Giant Trance 2 Small
Giant Trance 2 Small #2704337 14/04/2022 12:07
9
92er Offline OP
Giant Trance 2 27.5 2016 størrelse small til salgs. Kjøpt ny på XXL av meg i 2017. Brukt av to gutter på 10-12 år. Super sykkel til sti eller enduro for ungdommer eller små voksne. Den har 140 mm vandring, og er lett og håndterbar. Satt opp slangeløst med Specialized Ground Control dekk. Setepinnen trenger sannsynligvis ny wire.
Prisantyding kr 12 000/bud. Må hentes i Oslo. Send PM ved spørsmål eller bud.
Product Description
Keep cool on the trail, even when it gets rough. The lightweight yet stiff ALUXX SL aluminum frameset of the Trance 27.5 was designed specifically to optimize the performance benefits of 27.5-inch wheels. It’s engineered with 140mm of proven Maestro suspension in the rear plus a host of frame technologies including the OverDrive steerer tube and PowerCore bottom bracket. Whether you’re climbing or descending, pinning it at speed or crawling through technical terrain, Trance 27.5 helps you tame the trail.
Features:
ALUXX SL-grade aluminum frame with 5.5 inches of smooth Maestro suspension
Fox 32 Float Performance 140mm-travel fork with 15mm thru-axle
Fox Float Performance rear shock
Giant S XC-2 rims, Giant Sport Tracker hubs, stainless spokes
Shimano Deore / SLX 10-speed drivetrain with Shimano M615 hydraulic disc brakes
Giant Trance 2.jpg (1.11 MB, 1176 nedlastinger)
Redigert av 92er; 14/04/2022 14:26.
Re: Giant Trance 2 Small [Re: 92er] #2705400 24/04/2022 18:54
Registrert: Jan 2008
larshkj Offline
Hei. Har sendt deg et par meldinger ICON_SMILE
Lars
