Lupine Lighting Systems' norske importører...
Lupine Lighting Systems' norske importører... #336104 11/10/2006 09:54
-Harald- Offline OP
Lurer du på å skaffe deg Lupine-lys til din sykkel? Vel, jeg har prøvd en stund nå... Sendte denne mailen til Lupine (med kopi til Botolfsen) nylig. Noen som har erfart tilsvarende?:
Hi,
I understand that Lupine has changed importer/distributor in Norway from "Thesto" to "Botolfsen" in the near past. To us, the consumers, the degree of service provided from the distributor (not only the consumer shops) is of great importance, as they will be the "real" link to you guys in Lupine Germany - setting the boundaries for promptness of delivery, extent of support/supply of accessories. Botolfsen has failed to answer my e-mails, and are also not capable of delivering Lupine Edison 5, ordered shortly 2 weeks ago.
My first question is, should Botolfsen be regarded as adequate - functioning as your only link to the norwegian market - not caring about inquiries, maintaining a very limited stock/inventory of Lupine ? I think not.
The second, will it be possible for norwegians to order directly from your webpage, as Botolfsen obviously are not capable of delivering your products within a reasonable time?
Thanks and regards,
Harald
Redigert av -Harald-; 11/10/2006 09:55.
Re: Lupine Lighting Systems' norske importører... [Re: -Harald-] #336105 12/10/2006 08:34
jeth Offline
Camoboy
Camoboy
Har du brøvd å ringe Botolfsen? Det gjorde jeg igår, og det funket fin-fint. Anbefales
Jens
Re: Lupine Lighting Systems' norske importører... [Re: -Harald-] #336106 12/10/2006 10:07
geirh Offline
Ringte Botolfsen i uke 40.
Fikk på tirsdag vite at de skulle få inn Edison 5
i løpet av uken, og jeg skulle få tilbakemelding
om pris rimelig raskt.
Har fortsatt ikke hørt noe fra Botolfsen.
Re: Lupine Lighting Systems' norske importører... [Re: geirh] #336107 12/10/2006 15:19
-Harald- Offline OP
Slik jeg har forstått det, ut fra tilbakemelding fra Lupine - vil ikke Botolfsen selge til sluttbrukere. Jeg fant Lupine Edison 5 kun hos Oslo Sportslager, og må betale 6.990,-
Re: Lupine Lighting Systems' norske importører... [Re: -Harald-] #336108 12/10/2006 19:18
RazeFaze Offline
Botolfsen er jo importør og distributør. Det betyr at de selger til butikker og ikke til sluttbruker.
Sånn er det med de aller fleste importører: Stians Sport, Deler...Cyklon etc...
Skulle du kjøpt rett fra Botolfsen hadde nok Lupine Edison 5 sikkert kostet 6990 derfra også, slik at de ikke ødelegger for sine forhandlere.
Happy Trails!
Jørgen
Re: Lupine Lighting Systems' norske importører... [Re: RazeFaze] #336109 12/10/2006 20:32
-Harald- Offline OP
RazeFaze:
Det du skriver her er ikke nyheter for meg. Mitt svar ble gitt til geirh, som hadde kontaktet Botolfsen for pris, og ikke fått svar.
Re: Lupine Lighting Systems' norske importører... [Re: -Harald-] #336110 12/10/2006 21:54
geirh Offline
På den personen jeg snakket med, hørtes det ikke ut som
om de ikke var interessert å selge til sluttbrukere.
Ser bare ut til at de ikke følger opp avtaler.
