Selger min Specialized Stumpjumper FSR Pro Carbon (rammesett). Dette er en av norges råeste sti sykler, som gir utrolig mye sykkelglede i tekniske løyper. Den beste sykkelen jeg noen gang har syklet på!
Ta kontakt på: eystein@stians-sport.no hvis spørsmål
http://www.specialized.com/bc/SBCEquipPo...del=Stumpjumper Prisen på rammesettet er 20000,-
Med rammesett medfølger:
Ramme: FRAME FSR FACT M9 carbon front triangle, Az1 construction, M5 rear triangle, full cartridge bearing pivots and rear shock mount, Magnesium shock link, carbon reservoir mount, 120mm travel
Bakdemper Specialized AFR Shock w/ Flow Control valve, adjustable Trail Tune range, adjustable rebound, 7.625x1.625"
Gaffel Fox Talas RLC, 100-140mm, rebound adj, alloy steerer
Styrelager 1 1/8" threadless, integrated alloy cups, sealed cartridge bearing
Setepinne Tompson alloy
Sykkelen kan også selges komplett (pris: 27000,-)
Da med følgende utstyr:FRAME FSR FACT M9 carbon front triangle, Az1 construction, M5 rear triangle, full cartridge bearing pivots and rear shock mount, Magnesium shock link, carbon reservoir mount, 120mm travel
REAR SHOCK Specialized AFR Shock w/ Flow Control valve, adjustable Trail Tune range, adjustable rebound, 7.625x1.625"
FORK Fox Talas RLC, 100-140mm, rebound adj, alloy steerer
HEADSET 1 1/8" threadless, integrated alloy cups, sealed cartridge bearing
STEM Specialized adjustable rise, OS 31.8, 3D forged w/CNC finish
HANDLEBARS SBC OS XC low rise carbon bar, 640mm wide, 6 degree up, 8 degree backsweep
TAPE / GRIPS Specialized MTB, dual density
FRONT BRAKE Avid Juicy 7 203 rotor
REAR BRAKE Avid Juicy 7 180 rotor
BRAKE LEVERS Avid Juicy 7
FRONT DERAILLEUR Shimano M760 XT, 34.9 clamp, bottom swing, dual pull
REAR DERAILLEUR SRAM X.0, 9-speed, long cage
SHIFT LEVERS SRAM X.0, carbon/aluminum trigger 9-speed
CASSETTE / FREEWHEEL Shimano M760 XT, 9-speed, 11/34t
CHAIN SRAM PC-990 w /Power Link
CRANKSET Shimano M-760 XT Hollowtech II, 2pc crank/BB
CHAINRINGS 22A/32A/44A 4mm thick outer, 4 bolt 104/64mm
BOTTOM BRACKET Shimano M-760 XT, integrated with crank
RIMS DT Swiss XR 4.2D, 24mm w/ eyelets, 32h
FRONT HUB Specialized Stout disc, sealed cartridge bearing, high/low flange, 32h
REAR HUB DT Swiss Custom SL, 32h disc, alloy QR
SPOKES DT Swiss Super Comp 2.0/1.7/1.8 stainless, alloy nipples
FRONT TIRE Specialized Resolution Pro 26x2.1", 120TPI, aramid bead, dual compound
REAR TIRE Specialized Resolution Pro 26x2.1", 120TPI, aramid bead, dual compound
SADDLE Specialized BG Rival, Titanium rails
SEAT POST Thomson, 7000 series aluminum, 2-bolt adjust, 30.9mm x 367/410mm
SEAT BINDER 7050 hard annodized alloy collar w/ QR, 34.9mm clamp ID, black
