Du er sikker på at det ikke er "sag" da?
Rolf
(Sakset
herifra)
Setting Sag
SID forks are designed to sag when you are sitting on your bike. Sag is the compression of the fork caused by the rider's weight. Proper sag
allows the front wheel to follow the contour of the terrain as you ride. Sag is adjusted by increasing or decreasing the positive air pressure of
your fork. Increasing the pressure in your positive chambers will decrease sag. Decreasing the pressure in your positive air chambers will
increase sag
