Hvilken av disse to syklene ville dere valgt? Er usikker på fordeler/ulemper i bakhjulsoppheng og utstyrsvalg. Skal brukes av jente på 63kg, kun sti.
Forslag til andre fulldempede stisykler i samme prisklasse (20k) mottas med takk.
Jamis Dakar XLT 2.0
FRAME Kinesium alloy main triangle and 7005 rear, cartridge bearing pivots, multiple linkage design, 125mm travel
REAR SHOCK Manitou Swinger Air SPV 4-way
FORK Manitou Minute 2:00, SPV, 100-130mm RTWD adjustable travel, TPC lockout.
HEADSET WTB Team, Internal Cup type, 1 1/8”.
WHEELSET Mavic XM317 eyeletted disc rims, 32H, w/ Shimano Deore XT front and rear disc hubs, WTB 14g stainless steel spokes.
TIRES Hutchinson Spider 26 x 2.30”, kevlar bead.
DERAILLEURS Shimano Deore XT (hi-normal) rear, Deore XT 31.8mm top pull front.
SHIFTERS Shimano Deore Rapidfire-SL, 27-speed.
CHAIN Shimano HG-73.
FREEWHEEL Shimano HG50-I, 9-speed, 11-32.
CRANKSET TruVativ Fire-X SL, 44/32/22,
BOTTOM BRACKET TruVativ Giga-X, external bearing.
PEDALS Crank Brothers Candy C, clipless.
BRAKESET Hayes HFX-9 HD hydraulic disc brakes with 7” front & 6” rear rotors, Hayes levers.
HANDLEBAR TruVativ LE 31.8mm Riser Bar, 6061 T6 alloy, 35mm rise x 640mm.
STEM TruVativ XR,
GRIPS WTB MotoTec Clamp-on, DNA compound.
SEATPOST TruVativ XR Double Clamp, 350mm x 27.2mm with alloy clamp and QR.
SADDLE WTB Laser V Comp with SL top and steel rails.
WEIGHT 14.6 kg
Kona Dawg Primo
Frame tubing Kona Clump Butted Aluminum, 5" Travel
Rear Shock Fox Float RP3
Fork FOX Float R 130mm
Headset Aheadset STS
Crankarms RaceFace Evolve XC X-Type
Chainrings 44/32/22
B/B RaceFace Evolve XC X-Type
Pedals Shimano PD-M520 Clipless
Chain Shimano CN-HG53
Freewheel Shimano CS-HG50 11-32 9 speed
F/D Shimano Deore LX
R/D Shimano Deore XT
Shifters Shimano Deore LX
Handlebar RaceFace Evolve DH OS riser
Stem RaceFace Evolve XC
Grips Kona Jackshit
Brakes Hayes Hydraulic HFX-9 XC
Brake Levers Hayes Hydraulic HFX-9 XC
Front hub Shimano HB-M525 disc
Rear hub Shimano FH-M525 disc
Spokes Stainless 14g
Tires Nokian NBT 26 x 2.3
Rims Sun S.O.S. Welded
Saddle WTB Laser V Race
Seatpost IRD Quad 2
Seat clamp Kona QR
Weight 13.6 kg
