 nkr to 2800 nkr!!!
more info:
http://www.troyleedesigns.com/http://www.modulez.no/olk36/For more info or questions contact me:
MSN barrettki@wp.pl or call 99876511 (Tromso)
