VUrderer å selge denne: str 18. 2007 mod. noen oppgraderinger. Thomson elite stepinn. xtr pedaler. Demperen er 100 mm.
GT zaskar expert pro
# Frame: GT Hydroformed Kinesis Superlight Custom Tube Set
w/Machined Headtube, Disc Compatible
# Fork: RockShox Reba SL, 85mm Travel w/Positive & Negative Air Chambers, Rebound & Compression Adjustment plus Floodgate Release
# Cranks: Shimano Deore XT, 2-Piece Design, 44/32/22T li>Bottom Bracket: Shimano XT w/Outboard Oversized Bearings
# Pedals: Crank Bros Candy C
# Front Derailleur: Shimano XT
# Rear Derailleur: Shimano New XT Non Rapid Rise
# Shifters: Shimano New XT Trigger
# Cassette: Shimano XT 9-Speed Index, 11-32T
# Chain: Shimano 9-Speed
# Front Hub: Shimano XT Disc
# Rear Hub: Shimano XT Disc
# Rims: WTB Laser Disc , Double-Walled
# Tyres: Kenda Karma, 120 TPI w/Kevlar Bead & DTC Compound, 26"x2.0"
# Front Brake: XT Disc
# Rear Brake: XT Disc
# Brake Levers: Shimano XT (Separate)
# Handlebar: TruVativ XR XC 6061 Bars w/6 Degree Sweep, 680mm Wide
# Headset: FSA Threadless
# Stem: TruVativ XR Cold-Forged, 4-Bolt Stem w/Laser Etching
# Grips: GT Lock Down
# Saddle: SDG Bel Air RL
# Seat Post: TruVativ 2-Bolt
# Seat Clamp: GT Aluminium QR
noen som kan hjelpe meg med å laste opp bilde?
