Hei
Jeg lurer på om det er noen i dette langstrakte land som er interessert i en KOT MS2 ramme? Info nedenfor...
Jeg kjenner en her i Molde som driver eget verksted og import og han er villig til å ta inn noen få rammer hvis det er litt interesse for de. Så hvis du er interessert i dette kan du kontakte:
Einar Hoff Warvik (mannen som kommer til å ta de inn)
E-mail:
einar@rettpaenfelg.comEller du kan kontakte meg så kan jeg formidle videre:
Sondre Skjølsvik
TLF: 95 02 30 92
E-mail:
sondre_skj0lsvik@hotmail.comKOT MS2 Silver
Short Long
Pris: Ca 4500-5000NOK totalt
Description
- Constructed from the massively successful Ultra 6 Aluminium, this second-generation frame also features a heavily tested rear disc mount!
- The mount is located between the chain and seat stays for maximum support, and is also forged for maximum strength. CNC machining is 'fashionable' at the moment, but forging offers benefits in that it creates a more aligned grain structure.
- Rear disc mount is located at 'Plus 20', so you can run a 180mm rotor with any of your favourite brakes, such as the Hope Mono Trial!
- Also features dedicated 4-bolt Magura mounts.
- New concept head tube gusset: pressed tube creates more weld contact area, as well as halving the stress at the weld, and saving weight!
- Due to the forged chainstay yoke, dropouts and head tube gusset, the frame can accommodate a 1.7mm thick downtube, while still keeping the weight under 4lbs.
- The frame is available in Gloss Black or Brushed Silver, in two wheelbase versions.
- Weights: Short 1.803kg (3.98lbs), Long 1.811kg (4.00lbs).
Geometry
Wheelbase: Short 1065mm, Long 1099mm
Chainstay Length: 385mm
BB Rise: 30mm
Head Angle: 70.5 degrees
Centre of BB shell to top centre of head tube: Short 655mm (25.75"), Long 665mm (26.5") Obs! Det er bare ramma som blir importert.
