Specialized Enduro Comp
Specialized Enduro Comp #265213 29/01/2006 22:10
Molde Offline OP
Specialized Enduro Comp 2003 mod til vinterpris!
Kosekjørt freeride sykkel i MEGET god stand! Ubetydelig slitasje, blir levert med helt ubrukt hjulsett. Nytt kjede, wirer osv. Sykkelen er Svart/gull
Selges for hbo 10.000,-
Spec:
FRAME Specialized FSR technology, A1 Premium Aluminum TransForm Monocoque frame, ORE technology down tube, full sealed cartridge bearing pivots, ITch Switch 100/130mm on the fly adjustable travel, replaceable derailleur hanger
REAR SHOCK Fox Float R, air spring and rebound adj., travel adjust ITch Switch, 7.625" x 2.0"
FORK Rock Shox Psylo XC, 80-125mm travel with U-Turn external adj. travel,, rebound adj., alloy steerer tube
HEADSET 1 1/8" Threadless, 3x sealed, black alloy cups, cartridge bearings, ultralight alloy top cap and bolt
STEM Aluminum, 4 bolt, 7 degree rise, black
HANDLEBARS Specialized Enduro Mid Rise bar, 6066 Alloy, 6 degree upsweep, 8 degree backsweep, 640mm width
TAPE / GRIPS Specialized MTB grip, black, double density Kraton
FRONT BRAKE Hayes HFX-9 full hydraulic disc, 6" rotor (Note: Some bikes appear with Shimano M-555 hydraulic disc brakes)
REAR BRAKE Shimano M-555 hydraulic disc brakes
BRAKE LEVERS Shimano M-555 hydraulic disc
FRONT DERAILLEUR Shimano M-570 LX, 34.9 clamp, bottom pull
REAR DERAILLEUR Shimano M-750 XT
SHIFT LEVERS Shimano M-510 Deore, 9 speed
CASSETTE Shimano HG-50, 11/34
CHAIN Shimano HG-73
CRANKSET Specialized Strongarm 7050, XT Spline
CHAINRINGS 44Ax32Sx22S, 7050 alloy 4mm thick outer ring, 4 bolt 104/64mm pattern, Steel chainring bolts
BOTTOM BRACKET Shimano ES-30 Octalink spline, 68mm shell width, 113mm spindle length
PEDALS Shimano 515 clipless
RIMS Mavic X223, 26", black, welded seam, eyelets
FRONT HUB Specialized Stout disc, 28 hole, sealed cartridge bearings, 9mm Skraxle
REAR HUB Shimano M-525 Disc, 32 hole, loose ball bearings, alloy Q/R
SPOKES DT Swiss 1.8mm stainless, black, alloy nipples, 261/258mm front, 258/259mm rear
FRONT TIRE Specialized Enduro Pro 2.2", aramid bead, 120 tpi
REAR TIRE Specialized Enduro Pro 2.2", aramid bead, 120 tpi
TUBES Specialized Ultralight, presta valve
SADDLE Specialized Body Geometry technology, hollow Cr-Mo rails
SEAT POST 2014 Alloy, black, 30.9 x 350/400mm
SEAT BINDER Alloy collar with Q/R, 34.9mm clamp I.D., black
http://www.specialized.com/bc/SBCBkModel...ikeTab=techspec
Kun 10.000,-!!!
Re: Specialized Enduro Comp [Re: Molde] #265214 30/01/2006 14:27
Registrert: Jan 2006
JenteTruls Offline
Heisann!
Kva størrelse er ramma? 16" 18" eller 20"?
Baste <img src="/forum/arena/images/graemlins/coffee.gif" alt="" />
Re: Specialized Enduro Comp [Re: Molde] #265215 30/01/2006 16:25
Registrert: May 2004
Sebastian Offline
Sebastian Pedersen
Re: Specialized Enduro Comp [Re: Sebastian] #265216 30/01/2006 17:24
Molde Offline OP
Heisann!
Ramma er str. M.
Re: Specialized Enduro Comp [Re: Molde] #265217 30/01/2006 17:26
Molde Offline OP
Det tilsvarer ca 18"
Re: Specialized Enduro Comp [Re: Molde] #265218 31/01/2006 15:19
JenteTruls Offline
Heisann..
Vil 18 tommers ramme vere for stort til ein 16 åring på ca 1.73 cm?
Re: Specialized Enduro Comp [Re: JenteTruls] #265219 31/01/2006 16:42
Molde Offline OP
Hei, det blir ikke for stort! Sykkelen er veldig leken og lettkjørt. Er selv 176cm, og den passer perfekt til meg, både opp og ned fra fjellet!
- Øystein.
Re: Specialized Enduro Comp [Re: Molde] #265220 31/01/2006 16:46
Molde Offline OP
Mob. nr er 92208437
- Øystein.
Re: Specialized Enduro Comp [Re: Molde] #265221 05/02/2006 23:32
Molde Offline OP
Kosekjørt freeride sykkel i MEGET god stand! Ubetydelig slitasje, blir levert med helt UBRUKT hjulsett. NYTT kjede, wirer osv. Sykkelen er Svart/gull. Sykkelen vil fremstå nærmest HELT NY!!
Sykkelen har nå akkurat fått service på demper!
Ny pris er; 22.990
Spec:
CHAIN Shimano HG-73
Kun 10.000,-!!!
Re: Specialized Enduro Comp [Re: Molde] #265222 15/02/2006 17:17
Molde Offline OP
Er fortsatt til salgs!!
Meget velholdt, nytt kjede/wire/stem, hjulsett, + valgfrie pedaler(klikk el. flat).
KUN 10.000,-!!!
Re: Specialized Enduro Comp [Re: Molde] #265223 27/02/2006 10:24
Registrert: Feb 2006
JonasO Offline
Hei!
Jeg har sett litt på sykkelen din og synes det virker veldig interresant. Er det noen justering på bakdemper? er det lock-out foran på demperen som er der?
Sykkelen er jo DRITPEN! <img src="/forum/arena/images/graemlins/ooo.gif" alt="" />
Har du noen bilder av sykkelen din som du har tatt selv?Hadde vært fint om du la ut de å!
Re: Specialized Enduro Comp [Re: JonasO] #265224 01/03/2006 12:19
Molde Offline OP
Heisann!
Det er justering bak ja, fra 100mm-130mm, noe som du kan gjøre mens du sykler med en liten spake du dreie 180 grader. det er også et hjul du kan justere hurtighet.
På fremgaffelen kan du juster vandring, fra 130mm-80mm, men det er ikke lock-out. Under gaffelen kan man vri på en spake for å justere hurtighet.
Skal prøve å få fikset et bilde(kan ta noen dager, har ikke digital kamera.. <img src="/forum/arena/images/graemlins/smile.gif" alt="" />, men kan også sende via mms på mobil om det er aktuelt.
Tlf: 92208437.
Mvh Øystein.
Re: Specialized Enduro Comp [Re: Molde] #265225 02/03/2006 18:05
holand Offline
Er sykkelen brukelig til xc sykling? ser du skriver freeride, men på specialized sine sider så går det fram at den er dugende til både det ene og det andre. har du noen erfaringer å dele med oss?
Re: Specialized Enduro Comp [Re: holand] #265226 03/03/2006 15:06
Molde Offline OP
Ja, den er absolutt brukelig til xc sykling! Siden man kan justere vandringen på sykkelen er den bra både bortover/oppover og nedover.
Den er super på lange turer i terrenget (derav navnet Enduro, kommer fra maraton-lignende moto-cross konkuranser). Det er ingen racing sykkel, men den passer for alle som vil ha en solid fulldemper som tåler alle typer terreng, alt fra grusveien til utforløypa!
-Øystein.
Re: Specialized Enduro Comp [Re: Molde] #265227 15/04/2006 19:35
Registrert: Jul 2005
Varvik Offline
bump
