Schwinn kommer med noen elektriske sykler i år:
http://www.treehugger.com/files/2008/05/schwinn_electric_bikes.phpTestet en på Norspo i fjor høst. Artig konsept som faktisk ikke ser ubrukelig ut. tror prisen havner på ca 14-15000. med skikkelige Li-Po batterier.
Litt specs:
[*] Colors Men's - Green, Women's - White
[*]Size Men's 17" or 19", Women's 17"
[*]Frame Schwinn 'N Litened aluminum with Comfort Tuned geometry, Epicenter seat stays, removable derailleur hanger, rack and WB bosses. Low step over Women's.
[*]Fork SR NEX4000 Alloy crown with one piece alloy lowers, coil spring/ MCU and mini boots. 63mm travel
[*]Crankset SR/Suntour NCX-410, 48-38-28 with chainguard
[*]Pedals Nylon dual-compound comfort pedal
[*]Shifters SRAM SX 4 8-speed rear, 3-index front
[*]Rims and Tires Alex ACE 17 anodized alloy, 36H , 700C x 40 smooth rolling all weather tread
[*]Front Hub / Motor Schwinn Protanium Mini Motor with alloy shell. 24v, 180 watts continuous; 250 watts max
[*]Rear Hub Joy Tech sealed alloy cassette hub with alloy QR
[*]Handlebar SAlloy, 25mm rise, 27 degree bend, 620mm wide
[*]Saddle Comfort Tuned Super Soft Plus with memory foam and special waterproof stretch cover
[*]Seat Post Alloy suspension with micro adjust head, pre-load adjust with 35mm travel 27.2 x 330mm
[*]Grips Bio Tuned Ergonomic Components dual density anatomical design
[*]Battery Schwinn Protanium lithium polymer 10 AH battery, charger
[*]Extras Rear alloy Protanium Rack with integrated battery carrier and patented Plug-N-Drive system, front and rear full wrap fenders, alloy kick stand and handlebar mounted bell
