on-one inbred singlespeed ramme og gaffel
on-one inbred singlespeed ramme og gaffel #409643 07/06/2007 13:21
Registrert: Nov 2005
gaylord Offline OP
on-one inbred singlespeed sykkelramme og gaffle uten demping.
DN6 steel frame (white) horizontal dropout (v-brake only), on-one rigid fork with disk and v-brake mounts, FSA XLII headset and seat collar all in very good condition (never used offroad)
gi bud?
I can also include other parts if needed? rear wheel (fixed of freewheel), seatpost, bb, brakes etc. just let me know what you need.
I am based in bergen but can post anywhere.
Re: on-one inbred singlespeed ramme og gaffel [Re: gaylord] #409644 08/06/2007 07:38
harrymedklein Offline
Har du bilde så får du et bud
Re: on-one inbred singlespeed ramme og gaffel [Re: harrymedklein] #409645 08/06/2007 08:27
gaylord Offline OP
jeg kan ta noen bilder når jeg kommer hjem og legge dem ut her.
Appologies for the bad Norwegian I am still learning :- )
Re: on-one inbred singlespeed ramme og gaffel [Re: gaylord] #409646 08/06/2007 08:33
Registrert: Jan 2002
martin Offline
Your norwegian is fine..but your nickname.......
<img src="/forum/arena/images/graemlins/smile.gif" alt="" />
www.yetifan.com www.retrobike.co.uk
Re: on-one inbred singlespeed ramme og gaffel [Re: martin] #409647 08/06/2007 08:51
gaylord Offline OP
Whats wrong with the nickname ;- )
http://www.gaylordrestaurant.co.uk/index1.html
Re: on-one inbred singlespeed ramme og gaffel [Re: gaylord] #409648 08/06/2007 08:53
gare Offline
What size is the frame?
Re: on-one inbred singlespeed ramme og gaffel [Re: gare] #409649 08/06/2007 09:11
gaylord Offline OP
whoops, 18 inch center to top, with an effective top tube of 23.2"
The frame is corrected for 80-100 travel although I run my ti version (same geometry) with 125 mm travel forks and love the way it rides.
Re: on-one inbred singlespeed ramme og gaffel [Re: gaylord] #409650 08/06/2007 14:48
bstein Offline
Well, skulle jeg ha reist for å sett på rammen hadde jeg fryktet å komme hjem både hjulbeint og hås...
Re: on-one inbred singlespeed ramme og gaffel [Re: bstein] #409651 08/06/2007 16:29
gaylord Offline OP
If you have any questions mail me direct cleppard at gmail dot com
Re: on-one inbred singlespeed ramme og gaffel [Re: gaylord] #409652 08/06/2007 16:38
gaylord Offline OP
jeg er ikke homo .....
Re: on-one inbred singlespeed ramme og gaffel [Re: gaylord] #409653 08/06/2007 18:05
chalshus Offline
...Bare gaylord.
Kom igjen folkens, dette er en flott ramme som er særdeles god å sykle sti på.
Re: on-one inbred singlespeed ramme og gaffel [Re: chalshus] #409654 08/06/2007 18:12
Trailstar_Jr Offline
Si en ca pris da..
Re: on-one inbred singlespeed ramme og gaffel [Re: Trailstar_Jr] #409655 11/06/2007 07:49
gaylord Offline OP
Offers around 1200 NOK + postage for ramme, gaffel og headset
Re: on-one inbred singlespeed ramme og gaffel [Re: gaylord] #409656 11/06/2007 08:29
sigmund Offline
Jeg tar'n! Ramme, gaffel og styrelager ja <img src="/forum/arena/images/graemlins/laugh.gif" alt="" />
__o
_-\<,
(_)/(_)____ Sigmund
Re: on-one inbred singlespeed ramme og gaffel [Re: sigmund] #409657 11/06/2007 20:53
sigmund Offline
Etter en samtale med selger så har vi blitt enige om at jeg allikevel ikke kjøper ramma.
Årsaken er at jeg litt vel sent skjønte at ramma ikke hadde disk-feste. My bad! <img src="/forum/arena/images/graemlins/kokos.gif" alt="" />
__o
_-\<,
(_)/(_)____ Sigmund
Re: on-one inbred singlespeed ramme og gaffel [Re: sigmund] #409658 11/06/2007 20:57
OveR Offline
Apartheidmotstander
Apartheidmotstander
Men det fikser da vel din lokale rammebygger på null komma svisj? Så har du likevel en grisebillig deal?
mvh OveR
mvh OveR
Friksjon ambassadør
Østmarka rock city
Re: on-one inbred singlespeed ramme og gaffel [Re: OveR] #409659 11/06/2007 21:06
Joshua Offline
Hvor mye veier ramma?
Joshua.
...Joshua...
Re: on-one inbred singlespeed ramme og gaffel [Re: Joshua] #409660 11/06/2007 21:09
Joshua Offline
Hvor gammel er ramma?
...Joshua...
Re: on-one inbred singlespeed ramme og gaffel [Re: Joshua] #409661 11/06/2007 21:13
Joshua Offline
Og, går det an å ha flere gir på den?
...Joshua...
Re: on-one inbred singlespeed ramme og gaffel [Re: Joshua] #409662 12/06/2007 08:06
gaylord Offline OP
Joshua,
The frame was purchased in 2005, used for approx 1 month commuting on-road, then stored in my basement.
The frame weighs (according to the on-one website) less then 2.2 kg
You can run gears either via a set of these gear hanger chain tugs http://www.chainreactioncycles.com/Models.aspx?ModelID=249
Or by using an internal geared hub such as a rohloff speedhub (I use one of thes on my Ti Inbred ebb) or the cheaper option, a Sram S7 (this is what I used on this frame. I have the Sram S7 Hub that came off this bike for sale if you want it (7 speed with a drum brake).
Re: on-one inbred singlespeed ramme og gaffel [Re: gaylord] #409663 12/06/2007 13:16
Joshua Offline
So, can I have 27 gears on the frame?
...Joshua...
Re: on-one inbred singlespeed ramme og gaffel [Re: Joshua] #409664 13/06/2007 14:09
Registrert: Dec 2002
Niels Offline
Do you have the brakeposts for the fork?
Where in Bergen are you? I have family that might be able to collect it for me
2013.5 Specialized Enduro Expert Carbon 29SE
Moulton TSR9
Re: on-one inbred singlespeed ramme og gaffel [Re: Niels] #409665 13/06/2007 21:36
gaylord Offline OP
joshua - You 'could run 27 gears but it would not be elegent, its a singlespeed frame made for using with one cog at the back.
Niels - I live near straume/søreide but can take it anywhere in the bergen area, and yes I do have the fork bosses
Re: on-one inbred singlespeed ramme og gaffel [Re: gaylord] #409666 14/06/2007 08:16
Niels Offline
I've sent you a PM. <img src="/forum/arena/images/graemlins/smile.gif" alt="" />
Moulton TSR9
Re: on-one inbred singlespeed ramme og gaffel [Re: Niels] #409667 14/06/2007 08:55
chalshus Offline
Rammen veier 2150 gram i den størrelsen. Mener jeg veide min til det.
Re: on-one inbred singlespeed ramme og gaffel [Re: chalshus] #409668 14/06/2007 16:48
gaylord Offline OP
solgt
Re: on-one inbred singlespeed ramme og gaffel [Re: gaylord] #409669 15/06/2007 12:15
Niels Offline
Til meg <img src="/forum/arena/images/graemlins/laugh.gif" alt="" />
Moulton TSR9
